B16a sir crx no spark
Old Aug 5, 2015 | 02:40 PM
Jdm256's Avatar
Default B16a sir crx no spark
Ok so first i started off with a code for a new icm I went ahead and replaced that and that didn't fix it still threw the code after I cleared it, I then checked for spark and got nothing ! So I bought a new rebuilt dizzy and guess what lol, I still have the same icm code and no spark I have obviously messed something up but I sure don't know what. Anyone have any ideas they could throw my way?!
Old Aug 6, 2015 | 02:51 AM
Freemananana's Avatar
Default Re: B16a sir crx no spark
https://honda-tech.com/honda-civic-d...odule-1430824/
That's a decent write up even though the pictures are broken. Check your wiring to the distributor. Is it OBD0 or OBD1? I bet some of your wires going to the distributor are messed up.
Old Aug 6, 2015 | 08:22 AM
Jdm256's Avatar
Yeah you were right, I have spark at the coil pack now but not at the plugs it's OBD0
Old Aug 6, 2015 | 08:48 AM
Jdm256's Avatar
I should add that the black and yellow wire going to dizzy is reading 12v
Old Aug 6, 2015 | 10:03 AM
Are the wires good? Is the distributor cap and rotor good? Those should be the only thing stopping you from getting spark. That OR you have a ground issue. Thermostat ground, transmission ground and valve cover ground should all be present and in working order.
1badcrx
May 1, 2009 08:39 AM
IlsCrx
Mar 28, 2006 05:50 PM
willsEK-HF
Feb 26, 2006 12:53 AM
rnl04
Jun 23, 2005 07:11 PM
aaronhume
25
Mar 22, 2005 08:42 PM
