View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Ef8 foglights
- cool sites to find awesome parts.. jdm etc ^_^
- how to read ecu error?
- Have you ever started your car by turning your headlights on with the key NOT in the ignition ?
- Lowered CRX and axle hits?
- Transmission Question???
- going b18 in my rex
- sir crx ffrom japan.....
- any good shops around in Pensacola, Flo Rida
- Fuel Issue
- d15b vtec originally available in?? Need motor mount help
- What Do I Need to Do a Multi-Port On my CRX... I NEED HELP
- steering column?
- my first build AND I CAN'T EVEN START IT!!!
- SIR engine mounts
- how to wing tilt?
- red hose too big??
- Hatch issues!
- Wheel wobble?
- si wire harness
- EF9 power windows.help?
- halo headlights ?????
- dizzy experts
- 1988 crx fuel filter relocation
- OBD2 Engine Harness in OBD0 chassis how to? info needed.
- WTB: Reading glasses to read the EF forum rules.
- importing from Canada... US model questions
- CRX fan not operating
- Can we make a list of how many MPG of what everyone gets? Including Swaps.
- Air bubbles in my coolant wont stop! 89 civ dx mpfi
- white-ish build-up on the inside door panels
- Seat belts retraction problem
- 91 crx dx
- Just installed a B16 in 88 Si, cant get clutch cable to work? Also throttle cable Q's...
- Shift Linkage And Bushings
- How do I swap 88-91 prelude seats into my 90 Civic Hatch?
- CRX edm angry hood and bumper
- custom exhaust mandrel
- 89 crx si
- need wiring help!! and plubing too
- code 4/6 help!
- Water In Driver Side Floor
- Anyone have the Effin MPFI swap article? The site is down and I need it for tomorrow.
- clutch and brake pedals to the floor
- EF8 FRONT END CONVERSION. HELP?
- No heat/flow from my blower
- Hx wheels
- Gabriel spring/strut combo...any info on 'em?
- ...: Few Head Gasket ?'s :...
- i need help taking my dashboard out HEEEEEEEEEEEEEEEELP
- Help with axle removal
- wagovan rear seats into civic HB?????
- Battery dies in 3-4 days :(
- spc balljoint install
- strut bars
- tranny ??
- Engine selection help...PLEASE
- ut ohhhh
- my car just died on me!!!!! need help quick please
- poor mans type r
- Driver side vent blowing cold air, why?
- Rear defroster crx
- hasport shift linkage problem
- cam shaft
- need help motor swap
- My How To: Swap seats in 88-89 EF
- ebay headers
- Intake manfold gaskets
- important question requarding engine smog...
- valve adjust
- hydro conversion help hasport or innovative
- so i finally got it........
- Just got a new EE4!
- 89 Honda Civic Clutch Disc Fitment Problem
- quick question
- Is this what the CPS for a b16 looks like?
- Auto cluster?
- 88 std hatch w/stock d15b2 m/t 4spd, wondering if i could use 88-91 si or dx transmission
- Tach problem
- Mpfi dohc ZC swap crank fuel spark but no start
- HELP! CAr wont start
- Car wont start
- stretched tire...
- What Lip is this?
- Civic vs. Malabu: your thoughts.
- Help car shuts off.
- side mirror block off plate?!?!?!
- Rear brake lines (disk)
- need help on my 88 std hatch, swap 90 crx si clusters
- tranny problem
- B16a2 swap ?s
- 88 civic dx.
- bumper support
- It's 2008... I think it's time to unveil my K20a CRX build
- Annual Griffith Park EF Meet - Saturday June 14th, 2008 ► ► ► ► ► ►
- 91 DX hatch w/ d16a6, shifter too far forward
- FS/WTB Thread Suggestion
- Fresh ZC no start
- Sometimes it works, sometimes it doesnt.. (themostat thermometer temperature gauge)
- Pic request: CRX with Buddy Club SF/QF rims.
- dexron
- HELP! Before I tear down my motor...
- Testing single wire 02?
- what color is it??????
- crx with b18 or cavi with ecotec
- HAPPY NEW YEAR 2008
- Rear Disc STICKS out and is not straight WHAT IS THE PROBLEM??
- comment
- header
- ZC vacuum line help
- Brake Pressure Issue
- Help with a clutch question
- Crower head swap....
- Type R head
- Lower ball joint rebuild kit?
- Quick Vtec Solinoid question
- wtf part 2
- motor swap. what am i missing or what else do i need to do.
- CRX retrofit door panels
- 2 Step activation question.. MSD
- How to Avoid Being the Ghetto Ricer
- need some info for my civic swap
- Valve adjustment question?
- help ASAP ajusting idle mpfi swap
- Axles remove
- starter solenoid removal problem **searched**
- Lightweight lugs for vx/hx wheels
- Fuel Pump
- skunk2 lowering springs, which ones go in the front and which go in the rear
- help installing etd traction bars
- will a EG/sol mishimoto radiator fit?
- Car not running
- bad mount
- B18 Swapped Head Car Won't Idle
- A few questions about Traction Bars
- fuel gauge stopped working
- swap ASAP help Flywheel & Clutch & press plate
- Good Deal?
- OEM or Mugen RTA bushings?
- RHD CONVERSION STEERING RACK QUESTION???
- QUESTION: 1991 Civic dx ED3 dash cluster cover swap
- anyone know how to covert obd0 to obd1?
- Springs!
- What Brake Master Cylinder Can Be Used On A 90 CRX Si?
- Another exhaust post
- Tire question?
- Flywheel & Clutch
- the debate! worth the jdm price?
- starting problem
- sputter problem
- b16 wire tuck?
- FOG LIGHTD PLEASE HELP!!!!!!!!!!!!!!!!!!!!!
- Distributor Fitment Compatibility? '92 CX to 90 EX?
- Starter question *searched teh web thoroughly*
- Removing Alarm system on 1990 Si. A little help please?
- 4 door mirror door cover fit crx/civic?
- Is my TPS broke?
- 88-89 CRX or 90-91 CRX
- First time rebuild - 90 Civic Dx
- Invidia Exhaust question. CRX with EF9???
- DOHC ZC HEADER?
- antenna installation.
- code 9?
- fuel pump not running
- help removing gutter trim
- code 22 (oil press) check engine light in PR3
- b16a parts list
- EG intake in EF?
- straight pipe exhaust
- whats your harness connected to?
- Slow acceleration.
- oem cd changer placement
- z6 swap ?
- clutch cable issue
- custom civic headlights , single bulb + da style fog light
- surging idle between 800 and 1200 rpm
- Mendrel bent exhaust question
- What injectors will fit in a ZC motor??
- electronic temp gauge
- some one with a d16a6 help me real quick
- Bitch Pin
- wilwood brakes
- Skinned CRX Sunroof?
- camber kits?
- k swap in a crx
- precision 1000 question
- advance timing
- Alternator~HELP!
- WHERE DOES THIS HOSE GO TO??
- fog lights on a crx
- crx si car harness question
- canister next to fuel filter
- A few wiring ?'s
- motor mising
- Fuel problem
- help-b16a in 91 lx "coolent hoses" ???
- HELP.....B18a1 swap won't start!! Need to go to work!!!
- brake pads
- ef9 sir back lip question
- Thermoswitch?
- spoilers
- si lip....maybe
- EF8 bumper support,US 90-91
- pic
- zc vtec mini?!?!
- Car doesn't turn over - makes buzzing sound
- check engine light
- New rotor and still a brake shake @ high MPHs 40+!?
- Wiring difference between a 89 hatch and 90 hatch?
- something interesting......subframe brace on crx
- what tranny to use...
- EK-EF rear disc brake line compatability
- Need help! OBD 0 no fuel pulse.
- Need help with mystery part!!
- where can i find replacment gears for a y1 lsd tranny??
- Pic Request: Perfectly straight radius rods...
- turn signal problem need wiring help
- heater problem
- 91 Hatch, still running rich after motor/MPFI swap
- wiring DX for power windows and locks
- A6 wagon block
- ls block help !!!!!
- I Need Opinions: LS Hatch VS B20 Swap
- crx harness help
- Brakes, Heads, Bars, Questions
- wtb Front Upper Shock Mounts for 1991 Ef Hatch
- !!!!built ls/vtec ef build!!!
- constant cel light
- how can i install 1996-1998 CIVIC EK OEM style YELLOW Fog Lights on my ef??
- Oil Pan Removal
- JUST RELEASED: 88-91 Innovative D SERIES HYDRO TRANNY MOUNT KIT
- flywheel question
- itr header question
- Some One want to help my Friend
- axle clip(circlip)
- Battery Light Problem?
- brake upgrade
- won't EF'ing start!
- Windshield molding
- del sol suspension on ed6
- 89 CRX With 90-91 doors?
- whats your muffler
- h3 light bulb
- 1990 Civic EX Runability Issue
- .:BullBar:.
- Can turn signals be made into fog lights
- 90 CRX
- battery help
- redline question???
- e-brake light on all the time
