View Full Version : Honda CRX / EF Civic (1988 - 1991)
- heat question
- Wideband converter (searched)
- 89 crx
- thats my honda
- question
- fuel injectors
- Should I just get an aftermarket fan?
- Code 4???
- help..91 si dont start.
- B18c/r over heating please help!!!!!!!!!!!!!!!!!!!!!
- clutch and fly wheel deal????
- recaro srd question
- window problem
- b18 wont start, cel 8
- New OEM Civic EF Mats ?
- JDM Headlight Scatter....
- Air bag, steering wheel and horn??
- Problems with distributor and Air filter
- Cracked power folding mirror.. what to do?
- i got a honda!!!!
- EXTENDED WHEEL STUDS ! HOW HARD ARE THEY TO PUT ON ?
- what you think
- crx headlight
- When doing a swap?
- b16a or b20
- No heat
- Some pics of my Rex
- 2.2 i-CTDi
- looking for a flywheel
- anyone make engine dampers for the ef w/ d-series
- Early 90's integra ecu into a 91 crx
- STOLEN EF9 !!! HELP!!! SOUTHBAY REDONDO BEACH
- Rust Repair options
- b18a1 swap in 89 hf
- Heater removed, Clever way to handle the plumbing at the theromstat and block?
- honda newb working on mini me
- first post...problem w/ 89 crx si
- Help! CRX B16 Harness Dilemma (NOOB)
- REAR HEADREST USDM
- putting a d16 into a 90 civic hatcha 1992 civic hatch with a di6
- should i get the sir conversion
- installing new tranny need help
- b16 crx axle bind issues need help
- 1989 Civic Hatchback B18B1 Build
- need a shop to install a stock motor in socal area
- d16a6 Jackson Racing Supercharger on ZC?
- obd1 conversion problem, code 41 oxygen sensor
- CRX B16
- Thread Size of Seat Bracket Bolts
- Am I lacking anything people? freshening up a B16A swap....
- hf stumbling very bad
- crx fuel pump??
- ebay ball joints
- I know there's gotta be a thread for it...d15 building? NON-MINI-ME!
- grinding into reverse?
- B18C5 INTO EF HATCH....MOUNT QUESTIONS???
- tranny question
- should I plug banjo bolt hole with caliper removed?
- d16y8
- ecu code
- 90 Crx vs 90 Civic Fuse question ?
- D16A6 block with Y8 head, help me with a couple of plugs
- Eletrical problems
- cat-back exhaust system?? 89 hb civic si
- major tuneup
- which lip is this and were can i get one?
- PErformance clutch, barks!
- Tried bleeding brakes, snapped bleeder bolt
- stupid vtec rpm switch garr
- Inner axle joint problem -91 edm civic b16a1 Y1 tranny
- cel problems i have video i think 10 17 are codes let me know
- Smells Fishy?
- Code 43.....What could it be??
- sunroof question
- i have a clutch issue
- Need HELP WITH PROB!
- timing belt question
- the 4 door
- 89 CRX B18C1 Install issue: Distributor wire problem
- i think these are codes 18 17 10 ef89dxcivic
- crx build coments and sugestions welcome
- 5th gear gind
- oem crossmember ?
- issues with remote starter
- what radiator do i use?
- identify this
- 90 CRX DX Caliper won't come off
- wiring and brake questions for swapped 88 crx si
- Motor Mount Problems
- Clicking feeling coming from car??
- O.E.M. Honda front Lip here!!
- detonation
- No compression in 1 cylinder. Need help
- Power steering wagovan noob question
- 02 rsx steering wheel on a 00si
- Can any one idendify this bumper for me?
- Intermediate/half shaft
- my crx shaking, evenmore when on high speed
- s2k
- still having idle problems
- Noob brake question
- cam stage?
- So i was done putting gas in my car
- Cf hatch ?
- bumper question
- crx cup holder??
- which clutch will work...
- need a lil help
- Simple noob Hatch/CRX interchangeability Q
- gsr blades on crx?
- H.I.D. lights for ef9
- Help please! Rookie Wiring Questions!!!
- new clutch
- wiring harness!!!!!!!!!!!
- ticking driving me crazy
- 2 dumb swap questions...
- DOHC ZC in my EF si w/ ticking noise, I NEED YOUR HELP!!!
- my bad, axle help
- Lower strut tower bar crx
- Please help diagnose - hard start (researched and cannot find cause)
- bad idle....tps?
- intake manifold question on crx
- >>>>Motor Sputters?<<<<
- oil pump failure.
- spark plug wires arc
- alternator removal..
- taillight swap?
- pm6 ecu
- shif linkage seal?
- Ignition key cylinder install HELP!!!!
- zc throttle body size?
- B18A1 automatic to manual transmission in CRX
- Civic Seat Swap - Do DX Bolt Up To Si?
- crx moulding strip
- supercharged sohc zc
- lots of problems.
- need exhaust what are my options?
- anyone know which plug this is?
- Fuel line?
- fuel, spark, and still no start?... HELP!
- tachometer reading too high after b16 swap?
- My efk build
- Seat rail extension. '90 DX Hatch
- How to tell if cam gear or cam are tweaked? Trashed shipment.... :(
- snow tires
- shocks on my rex
- CRX SI ECU pinout
- best pistons for an ls-v build
- anyone else broke this before????
- crx fuel pump not turning on
- sir cluster wiring
- 89 EF DX hatch help
- Swap help..?
- bad cylinder sensor or timing marks????
- ef hatch swap!! need some help!
- spewing gas from tank
- Bog at over ~90% throttle
- Turbo ZC sedan???
- What NGK plug wires fit the DOHC ZC motor?
- b16 vs. b17 vs. grs head
- 91 ef when i hit the brakes the car bogs down and quites running?
- oil leak
- Relay location?
- how do you get a speed signal to the ECU?
- Starter Signal Wire
- Brake problem
- installed jumper harness and car will not turn on. please help!
- trouble with my clutch
- B18 Swap
- 1990 Civic won't start
- b20 not cranking
- tein springs ??
- redlines at 7000rpms???
- EG Civic carpet in EF civic interior ?
- new guy from cincy... ef sedan pics
- .............89 dx hatch need help .................
- Problem ZC Motor
- Check engine light
- having hell of problems with my ef
- grounds
- K20 EF Photo Shoot
- AEM air intake for '89 civic lx jdm b16 swap
- overheating d15
- Starting issues
- All wired up and now she smashes!!!
- heater removal
- good deal on a EF9 front end..need advice
- explain the differance
- speaker brakets????????
- Throwout and pilot bearing for B16 Gen I
- Rear Disc Brakes, by the way...
- b16 tranny removal problem
- speedometer dont work????
- for those who are using innovative mounts what do you recommend for the stiffness?
- My Ef hath project.. crazyness? i think so.
- code 17 VSS speed sensor
- hasport ac bracket belt
- Inner fender plastics
- GSR into EF HELP!!!!!!
- seat rail question
- ok
- Water temp guage problems
- Fuel Gauge needle Broke =\
- Is It True?
- Brake Caliper problems
- Hydrogen tip
- Caliper Rebuild Kit
- stupid ? about exhaust!!
- blown motor???
- calling out the north bay
- Vibration while driving and turning LEFT ONLY... searched... please help
- ARC Intake in a EF??
- crx starting problems
- ls_vtec swap in crx????
- is this normal
- innovative kit
- idle problem. just did motor swap
- New Turbo...24lbs.
- Name that Plug...Cleaning up engine harness
- crx swap WIRING question
- DC2 , what all can i use on my sedan
- 89 Si overheating
- 89 Si overheating
- 89 Si overheating
- What year clutch and bearing will fit my b16?
- help with my car
- B series swap... Hub question..
- jdm B16 exhaust manifold
- header to downpipe bolt hole stripped d15b
- crx hf getting bad gas mileage :(
- Honda injector flow rates???
- starts then dies...then won't... few cranks later...starts
- Swap question
- new crx
- d16z6 swap in a 90 crx
- Turning the buzzer OFF
- crx wiring
- mugen twin loop
- Help
- power mirrors....?
- b20 into 88 crx
- PGMFI.org ????????
- 89 ef civic no start
- NO SPARK. HF ENGINE
- Radiator Fan Problem
- brain storming
- ball joints
- No Codes Car will not go over 50mph
- Best rear LCA for 89-91 crx
- Lighting issues instrument and tail lights
