View Full Version : Honda CRX / EF Civic (1988 - 1991)
- wings west body kit help
- would a ob0 ecu plug in right on my 90 civic dx?? need help tryin to put an ls motor..
- Can you identify these Motor Mounts??
- skunk2 stage 1 or buddyclub III's?
- **My 90 civic hb w/ LS jumped timing**
- Where to get stock bumpers?
- CRX sunroof swap with 3rd gen prelude
- little help on my jdm B16a
- **OFFICIAL D15B VTEC PARTS LIST**
- Help!!! I need help in buying a header for my B16a OBD1 for my 90 CRX Si
- Who has a BAR certificate that has to do the idle/2,500 rpm test?? (not the 15/25mph test)
- Newly installed B20B in CRX will not start. I checked everything. Help!!
- To Nitous or not to Nitrous?
- taillights
- charge pipes
- Sparco Harnesses...install
- sir headlight wiring question
- Need help on swap
- Eg radiator in crx? will a/c work? and any mods to bolt it in?
- civic w/zc tranny synchros
- How do I fix my car?
- Stupid emissions!!!!
- crx intake flange for welding
- a few probs with my 91 DX
- Quick timing belt question.
- high idle after lsvtec swap
- Where can I find this????????
- Mini Me or Turbo - Vote!
- CRX Si - Brake Upgrades?
- 1984 Civic
- obx intake manifold?
- FINALLY <--- B18C1 crx
- d16a6 differs from d15?
- Engine light, ecu wireing help
- car keeps dying
- B series guys, a tranny question..
- Where are good shops in Jersey?
- how much does a civic si sunroof/assembly weigh?
- Q about engine wiring harnesses.....
- 1991 hatch with d16z6
- pic request---------POST PICS OF CRX'S WITH BLUE PAINT JOBS
- truth about turbo (??? bout it)
- Why Did This Happen?
- V-tec controller wiring diagram
- CEL goes on when engine is warm, but no codes?
- Grinding noise coming from timing belt area
- help im confused
- To Flame or Not to Flame?
- Dual Carb ZC
- Sweet, I got an LS 5th gearset (pics)
- eDid I f**k my clutch up?Please help me diagnose.
- Glue: Questions I am trying to glue metal shit on Windshield for rear view mirror
- engine harnesses interchangeable between trims (dx/si/hf) and years (88-91)??
- F/S: 91 honda crx si right hand drive , b16a1,wide body!
- need b-pipe
- What to do?
- JerZeyReX CrX...
- yeah, i'm a newbie, with a noob question
- help;buying Dohc ZC.
- B16a in crx
- having trouble
- need : how to swap Dohc ZC into an EF civic sites.
- Where In Philly Can I Get A Good Swap!!!!
- Anyone running PM7 (DOHC ZC) pistons in your Y8?
- help on building all motor crx??????
- I'm new here, PICS of my REX
- Fix-it ticket blue! & ZEX kit question
- Sohc parts for sale crx civic
- Me-N-My Hatch
- Need Help !!
- 88 crx tranny on 92-95 engine
- idle problems
- CRX bumpers on HAtch?
- leather seats
- 89 Crx SI theft recovery, cut cables need help ASAP.
- Sacramento, Ca Engine Rebuilt ShoP?
- just installed camber kit and teg brakes..uca's touching fenderwall...help!
- NEED SOME VAFC HELP!
- CRX exterior done
- GSR TURBO STOCK INTERNAL?
- B16 CEL! 1st gen code 14??? engine in 91 crx si
- civic tranny question???
- !help! leaking 4 quarts in seconds!!!!!
- bar certified b18c!
- SRT-4 Intercooler on EF/CRX (mockup pics...you decide)
- head gasket?
- questions on zc swap
- WTB: 88-91 CRX Carbon Hood
- EG body with JDM type R front end...
- Fixing up GF's Car, what's this thingy?
- Failed emissions need some opinions
- most RUST EVARRR!!!
- adjusting doors
- mounts maybe?
- Anybody wanna trade their bumper for Mine
- How much is a y1 worth? Is a LSD Y1 worth the hassle?
- 15 inch VS 16 inch
- BRAKE LIGHTS STUCK ON.
- my wipers aren't working
- d15b vtec clutch setup, what are you guys.....
- What ECU's can I use?
- where to get a battery cable
- B20/VTEC build pics
- cant remove tie rod end...help!!!!!!
- This guy makes a B-Series into an EF sound REALLY hard! Is this the case?
- Dropped the pan and found specks of stuff on the screen?????
- My 1990 Civic Si hatch sound
- D16Y8 block, D16A6 head?
- Picked up the car this weekend, finally
- POLL: Help me out with a plan...
- Need help on what size of rim??
- LF: EF9 SiR Dohc Vtec sticker.
- i need a new zc!!!
- What kind of rims are these
- worth running equal length axles?
- question about tein basics for crx
- Searched and Couldnt Find: JDM Body Kits for a CRX.
- B18A1 in Crx si?.....Is there anyway to make it work?
- 90-93 integra abs axle's
- HKS sport exhaust for CRX-searched already
- heat/aluminum radiator
- Has anyone ever hooked up a automatic b series in a EF?? (not for me)
- b16 swap
- hopefully not a dum question
- radiator problems
- D16A6 mini-me swap - timing belt?
- HF adapter?
- I've seen everything now..DOHC ZC head on D15 block...WTF
- eMugen kit really wind tunnel tested??
- intermitent relay?
- engine harness question...i have searched
- Adjusting cable clutch
- new crx suggestions...
- Ignition Timing Range
- is a si tranny suppose to say .. and other question for the zc head
- lookin for a site that sells stock motors?
- Idle dips low after skunk2 cam install, suggestions
- tranny problems
- put my motor in today...
- Aftermarket Intake Manifold
- b16 boosted or boost d16a1
- h 23 swap
- new crx! died at stop light B16G1, acts up, revs on its own!
- o2 sensor/boggin question?
- trailing arm bushings
- cant stop oil leak
- ls pulley or gsr pulley
- mid engine crx
- my side marker lights (orange side lights) and tail lights dont work, only headlights, brake lights
- My turbo hatch PICS
- Carbon Cluster cover on my 90"Hatch>>>>>>>>
- STD woes *and not that rash*
- bought crx, need swap advice
- B20 Vtec Need some help
- Q U E S T I O N???
- fuel line fitting size?
- B20Z Compression Ratio and Stock Sleeves
- different head for my d15a3 block
- Motor Question
- crx idles too high?? WTF?
- *New Official Exhaust PIC Thread****NO COMMENTS ALLOWED****
- Distributor and oil problem
- CTR CLUSTER WIRING!?
- motor swap/wiring
- cam angel sensor on a zc q's
- fuel rail threading?
- dizzy problem?
- sohc v-tech head on a d15a3 block?!!!?
- D16a6 Fuel rail nut and washer
- invidia catback
- Front brake upgrades
- sohc head on d15a3 block?!!!?
- how do i post pics
- potential for a D16y7
- wiring harness conversion???
- manual boost controllers
- which mounts for b18a1 in crx??
- PICS???
- turbo project, input wanted
- Does anyone know where I could get a detachable steering wheel?
- Turning on headlighst, idle drops 500 rpms. Help
- Oil leak...HELP
- tranny problems
- auto to 5 spd swap questions + b18 swap questions.
- emergency help
- SiR exhaust on ED9 ?
- any have MPFI wire harness for sale in south cali???
- Upgrade for 89 Civic Si HB
- New to the board, previous Ef rex owner
- putting 4point harness in crx any ideas? pics?
- VIBRATIONS!!! What mounts will make my B series more like OEM?
- new here
- B18C5>into>85 crx si
- Whats up w/ this!?
- does this happen to anyone else with front fenders.
- Bought a new CRX project
- dc headers for sohc zc motor
- dpfi to mpfi
- what are hubs
- Starting problems...
- quick question.
- Question about rear defroster on crx
- Pic request -> Civics with CRX Wheels
- EF9 front bumper on CRX
- articles regarding rebuilding blocks.
- Help! Installation help with Crx Si Under dash Harness
- CRX for sale
- HELP : ecu pinouts for a pm5 ecu
- tranny installation qwestion
- crx will not start!!!!!!!
- It's finally here (ZC), lets get to work...
- NAPA axles.....WTF???
- My CRX.
- HONDA ENGINE SWAPS !!!!!!
- Quick CRX question...
- Automatic B-series motor into manual EF
- axle comparison
- **Stock looking body kits, thought on THIS**
- transmission
- ecu question
- Skunk2 Exhaust system
- ZC head ports...
- Intake Manifold Question?
- ****Automatic seatbelt troube**** PLEASE HELP
- 02 sensor replacement (b16a1)
- Tranny swap question...
- Tranny Gear Ratios (Cali People)
- tranny question
- Winter car.
- H22 88-91 CRX mounts, question from the UK!?!
- Mechanic or ZC expert needed in Northeast
- What do I need to swap a D16z6 into a CRX??????????
- Allright, looking for help here...
- car wont start
- Wiring problems.
- possibly a dumb question??
- help with interior
- HEAT MY CAR DAMMIT!!!!
- 88 Crx Si fueL!!??
- obd-0 cipping
- JDM Crx bumper on HB, pic please
- '91 Mazda Protege GT rims OK for use on '91 Civic?
- Bad distributor = my car feels like it's in neutral?
- Right hand drive CRX?
- skunk2 springs???
- headers on a auto 90 sedan with a 98 D16Y7?
- starter, high compression b18
- zc swap problems
- civic comparasion
- Making speedo work with H22 swap?
