View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Dim EG/EK parking pole light
- dpfi restrictor plate removal
- DA injectors VS CRX si injectors
- ECU codes for ZC(PM7)
- D15B2 with pm9 ecu
- F22B..??
- Where to buy stock replacement front shocks/springs
- Is it possible to keep AC and PS in my B-series Wagon?
- cluster question
- fog light fitment
- crx main relay location?
- ECU ground got too hot, melted plastic, power went VERY low (pics)
- WTB: EF DPFI -> MPFI HARNESS
- starting problem on my gsr
- Verry Confusing Starting Problem !!
- do you know?
- CRX si harness question
- quick injector question
- EF hatch stalling and jumpy throttle
- symptoms of bad iac?
- Ignition problems
- EF Hatch B16A swap problems...need help please
- full 90-91 Civic Si front bumper w/Si Lip
- 95 ls into ef wiring?
- New rex
- 1991 crx problemmm
- crx gas smell problem
- 1990 Ef hatch
- Fuel Pump Problem
- Trading my 89 si for a 03 Subaru Impreza??
- D16a6 to d16y7 swap
- head change
- help me get my pr3 ecu out of limp mode
- 88 si to 91 si
- Old but new rust repair
- Help! jdm fog light switch wiring
- 90 ef hatch w/ls swap questions
- Carbon fiber vinyl wrapped 89 civic si?
- Spark plug stuck so I have a BIG questions (gaping)
- exhaust question
- NICE CRX turning to project.
- vacuum question (not line location..)
- 91 civic dx d16z6 swap fuel pump wont stop priming
- Newb kinda but need some help with D-series hydro trans in my EF
- 91 std not starting
- 88SI to 89HF
- piping cracked
- Anyone know how to mount this lip?
- CRX died No lights, no crank, no power
- Oxygen Sensor burned in two weeks??
- Civic wont start :'(
- Springs needed
- 88 CRX Bumper On Ef W/out CRX Fenders?
- tps removal
- si sputter-stumble
- Z6 with 89 std tranny?
- Steering wheel center
- Transmission to Motor Mounting Bolt Order
- McGrubers all out crx track build
- Cr-x. Hard pulling to the right
- Bumper Identification?
- very weird problem
- mini build help...
- Fuel Gauge Help
- Worth the EFforts
- Help!! crx tranny
- Tps Problem?
- EF lip... help!
- b16 timing
- 89 CRX wont start...
- 89 ef std build
- I Need a Site for parts for a 1988 EF Coupe
- abandod Hatch
- Diy: Re-sealing interior vents to Heater blower motor(Ef,Eg etc)
- 91 civic type-s
- HELP! 88 CRX HF, Tack on Crack, gauge or sensor or electrical issues???
- engine swap wiring
- link to the ef honda access parts thread?
- Exhaust in car. Can't find fix
- Front Springs
- dpfi to mpfi code 4
- Need feedback on this chassis part list for fully built rally/drag/track CRX
- Mini-me swap problems
- Installing 11.1" ITR front and 10.3" DelsloVTEC rear brakes on CRX?
- how does the rear edge of the lid of the storage box attach to the body ??
- how can i strengthen lid of storage compartment so people can sit on it ?
- headlights dimmed a couple times last night, that sign of something going bad ?
- ideas how to keep top cargo cover piece from popping out of place ?
- All-Motor B16 or Turbo D16 VTEC?
- OBD1 conversion done, ecu fuse blows :/
- Engine harness help
- dpfi to mpfi code 10 wont crank
- F20b swap in my Si
- bumper light help
- Help me find those rare CRX chassis unibody stiffeners plz!
- crx help :(
- Loose wires hanging around
- looking for CRX parts "CANADA"
- d16a1 swap into 91 dx hatch questions
- New in town
- crx fog light
- Key doesnt fit but the car will start with it half way in or with a screw driver
- CRX HF didn't have a rear swaybar, how do I install one?
- CRX question
- extreme rough idle below 3000k
- 88 Sedan DX signal lights not working
- shaky steering wheel
- ef b18b swap mount bolts
- Battery dont hold charge
- 90 crx si with b18a1exhaust question
- b16 wont move forwards
- strut/UCA brace
- d16 16valve
- 90 Civic Lx, starts then stall
- d16a6 head swap question
- crx fog lights!?
- 91 Si Hatch Clock In 91 Dx?
- crx ls swap cel 13 help?
- Will a 1989 hf chassis harness fit in a 1989 dx
- can someone tell me were this goes? :c
- Throttle cable problem
- Air Vent problem?
- B16 VERY High Idle???
- Stolen 90 ef 4dr In Kent WA
- best b20 swap?
- head milled question
- 88 sedan almost caught fire. Short in the harness
- D15B7 obd1 dizzy onto D15B2 obd0
- CRX 88-91 dash differences
- ef hatch civic problems
- 0bd0-0bd1
- Engine swap questions?
- thr roller rockers
- 88 wagon,driving this morning at 100 mph,car was lost power, like fuel cut???
- crx stilll not starting
- crx ls swapped cel 7
- does anyone know the stock spring rate on a 91 civic wagon 4wd?
- Khaki CRX from Az
- HOLD UP WAIT A MIN!!!
- quietting my car
- Found Custom Fit EF Floormats but can't find any feedback on them!
- LS/VTEC project questions
- How to repair destroyed hatch strut threads?
- FULLY BUILT CRX chassis parts list.. what am I missing (excluding engine-related)
- Weight Reduction Question (and manual/power steering rack difference)
- Motor swap clearances?
- Eratic Heat in 89 si , 10 bucks to who can figure it out
- tranny replacement
- 89 CRX dx idle/reving issues
- My DPFI --> MPFI writeup
- chirping noise during cold mornings
- S1 tranny, can i use a VSS insted of the cable speedo?
- Replacing oxygen sensor
- 90 cluster in 89 ef
- Correct? Clutch, pp, flywheel? D16Y8 in HF
- At a loss! PLEASE HELP!!!
- 90 si ef with ls
- b16a
- b18a1 heat
- NEED TO KNOW WHAT SPOILER THIS IS, ANY HELP?
- D16a6 to D16a1 or Twin Cam Zc
- Drabilaty tuning pgfi d151b
- blower motor problem
- honda motors
- Are all D15 blocks the same?
- ls swap in 90 si hatchback igition output signal code
- suspension?
- rear disk swap.
- I want my D15B6 to look and drive sparkling new, what to do...
- B&M Shifter Question
- which rates are best for daily drive on the 91 wagon?
- did some searching and just need some clearifying
- My Lil CRX build + others
- help tailights or dash wont light up
- Just a simple question
- storing CRX gas tank for a few months
- Car stars then dies
- looking engine harness pinout
- Bumper and lip identification
- 90 Hatch Oval Race Car
- distributor question
- dont get mad at me
- researched problem with cluster back light and dashboard lights
- not sure if main relay or fuel pump
- civic ef 90 need some help
- How To: EG steering wheel installed into EF Hatchback
- crank angle sensor
- jdm part question
- car keep dying please help !
- door question
- Please help! Purge Solenoid Problem
- [Nicolay45] CRX DailyDrive Project
- fixmyrust?
- pedal bracket broke today, need sum info
- I need some help
- Idle Issues
- Code 16 put me out of the game....HELP
- Help! B16 Miss fire @ VTEC!
- Timing/Ignition issues?
- MPFI conversion question
- NRG seats, sliders or no sliders, which bracket fits best
- 91 crx cel 16 consecutive blinks
- CRX project, glass sunroof. Will be attemping. Slow project.
- THIS REALLY PISSED ME OFF
- New to Honda's and this site
- Possible purchase: '90 CRX Si
- what top hats will work for my F&F TYPE 1S
- icm diagram?
- 88 ef hatch build
- My ZC has no fire to the coil
- d16a6/z6 mini me distributor question.
- How to find tdc to get block and head mated right
- help my head is fried :(
- Hatchback and Wagovan dash harness the same???
- Electrical Issue
- Walbro blows fuse 14
- 91 Civic Hatch STD - ELD
- 91 honda crx hf body parts...front fenders, rear quarter panels...etc. helppp?
- Civic just quit running...
- Can I make my EF Hatch AWD?
- HELP! Hasport h22 Crx axles combination???
- 90 dx hatch raer disc brake conversion..
- CRX PROBLEM :(
- crx si what is that solenod lookin thing
- Fuel pump replacement question
- fresh z6 not starting
- 1990 Civic SI stalling problem
- swap advice?
- Need help. Redoing some wiring
- My CRX; Where it's been and where its going.
- crx b swap smoking white
- 88 crx wanting to do moter swap
- Head gasket removal. Need help.
- Itroduction
- Steering Wheel Slipping???
- 91 Crx Si Build
- D15b1 Swap from a D15b7 into a 1991 CRX HF
- 90' dx Won't start
- CRX rear control arm bushings
- Auto to manual now little problems?
- Another D vs B question.
- Oil consumption on d16a6.
- 1988 honda civic lx running poorly help!
- Another CRX gone (hit and run)
- Grinding gears.. (Every gear over 2500RPMs)
- Different doors on an 89 CRX Si?
- Newbie from Ireland - ef9
- b16 vacuum lines, 91 hatch & heater hose ?s
- 1991 Civic Si Brake Booster
- can d16z6 aftermarket parts fit on a d15b swapped crx searched
