View Full Version : Honda CRX / EF Civic (1988 - 1991)
- ys1 speedo wiring?
- honing
- Car is running way rich and very sluggish
- mpfi swap problem
- 92 GSR YS1 Transmission clutch options?.
- fuel injector question
- B16a Vs. H22
- good exhaust for sedan
- charge light never comes on
- Parts List....
- honda noob <=
- NO CRANKIN
- GSR injectors
- DOHC ZC help
- Tail light wiring...... What harness will work?
- i need help with my ecu
- new suspension set up with PROBLEMS
- 90 crx hood emblem
- Shifter linkage 88 and 91
- 89 Civic cranks but wont start
- I can't find it!!!!
- What is the length of a stock catalytic converter?
- Fiberglass Sunroof Plug
- intake gasket
- questionaire??? zc tranny
- VSS ISSUES ATTENTION ALL B-SERIES SWAPS!!!!!!!
- Where can you purchase poly/rubber to use for motor mounts????
- PIAA
- EF/EE Mesh wheels? EE Wagon mesh?
- help!!! my alternator belt jumped ship!!!!
- HONDA INTERIOR REPRODUCTION PARTS
- i have a 91 crx with a 92 integra engine b18a1 swap question
- Negative camber/Integra Brake Mod
- The History/Timeline of my CRX Si. 56k don't even try. Theres 70 pics!
- Check out my '88!
- use OBD1 or OBD2?
- ef project almost done
- 91 crx SI part out. BEAUTIFUL SHAPE I REPEATE BEAUTIFUL!!!!!!!!!!!!!!!!!!!!
- What controls fuel on start up (too much fuel on startup)???
- Who knows the answer to this wiring question?
- bad fuel pump?(searched)
- CV boot tore - Need some help with identifying parts
- help please!
- crank positioning sensor
- Need Instructions to putting in a intagra JDM ZC engine in my 1989 honda civic
- Electrical bug.
- fuel rail problem!! need help!!!
- Brake problem
- My RT4wd wagon
- rear seat in a crx
- removable top CRX conversion
- Help with my CRX?! (oil pressure problems)
- Replacement injectors
- s1 transmission question.
- 88 crx si front seats
- B16 which air intake will fit?
- Dont let some one like this screw you over...
- header question
- headlight adjustment
- Wideband 02
- auto tranny problem. please help
- check light problems:
- this is bull
- Wont start, Code 20
- d16z6 w/zc pistons i have, but is that safe to supercharge?
- front lights not working
- tranny squeel
- Sup HT! Need to be pointed in the right direction for Suspension set up
- vtec controller off = no vtec
- Lower Ball Joint; no circlip - DA integra brake swap
- D to B series exhaust adapter
- Questions about gas mileage and my 89 civc dx hatch
- I need help PLEASE
- Newbie to EF's
- heater not working need help
- d16 numbers
- EVERYONE READ THE RULES
- READ THE RULES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!! PLEASE READ THE
- 89 si hatch
- d16 question
- CRX FRONT END SWAP on civic photos
- 88 si crx code #43 ??????
- looking to do a mini me swap in my 89 boosted ef hatch, which head is better z6 or y8??
- blinkers
- 89 Civic Si Hatch Sunroof Sun Guard Replacement
- Will rear interior plastics from an 88 civic fit an 88 Crx????
- Another JDM cluster question (Searched hard)
- o2 Sensor help please
- b16a cam question...
- time to beef up the outside of my car or get a new car
- **3 B-series * 2 DX Chassis * 1 Garage** Let The Builds Begin!
- i got a few questions about a zc motor
- lots of questions lol.
- New here
- vibration when accelerating through steering wheel and gas pedal
- crx tranny question??
- overheating and odd idle
- what cat will be good to put on my ef gsr hatch
- 92-95 EG Calipers on a crx ?
- 4-1 header question
- D16 15 gear ratios
- the rsx guys have it
- I'm buying eBay patch panels for hatch. This should end ALL questions on how to!
- The 2007 Florida CRX Meet is still on!!!
- CRX Exhaust
- a/c with swap
- b20 swap Q's
- vss question (searched)
- Help with Greddy Oil Adapter Kit!!
- a6 flywheel
- CRX B16 alternator belt oem part number????
- new blood to the EF scene
- Emissions with p08 Ecu.
- DOHC ZC what starter needed
- ::: Please keep an eye out for this bad boy... ::: Stolen crx!
- Lighten 90 crx doors?
- HeY I'M NEW HERE, QUICK QUESTION
- brake light circuit/horn, burnt up, help please.
- Project NASA/ classic fun-91 DX LIFE PROJECT!
- Finally fixed this promblem!!!...b16 voodoo RPM and bogging...small write up.
- hood wont close after swap
- b16 starter (searched)
- Innovative mounts crossmember and EG radiator question
- Do people introduce themselves on here?
- another engine light question
- how much you think a front hub will cost?
- wich conversion harness
- losing oil pressure on new build
- "exhaust to load"
- ALright CRX owners, gimme some help!
- v-tec controller?
- Calipers
- NEED A DRIVER SIDE QUARTER WINDOW....
- Which connector to jump for timing???
- d16 pistons fit b16
- skunk 2 cam gear ???
- Can u retrofit 2005 civic door lock and ignition cylinders?
- gage cluster 91 to 88
- omnipower
- Door Locks on CRX
- IACV screw
- gauge cluster lighting problems
- brake issue... need a little help
- crx seat brackets, cheap carbon fiber hood
- springs from da into ef
- Can i use EG and EK Struts on my EF????
- What seats bolt on to a 1991 HF?
- brake light
- jdm crx headlight wiring
- D15 STARTER in B16a SIR?
- no start after d16a6 swap
- Oxygen Sensor #2????
- PLEASE HELP!! problems b16 and whole car!!
- No fan after B16 swap
- D15 and D16 differences????
- 1988 si
- Need CRX radiator dimensions
- b18a1 in a 91 si
- SOHC ZC Swap
- help with report
- need help...
- Acura transmission interchangeability question
- seat belt light problem!!!
- 88 crx si help
- please help
- Hiding Clutch cable?
- What coilover sleeves do I have?
- My 95mm stroker build almost running
- zc dual cam
- A couple of conversion questions
- rear lip for crx?
- What's Wrong (video included)
- head light bulbs
- will eg front suspension work on ef?
- looking for acura center caps
- Whats this worth ? crx related
- Vacuum line with aem intake
- i have a question...help me please.
- Del sol radiator?
- bringing back form the rice land
- b16 wont start when its cold. Xsi swap.
- smog time on the obd1 89 sedan airbox question
- Weird A/C Problem?
- d15b block, d16y8 head, 91 dx hatch mini-me
- H2B in ef8
- Valve Problem?
- Code 17 VSS?
- 1991 Civic - Engine Smells Hot, Fluids All Normal
- 89 4 door project
- vtec
- carbon hatch and glass for 91 civic si
- Mod Question
- Mini-me swap question
- pics of my crx and anybody else who wants to post theres
- B18B1 into a 89 Si need help
- gsr in 91 crx
- Revisiting the problem... (blown engine?)
- Brakes
- Half Shaft
- timing question.
- New Pistons, Rings and Connecting Rods
- crome ecu in b16 crx
- swaping obd0 harness to obd1 has anybody tryed it???
- Bouncing Tachometer needle
- rust repair question...
- ebay wanna be spoon side mirrors help
- Another Turbo CRX hits the streets...
- steering wheel options for a ef hatch?
- vtec-e
- altenator?
- D15 will not start
- PLEASE READ THE RULES
- gsr shifter
- alternator/battery problem
- What Does this Code Mean?
- clutch questions
- Bent clutch level?
- Noisy Transmission after clutch install?
- Install A/C in a non A/C crx?
- Electric Problem: Short or fuse problem?
- ls questions
- Oil Presure Questions
- does MSD make th alt not charge at 14 volts?
- fuel pump removal
- MY OBD1 dizzy went bad...TRYING TO convert OBD1 connectors on OBD2 dizzy...HELP?
- pressure plate
- wont start
- 90/91 Si transmission + 89 Flywheel, PP, Clutch?
- Valve Replacement
- shift linkage bushing kits, any suggestions????
- oil pan?
- dsm injectors plugs
- throttle problem?
- swap the motor
- z6 motor with ZC trans, ZC intermediate issue
- suspension setup
- master Cyclinders
- car is jerking like a motormount is broken but its not...
- D-Tranny test
- rear discs on a Civic Wagon
- Best Suspension?? Details Inside
- which model is best
- what starter to use on b16a 88 crx
- zc question
- Anyone using 92+ Blue Shocks in EFs?
- firewall gromets
- Where can I find a header for my B16 CRX that has 2 02 bungs on the runners?
- Oil pans . .
- white smoke
- Still confused about B18B1 swap
