View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Integra tie rod ends
- cluster help
- RULES RULES WE ALL LOVE RULES
- LETS ALL READ THE RULES TOGETHER SEVERAL TIMES
- failed NOx , please help
- TPS Positioning
- IAuto to manual + Engine swap?
- Obd0 vs obd1 and 2 knock sensors
- H22 into 91 civic
- ef swap wireing help with d16y7/y8 mini me
- MAin relays all the same?
- B series into CRX Help!
- **wiring harnes ????
- Operating Temp?
- C-clips on Drum Brake Shoes
- Help with my car
- Help with ef8 Climate control
- POLYURETHANE OR RUBBER BUSHINGS
- b20b?
- ******STOLEN: 90 CIVIC Si- Red w/grey interior- STOCKTON, CA.******
- Stripped flywheel bolt!!!!!!
- value or cost of crx w/ bard or legal ls swap
- Basic Engine Rebuild...
- Clutch and Flywheel setups what do you recommend?
- del sol dash in a crx?
- CRx wont start NEED HELP PLEASE!!?!?
- swap help!!! please
- 1991 Honda CRX Si Manual Trans
- bumper question
- Tenzo R seats in EF
- DA knuckles and stock sohc axles ???
- Hf transmission into Si swap questions…
- EF AUTO TRANS FLUID?????
- 200 hp civic , ok i guess
- new honda owner
- Fuel spraying out of fuel rail!
- HOW DO U TAKE OFF THE BACK SEATS OFF A EF HATCH ? HELP ! ! !
- Where can I buy a rear spindle?
- H22
- single cam swap
- How low should i go?
- transmission questions (differential/oil/bearing)
- K20 roll call Axle related
- bout to get a rhd 89 hatch
- B16 tranny to h22 motor ???
- Skinnies on a 89 si
- clutch and flyweel
- suspension
- ef9 jdm spoiler HELP!
- is this a good deal?
- catch can install?
- holes in the bumper??
- weight of oil
- Transmission Install Help
- New ZC up and running... Pics later today
- What is this on my distributor cap?
- sedan bumpers and moldings
- ef9 front clip on a ef8
- 90 CRX cranks but wont start
- 91 CRX hard to start, sputters below 3000rpm
- password jdm
- Need Help. New to H.T. Blue smoke from exhaust and knocking in motor
- brake question
- d15/16?
- Troubleshoot
- 89 Civic Si...need some feedback help.
- wheres my ECU?
- ef8 front end help.
- How much for a CRX OEM front swaybar?
- 91 civic si transmission swap
- Need HAP part number
- K20 ?
- 88 crx si - first time buyer
- ecu pins b10 and b12
- Looking for a suitable clutch for b16a and b20VTEC
- DPFI to MPFI almost done, throttle cable & fuel line q's
- Need to read the rules!!!!
- Brake cable for rear disc conversion Sedan
- dx/std conversion??
- Swapping in a d15
- idle problem/map sensor hook up
- EF9 Round Fog Lights
- Is this a good price for a hatch?
- Easiest way to replace clutch
- Where to get shift linkage for sohc zc?
- coilover lowering problems help!
- Electric Load Detector
- all ready but?
- trans bearing problem
- CRX Swap question
- B16A SWAP INTO A CRX. WHAT HEADERS TO USE
- Power windows for Crx
- sputtering y8 crx
- CRX Fuel Problems
- putting a b18b1 into my crx with a cable tranny what clutch to use?
- 3k rev limiter
- fuse power
- Starter won't crank, Remote Wire only has 3 volts
- Informations for the European Freaks!
- 88 crx grinding and won't go in gear sometimes... any ideas what the problem is?
- 88-89 bumper WITH RULES!!!!
- removing tranny got a question >>>
- EF sedan in da making
- suspension
- best stickers ( custom made and not ) ex
- 90 ex dome light and center clock( car wont start)
- Blue Clock
- which distributor fits in?
- Installing a 255 walbro pump?
- dpfi->mpfi codes 4 and 9
- Mystery Wire Coming out of Engine!?
- cable conversion to hydraulic
- Which do you like better?
- GSR cluster in EF: Speedometer not working?
- d15b2 intake mani gasket
- Car only runs on VERY HIGH fuel pressure
- side markers help
- STOLEN HATCH in rancho cucamonga f**K THIEVES
- Oil starvation!
- Need to hook up my horn, have aftermarket wheel.
- smog for dualZC
- 1991 Civic, Code 14 IACV, Hesitation from idle to 3000rpm, I'm stumped.
- im pretty sure its a coolant sensor..
- 89 honda civic si hatch check engine light
- Moving part contact noise
- clock display
- Shock/strut suggestion for my set up?
- how thick is too thick for trans fluid?
- '91 sedan ex -- it's a project all-around!
- Sunroof
- rusty crx
- ZC swap, no start??
- fresh paint; on the inside
- Clutch & Flywheel Kits
- CRX / hatch front strut bars the same?
- Need Help With Seat Brackets!
- 88 CRX Won't turn over.
- 91 civic b18b1 cam mount problem
- gsr gauge swap in a 90 crx si
- I Need Help With My Swap into my 91 EF
- Anoying ignition problem please help
- EF Sedan- Are there any known problems with water leakage into the cabin?
- no power
- dohc zc
- 89 Si Distributor Replacement
- Shift Linkage Problem
- Lifetime Warranty on Seatbelt Rectractors IF and ONLY IF...
- need help
- HELP! Broken Clutch Pedal Bracket??
- Vague steering, little road feel w/ manual rack
- Ticking On the far right side!
- Myth or Fact? Lifetime warranty on seatbelts
- B16 lower power problem
- 1991 Civic DX - Cigarette lighter question
- temp
- oem..i need.
- Anyone have the HOW TO INSTALL A JDM EF8/9 SiR (88-91 Civic/CR-X) GAUGE CLUSTER Information taken
- shorten integra linkage
- Need help on engine swap upgrade
- OEM door panel patches and Civic and Crx door panel logo's anyone interested?
- heater diagram
- Tanabe Super hyper exhaust
- front bumper turn signals
- Mog's 1990 Black CRX Si
- car all of sudden won't start (searched)
- springs?
- Fuel tank swap... im SCREWED!!
- 88 SI REX,,,OBD1 GSR.? what do i need to re-pin?? DIY's?
- Does zc Head Bolt up To d16a6 block?
- what clutch kit do i use?
- Direct Swap?
- i need a answer to obd conversion?
- Wiring question...Need some help!
- B16 XSI Diagram
- b16a
- 89 crx with lot o problems
- Rear Disc Conversion
- EF automatic install help
- *b16 small build* questions
- going to do a swap but
- DOHC ZC IDLE ISSUE!!!
- power steering?
- Pic Request: Light blue hatch/crx
- Swaping Gauge clusters (Gauge w/out tach->Gauge w/ tach)
- crx b18 starter problem??
- Windshields for 88-89 and 90-91 ?
- 91 civic hactback d15b2
- b16a in crx....
- engine spec help
- Powerflex bushrings???
- im trying to bring back the old school import days please read. (Car Meet)
- lowest coilovers available?
- 91 hatch, interesting problem... HELP! ASAP
- 91 Civic Speedo - Speed Sensor
- Brake pedal goes all the way down, no resevoir fluid leak, no apperant line leaks???
- 91 crx si b16a swap help
- Will a 96-98 D16Y7 AEM cam gear work ON a 88-91 D16A6
- will crx si wheels fit on da integra brakes
- Blinkers stopped working.
- Wire harness question
- dizzy question again.
- SI Tranny in a D15B2?
- VAFC OBD 0?? possible?
- Clutch in to start?? need help
- clearance issues w/ anr header and traction bar *(radius rods)
- woodruff key for adjustible cam gear
- 89 honda civic si speedometer not working
- crx and civic cluster are they the same?
- spark plug wires
- crazy CEL
- My build thread(I want one too)
- Poor Gas Mileage CRX Si
- i need some opinions
- rear disc question
- Unknown Relay
- Surgeing around 1200 rpm's
- car wont start!! help!!
- How well does a stock crx hf tranny hold up?
- Up and running again, no more rattling
- Z6????
- crx or civic hatch hood?
- code 20(dx&ex interchangable)?
- dpfi to mpfi fuel pump problem
- dies when warmed up
- integra obd1 chassis harness into a crx?
- Just bought 89 crx, lots of rust. What do I do?
- d16a6 question!
- zc swap
- Questions on upgrading my '88 CRX HFs brakes
- PASSWORDJDM DID IT AGAIN.
- crx rear disc conversion
- looking for 88-91 civic hatch CALI
- What do you think so far with my project?
- 1991 civic b16 ( Cleanest iv seen) lots of pics
- CRX DX smog
- 6k rev limit??
- will del sol vtec knuckels and brakes work on 91 crx si
- Cable on back of the tranny
- 90 civic - stalling when idle / accelerating / shifting low gears
- My new CRX
- Rusted out hatch-hinge?
- Could a bad distributor o-ring cause a CEL code 9?
- Help guide me to the right direction about removing the Resitor box.
- fog lights on a crx, and substitutions
- Code 9 and VTEC ?
- Tanabe Super Hyper Medalion Exhaust
- How To: fixing sloppy Avid shift linkage
- my POWERSTEERING fluid is overflowing... WHY? please help!
- Motor want start?
- expletivein Ricers!!!
