View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Who is going to NOPI 2002 plz post here (it can be a H-T meet too)
- 93 ex into a 91 civic/??????
- itr lsd in s1 tranny?
- I searched but no answer
- another quick question about flywheel compatibility
- CRX and EF civic mounts....are they interchangeable???
- Central Ohio EF Meet On Aug 20
- quick question about intake manifold compatibility
- I need help...CEL came on
- Anyone in here bought an adapter harness from LELOPEZ??
- ECU wiring Q.
- Rollbar Preference Kirk or Autopower.
- im confused.
- best place to get motor mount inserts?
- diy turbo
- f/s z6 intake:y8 throttle body!!!
- lowering spring question
- Front Brake swap...integra to 89 CRX Si
- CarSound or PowerCore
- Help wit Camber kits for 4th Gen Civic Hb......
- car starts slow...why?
- UnderDrive Crank Pulley
- Will 02 RSX steering wheel fit CRX ?
- CRX lug pattern?
- Okay, a couple things I want to get straight
- D16z6 worth it?
- ECU chips....?
- crap CEL's again
- Another DAMN clutch problem....this time Its like I dont even have a cluth hooked up to my pedal....
- How to put 88-89 projector headlights into my 90 hb?????
- removing the a/c compressor
- What's it gonna take to convert MPFI?
- Carpet
- Plans for NOPI September 20, 21 & 22 (Part 2)
- SOHC ZC Questions...
- This sound like a sticky thermostat
- D16A1 into '87 CRX Si - wiring help needed
- b16 CRX worth ...
- help with seat mounting
- Pic needed of ST Rear swaybar (endlinks)
- anyone have ENKEI RPO1 on their hatch?
- motor swapin????
- Head Gasket blew! ARGHH!
- tranny ????
- sport mirrors
- how to tell a1 & zc cams apart?
- 94+ Teg seats in a 1990 Civic Si
- where in the hell do i get alignment?
- D15 MPFI Conversion
- Anyone with CRX mechanical experience, please help!
- new name old person..questions
- where to find best price on APEXi VTEC-AVC
- EF Si guage cluster plug-in any EF DX???
- Need help ASAP with b16!
- ef and lots of ef parts for sale.
- Need your help guys!!
- need pointers w/ B20 swap...
- where to buy hcp mounts
- ZC Aftermarket?
- My main PGM-FI relay went out! =(
- whistle at low RPM from Intake
- Help! I broke a wheel stud, how do I replace it???
- Damned A/c!!
- Help 91 HB with ls with stock civic ac compressser
- What do i need for a zc tranny in a si?
- User question (Sorry can't seem to post in the member's forum)
- zc guys?
- i post this in the hybrid forum.i thought i'd post this in here too.
- d15b8 fit in 90 crx si with si head?
- Need Help!! - SI Complete Swap into 89 STD?
- HELP!! Coolant Leaking Like no Tommorow!!!
- Si, ZC, or Ls injectors??
- How have you taken the tar out of your CRX?
- Anyone know where I can find a cheap battery tie down?
- TECH: How do i tell if a used clutch is in good condition?
- whats up with my short shifter ?
- what is the highest octan i can run in a 86 crx si stock sep for air intake and exhust with out blow
- si engines
- will this bolt up?
- rear lights
- What clutch should i use with my zc
- First time buyer
- Another question on the Z6, this one more simple, hah
- HELP like right this minute
- Pics of my EF9
- ? coilovers
- More on the b16 hesitation issues...
- best way to cool down the mini me swaps
- Gauge Installation
- Si into Hf swap help needed....
- d16a6 for sale
- combo exhaust
- My newest toy!...
- Lopey idle
- i heard tokicos blow out easy
- need part # or source for ZC cam sensor (CPK?)
- SOHC vtec head
- anyone running the d15b 130hp sohc vtec?
- 88 CRX Si swap---OBD Questions
- b18 TB on d16
- zc/a1 pistons
- Best place to get an HKS catback for a 89 CRX Si?
- Axle problem.. boot torn after 1 month.
- pics of my home made 3" exhaust
- exhaust question, i know its been asked many times.
- need good help fast!
- Another Turbo DX added to the website Homemadeturbo.com!
- I Need More Room!!!
- driveability problem
- A quick CAI question
- what dose long block mean?
- What do you think about it all? (everyone read)
- quit locking the dam threads!!!!!
- Ive almost got my problem fixed..but need your guys help..
- Anyone know a site where they give instructions on how to install coilovers and struts????
- When using LS spindles (on 90 STD Hatch), could u still use same rotors and calipers??? Please HELP
- Wiring for 89 Gauges.....
- CRX door panels?
- Redline
- need help! ls in 90 si wont start.
- 96-00 civic springs fit in 89 civic hb?
- Quick question about 89 DX
- someone help me with my dilema
- Strut Bars
- car jumps between 2k and 5k in all gears? wtf??
- D16z6 vs. D16a6
- B16a swap question?
- what engine is in the special edition 88 prelude? will it fit
- turbo 88 dx?
- Best place to buy parts???
- ignition
- 88 Prelude Rear Disc work on 89 CRX Si???????
- HB civic Question
- Does anyone know the torque specs for a 91 CRX Si engine?
- Fuel Pump Woes...
- I think I'm done
- Anybody have a......
- Pics of my sleeper
- cluster w/tach into 89 std
- My EF won't start please help!!!!!
- first time drivin an EF
- starter relay ..where is it????
- spring install?
- i need some info on a turbo/crx with AC....
- possible purchase, advice needed
- What the hell kinda plugs didnt Honda put in my car!
- FS:1989 honda CRX SI
- CRX Conv
- car wont start, already tried searching
- looking for 5 lug conversion for '00 Si
- How do you guys remove you CRX from the back middle section of your tailights.??????
- Swap into 91 Rex......
- Gettin ready to change fuel filter...anyone wanna give tips ? advice ?
- Carfax help
- 91 CRX with LS swap..... Need Fuel pump???
- Getting motor next week, what to look for
- Carbon fiber hood and fenders
- how do i adjust the valves?
- what will this strut bar fit?
- Sprint Suspension URL?
- smoke coming out of exhaust.
- ZC powered EG hatch???
- what will i run if i try it?
- whats it cost to fix an over spun rod?
- I want white bumpers, my 90 Dx needs white bumpers.
- 89 CIVIC DX 243k miles - Passed Smog with Flying Colors !!
- i need help please
- integra type R lower control arms
- whats the best motor for a CRX?
- Hybrid Question
- anyone please helpppppppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- car pics
- Why is my motor running lean and missing ??
- Debating selling Hybrid CRX, what is she worth?
- Got my piping!
- how to find a bad ground????
- Intake Question
- Please list some 1st Generation CRX Performance Sites ASAP!
- z6 Distributer w/ 91 si Ecu?
- sell crx
- a/c compressor
- acura integra center console
- VAFC into 91 CRX SI--RPM, throttle signal, VTM wires??
- Instrumrnt cluster with a tach, Which ones work?
- CRX AC Components and Evaporator location
- need info on JDM EF9 cluster... nothing in search????
- Is my brake booster bad??
- how the hell do you remove a b16a primary o2 sensor?
- Anyone close to Nashville,TN?
- catalytic converter??
- Question on my 'Teg Seats
- GSR Shift Knob
- New Project
- wheel stud size?
- I need opinions... Cams and turbo...
- Idle, reving, shitty z6, need help..
- Attn:European Rexers I need some help......
- racing seats in a CRX??? need some help...
- Idle issues-b16; o2 sensor Q
- Neeed help right now
- short shifter
- what the heck is the problem? CEL woes
- b16a stuttering
- Hondata ?
- pulling motor-where to attach chain?
- ZC: which dist. and crank angle sensor fit?
- what JDM parts for a 89 Sedan?
- Tenzo R exhaust
- Opinion on HKS Super Form
- Car troubles! Smokin'! :(
- Lowering advice please...
- Massive play in the brake...help me
- E brake light
- ZC throwing codes
- I think I hurt my car.. please help
- Itr lsd??
- crx/ef civic
- Ok this is really off topic but...
- best settings for kyb agx
- Spark Plugs for B16a!
- For those with an S1 transmission
- fuel hose
- sir conversion
- zc sir
- serious zc guys....need help!
- 1st drive with my project car
- J-OEM hatch question
- will the GSR CAI work and fit in my EF if i move the battery to the back?
- d16Z6 Won't start?? Help im stupid
- neuspeed strut tower bar compatibility
- 90 crx manual rack fit an 89 crx?
- bilsteins for 4gen?
- removing speedo sender?
- Best exhaust?
- ouch
- Installing short shifter...
- VTEC Problems
- allen key stripped on my ground controls....can't adjust the ride height
- Question about full D16Z6 swap v. D16Z6 head mini-me
- Check out what I just scored on ebay!
- reviews of Pivot auto shift lamp
- I need another b16 a part(Thortle body gasket) where ?
- 2ng Gen ZC wiring help!
- Stock fuel pump for use with a zc?
- zc swap into hf
- skunk2 IM on 1st gen b16 qestions
- exospeed cam?
- will this setup work?
- Preferred 4g b series mount install sequence
- Who lives in the 626 area CALI?
