View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Ticking sound when turning, axle or something else?
- FS: JDM CRX SiR
- is there an obd0 vtec ecu and dizzy?
- Motor Swap Question
- Check out this gem.. V6 crx ebay
- best valvetrain on a gsr head?
- CF project II part2
- CRX b18 swap question
- Honda Training School
- b16 block, gsr head, what wiring harness?
- Farking GSR ?s into CRX (i searched)
- Door Seat belts
- A few issues to work out...
- They got me
- ignition problem?
- I need to locate a Personal steering wheel hub.
- tachometer white wire connection
- B-series swaps into 89-91 CRX-how much longer did you extend your cat?
- no getting any poer to my fuel pump
- overheating question
- b series wiring harness ?'s
- i need some help up in maine
- Clutch disc question
- oil leaking from tranny!!!!!!!!!1
- jdm conversion questions
- b20 for the rex
- does 5 lug fit on ef's??
- B16 Power Loss
- B16a Turbo, starts but stumbles and doesnt idle
- What is the easiest way to take out the dash?
- car height
- clutch conversion
- fender braces
- car wont start when warm
- Pics Needed... Trying to make an exhaust decision
- B16 in a 4g hb
- k20 in 4g civic???
- What is Code 43 for OBD0 PM6 ECU?
- just did a swap and............
- what clutch cable to use????
- Ignition troubles and general weirdness/ (kinda long)
- car doesnt like starting in the afternoons
- elctrical Crap
- Whats better koni yellows with ground controll of tein basic
- EF8 Horns louder??
- Would there be any significant difference in putting a b17 iintake manifold on a b16?
- Crank Removal?
- YAY!!! New problems with my car. Please Help
- are civic and crx seats interchangable?
- where to find B16A
- Rear speaker pods/mounts?
- Need help finding 2 wires
- D16Y8 doesn't come with a oil return does it?
- B16 Throttle Body
- got the rex fixed
- 2nd Gen crx motor ?
- Integra shox in crx?
- SWAP... fuel return line..... stock EF or use the GSR
- My Big CRX Project
- fuel filter pic request
- carbs for a b16a engine?
- shift linkage in a b16 swap?
- AEM INTAKE OR INJEN INTAKE???
- ZC = d series?
- My automatic tranny is fuked up
- B16A problems and questions??
- form EK, to EG, then EF.
- WTB Hatch civic,Coupe Civic, or Intgera in the Chicago Area
- ZC HEAD!!!!!
- body work
- ? itr im
- CRX aftermarket headlights
- I need help with fuel cut on a b16 swap
- Can you drive without a rear motor mount?
- UKDM Gauge Cluster Write-up: install into 90-91 CRX's
- I NEED MORE BOOST
- Anyone interested in a Custom crossmeber ??(Jimfab/Z10)
- What axles fit EF
- Truck Bedliner Coating up the interior
- negative camber problem
- Wiring Diagram
- Pics of the new lcon x member
- Electrical Load Detector circuit, COde 20, wtf is it
- Problems w/throttle body, broke hose off, and used jbweld.
- Lightened Underdrive pully w/lightened flywheel. Problems?
- Electrical Load Detector circuit, COde 20, wtf is it??? let me know asap
- A little problem with my hasport EB2 swap
- 88-89 VIN Locations
- 91 hb H22A shafts?
- LSvtec...no fuel
- car still isnt working please help
- SPC ball joint camber kits
- CF prject I part2
- rs-r ex mag exhaust
- suspension swap for crx
- ZC SWAP IN CRX DX
- sohc ZC vs. A6...here are the answeres you've always wanted.
- Heater fan wont work? Fuse or blower motor?
- rota slips
- crx w/front mount cold air intake?
- dpfi to mpfi european HELP HELP
- Question on Circit 8 wheels from Rota
- brake question....
- Got water in the spark plug holes, ruined?
- What type of mounts should be used for b-series in an EF?
- TPS help!!!!!!!!!!!!
- What HID Kit ?
- quick help.. distributor problem
- pinging
- Quick help!
- JDM EF2 Civic One Piece Headlight Question
- engine start switch.
- CONFIGURE CD PLAYER
- question about Si tranny's
- wtb.....crx si center caps
- old skool 5zigen exhaust
- Using Stock Mounts On B18A Swap
- Engine Disassembly
- fuel system not pressurizing?
- Engine Swap Info
- ATTN: RsR ExMag Owners....
- Overheating issues
- HELP need d block and tranny in MA
- J1 transmission ?
- 90 civic std air intake work on hatch si??
- D16 head upgrades.
- 90 Civic HB SI (Cdn), A/C question
- Civic Dx interior wiring
- ZC crank = D16A6 crank ?
- D15B2 question
- Need a new ignition.
- Just swapped out motor in the EF. Runability issues. Any EF experts please read.
- Keep the cable, or go Hydro?
- 'euro' console? DA seats?
- please help me find a good deal on koni yellows
- any one know of a speed shop in michigan selling front clips?
- CRX Gauge Cluster
- so...we took the dead D16 apart. Damage pics inside.
- seperating lights???
- Cheap CRX on Ebay
- EF Dash Conversion
- Converting a Stick to an Automatic....
- Can someone help me with this?
- D15B swap 'bogging'
- just got the boxer fields vtec controller
- need help picking a exhaust for crx
- BROKE TIMING BELT on D16A6, IS THERE DAMAGE TO MY VALVES??
- post your 02 setups PWO/PR3 owners!
- zex kit on z6...how safe?
- DA rear disc brakes
- DPFI to D16Z6 Wiring???
- 91 civic hatchback Si engine type
- Well, i got off the head today....:(
- Quick Question, what seats will fit into a 1990 civic hatch?
- 30 degrees advance??
- radius arm denting the tranny case.
- front kit wit large opening for intercooler(crx) anyone know of one?
- **Been away for a while...heres what has happened(long)**
- rain.leak.underdash!!!!!?
- d16y7 swap
- axels zc swap
- Radiator fan
- driverside:postive camber, pass. side:negative camber. Allignment? *searched*
- DA rear disc swap??? bushing?
- clutch cable just broke on me... is there a better replacement than stock?
- b20
- Another ??
- what is this exactly?(hasport wiring)
- What car can I get a pw0 ecu out of?
- where can I buy plug and play harnesses?
- 90 si tranny on a b16?
- Driven's Project Log (everyone else has one)
- quick ?
- valve settings
- EF9 SiR front end conversion on 91 EF 4dr.???
- MPFI swap almost running! except this!
- Need help with 1 gen b16 swap in crx
- rear lip question not the si lip!
- Heres the deal
- custom exhaust job (header back)
- ukdm/euro crx trim options
- Removing oem antenna from 88-91 hatch
- will a 89 tranny work on a 91 engine?
- gsr cluster swappers, is this missing a connector or not?
- Coolant Question???
- shift linkage
- car just died with out any warning signs????????
- ZC HEAD!!!!!!!!!!
- Joinin the EF crowd
- different head than block?
- Lightweight Underdrive Pully, does anyone have one. What do you think?
- air cylinders for CRX?
- rsx dash
- Code7 tps, 16, injector why am i getting this
- What is the difference pr3 & pw0, which is better?
- Skunk2 exhaust...anyone have it yet?
- Dose NOS fuck up ur Eng? and is it worth the $$$?
- Aftermarket Camshaft/Gear?
- FOUND:91 CRX ONLINE MANUAL!
- question, launched the rex
- STD. 90 civic hatchback...B18C1 swap
- 87 Si or 95 LX
- Trying to find a body kit...
- shocks fitment?
- Another EF Lip
- z6/y8 hatch times
- the new CRX
- B16 backfiring and hesitation caused by ignition
- header question.
- 91 civic overheating from the head? but no oil coming out by discruper
- B16A1 Intake gaskets + clutch alignment shaft
- Price for stock pr3 ecu
- Wrapping headers ??
- rear hub replacment
- How well do your hatches stop with passengers?
- universeat seat bracket question
- Did I get a good deal?
- help need 8 pin (cluster)wiring harness for 91 crx
- Top Fuel Spoiler?!?!?!
- went to the track today with my d15b crx
- Mini-me smog
- d16a6 with p29 pistons..
- are lexan windows legal in VA or anywhere for that matter?
- Engine Swap Progress....b18a1
- DOES ANYONE HAVE A WORKING PM5 ECU FOR A 1990 CIVIC DX TO SELL ?????????????
- horse power problems
- 17" on a 91 sedan LX
- installing sir spoiler
- V-TEC
- Pulse Side Injector Wire.
- 5 lug suspension
- car wont stay on(igniton switch????)
- Anyone around that can tell me what weight trans oil I need for my crx
- sanding bondo/contourls of rear quarters.
- Synchros on the Y1 tranny..
- Will an integra master cylinder fit in a CRX ?
- Complete wiring swap??
- anyone!!
- Intake Manifold??
- How do you wire a VAFC2??
- OEM ZC Head Handle 13psi?
- Will new exhaust clear ST rear sway bar?
- d15b vtec
- Worst day of my life my POor REX!!!
- Trial member
- full race (or similar) on b18 in crx pictures?
- What axles do i use in the crx b16 swap with a S1/J1 tranny?
- best b series setup?
- Civic Control Arm n brake knuckle spindle HELP NEEDED
- How to tell a p28 ecu?
