View Full Version : Honda CRX / EF Civic (1988 - 1991)
- ac fan prblems
- ef9 new suspension budget help
- alternator help plz
- B18 CRX Swap Help . Reward Offered.
- clutch is slipping..pls help
- Solid CEL and ECU Code 9 CPY Sensor After Timing Belt Change - Searched
- DA lip fit>?
- External coil install Howto (obd1)
- Help! My V-Tec is Not Activating
- Crank Position Sensor Help
- Alrighty I bought the wrong axles, b16, ,y1 with a half shaft
- car insurance??
- Door swap.
- CABIN HARNESS
- p28 or p30 whats better
- Best halfsize radiator?
- smogg
- 88 crx zc dohc wont start HELP !!!
- Noob to the Honda World ...
- code 16 help
- yaaay, stripped the rear interior, take a look!!!
- Suspension swap question
- what shock are you running with Eibach pro kit? (searched already-need opinions)
- raspy exhaust!
- I got a good look at the car today
- help help!!
- 1990 projection lights civic
- New brakes tomorrow!
- Crankshaft Pulley removal
- B18 miss fire
- Motor rebuild kit(dohc zc)
- is a Y1 tranny a B16????
- 1989 CRX HF stock
- Aftermarket 2" tach - works etc.. but lighting wire? Help.
- b16a faq's
- OBD0-OBD1 conversion....
- DOHC ZC?
- omni power(new design) or skunk 2 pro series(new design)
- 88-91 D16A1 Ls and D16A6 Crx Si questions???>>????
- Build thread - no real technical info here...
- quik question( does ac from a crx fit a hatcback)
- Help: Choosing an intake for a CRX
- b16a
- Stupid newbie question...Sorry!
- Canadians!!! Swaping EF8 JDM front headlights for USDM ones?
- Additional Bung on header....
- need help, ls wont start
- Oh No, Another Nissan turned Honda Driver!
- carb legal intakes
- can anyone show me a photo of an 87 crx cargo cover, or tell me if an 88 cover fits?
- EF Headlights installed, now need some help with wiring for fogs and sidemarkers too
- smoking like hell after mpfi
- question on intake vacume lines??
- CEL on OBD0 converted to OBD1 91ef..HELP HELP HELP!
- Help Please 1st swap of my life
- mpfi help
- To all that have seen my car on Honda-tech please look i need your advice
- ACT 88 to '90-'00 clutch conversion kit
- question for ef cars?
- Turn signals keep clicking...
- high idle when i park automatic dohc zc trying to help out a friend
- Intercooler fitment with 90-91 hatch bumper
- Tips on lining up my jdm front end.
- Help Please... horn+brake light+door/seatbelt alarm
- Getting bar'd legal questions?..
- Fluctuating Idle when hot
- blitz bov question
- The higher the RPM the hotter she gets.1990 Civic Overheating
- 89 Si engine harness question ?
- Mugen chip on a SOHC vtec
- what fmic?
- front bumper mount
- wiring up a rhd converted crx
- CLUSTER CONVERSION ON A CRX
- 89 ef with b16a a/c conversion
- RIP Homer.
- d16a6 long block
- taillights and interior lights out?
- swap didnt go so well...
- b16 jdm obd1 170hp
- Any Body build a b16a stroker in here
- mpfi
- Clutch pedal suddenly came up.Anybody have any explanations???
- Timing belt came loose, couple questions.
- i need to know how too...
- BB6 97-01 prelude wire tuck...
- d series high compression questions..... i am looking to have a 11.5
- Apexi world sport 2
- Where's the needle on the temp gauge?
- CRX B18a1 questions
- Removing rear bumper
- z6 build/mini-me what is better?
- Heater core removed, how to block off hoses on block?
- rom burning help
- Final Dession on JDM D15B
- Exedy clutch, what stage is this?
- Buddy Club Spec II exhaust question (Parts related)
- D15B transmission mounts
- obd0 to obd1 *HELP*
- *****CEL CODE 21 Vtec Solenoid *SEARCHED* OBD0-OBD1
- so installing a fuel pump...
- DOHC ZC
- sanding valve cover for paint.
- timing belt question
- can i smog my 90ef w/a d16z6 in it? & b18b in a 90 da integra?
- 1st gen b16 valve clearance??
- Engine I.D
- JDM wanna be bumper
- turns over and dies
- b16 91 hatch
- How can you tell how old your engine is?
- Bolts for a 91 Civic ??
- magazine issue request
- crx build plans...
- Carnage!
- i need help plz
- having trouble starting it up??
- Problem with exhaust on my 89 si
- wtb,ef8,ef9 parts
- WTB EF9 and ef8 parts
- Loud rattling noise after changing valve cover seal.Help please please
- Help?
- CENTER CONSOLE
- Anyone know what assembly plant EF8 SiR's were built in?
- vtec engagement
- NEWBIE >>>>>EF/S2k??
- sohc vtec swap question
- Easy but not... Rear seat removal: 88-91 civic hatchback
- check engine light on, need help
- maby a bad question or 2. but please help
- K series EF
- Hesitation Around 3K Rpm B16a 1st Gen.
- WTB exhaust for 91 civic
- Am I going to need any specific tools for a strut install?
- motor question??
- why did explictspeed get kicked off!!!!!!!!!!!!!!!!!
- Serious Z6 in 91 SI problems. Need help ASAP!
- another b16 build, just with a sazdasl twist
- st legal car!!)Anyone got problems with North American fuel?
- are 88-89 Civic doors the same as 90-91 civic doors?
- New to the site
- ZC Swap problem >=0[
- 89 Rex runs one day -Nothing next day
- obd0-obd1 conversion harnes difference? Vtec doesnt work
- y7 head on b2 block
- batterie relocation
- Half project car
- what are symptoms of a bad temp sending unit
- EF8 door
- Need My Seats Rewrapped Leather
- 88-89 Front/Rear Bumpers and everything of OEM will fit in 91 crx?
- compression tester stuck in engine
- SIDE MARKERS ON EF??????HELP
- overheating bad thermostat???
- JDM D15B NON-VTEC TO VTEC SWITCH ( HOW TO DO )
- thanks to every one
- im a noob and i need a opinion on my crx si
- Idle question
- D16z6 into an 88 crx dx
- JDM Hatchback front end on a USDM CRX?
- Obd0 to Obd1 conversion
- im back in the game :)
- Noob here, '91 DX sitting for over two years.
- 1991 CRXSI CAM HEAD TURBO ZC ?????
- Transmission grinding on deceleration
- know of a place to buy RHD ef8?
- d15 vtec swap
- B back to D series swap help
- Steering wheel shakes/vibrates while braking
- ef8 cluster
- rebuilding my tranny
- ***EG radiator on EF***
- d15b7 in crx won't start help
- Question about engine Block bracket into crx
- Anyone using this steering wheel hub?
- jdm hood for sale
- problem with autometer a\f gauge
- JDM D15B HELP!
- 1990 crx ls senser problem
- this is my car trying to turn on after mpfi swap why wont it go??????video inside!!!
- tranny ?
- weird idling
- 89 si crx ecu in a 90 si crx ????? will it work???
- No 1 2 on blower setting
- Where is the ECU temp sensor?
- ***DOHC ZC Smokin?***
- Possible Mount Solution: Hydraulic SOHC transmissions into the EF chassis
- vtech motor
- 2 injectors converted to 4 injectors
- Need Help!!!!! B16 ef obdo problems!!!!!
- RTA bushings
- fresh swap..CEL light flashing 2962969x a second
- HOT ROD Magazine EF CIVIC
- supercharger question
- what swaps can or can not i get bard or smog? into ef hb n da
- dizzy swap question
- another wiring/connector question
- Oxegen Sensor
- smoking b16a
- JDM Fogs/USDM Front
- 95 Civic DX faltering on idle
- Autopower race bar with harness
- Custom Gauge Faces and Templates
- auto manual swap question
- d15b question
- ya or nah!
- C-Pillar Bar
- what is the difference between a 91 CRX Si and DX?
- COPS ARE DICKSSSS!!
- CRX hatch alignment
- Body Kit . . . Hope I don't get kicked out of here . . .
- 91 crx si MC questions!!
- My cheap bucket of crap CRX
- Full polygraphite bushing kit for 88 crx dx?
- H22 EF Sedan
- CRX Cat-Back Question
- anyone knw a way to bypass or get rid of map & iacv?
- 1990 crx hf problems
- 91 si b16 wont start....please help..
- When removing and re-installing axle shafts,do I need to change anything???
- Help: CRX w/GSR swap *Wiring*
- Brake booster issue.
- distributor question
- gas cap problem
- LS TP bigger than ZC TP?
- Good deal.
- ITB's for my D-Series
- MY 4G4D
- trying to swap b18a1 motor in 89 hf crx
- JG 301 cams for DOHC ZC, anyone have the specs?? I need a 'cam card'
- so i finished my mpfi swap cranks but doesnt start
- Do not like/Ok Lighting.
- alignment getting worse? clunk under hard braking?
- doing a y7 swap..I'm confused on what this wire is though ..
- More HP
- Custom parts for EFs???
- Sunroof
- my setup and a question...
- Official Honda Workship Manuals (UK version)
- tranny problems?
- nos question.
- Need Hasport Motor Mount Bolt Measurments........
- pre d15 to d16 swap
- coolant coming out of tail pipe?
- **Looking For Helms PDF**
- Half Rad for the turbo set up
- Any insight on the Engery Suspension Kit for a CRX???
- New Hatch owner
- CRX leaks water please help!
