View Full Version : Honda CRX / EF Civic (1988 - 1991)
- front ends
- ef gsr obd-1 swap no spark
- axles that come with a swap
- help please rex wont start
- Need help with a civic engine swap...
- radiator cap
- ls cams in a zc head
- Is the car rare when it has factory paint and interior color ?
- Stupid hood problem!
- Hood Dampers installed on 90 Civic
- jdm front clip
- calling all engine swapers who want at crx shell for work in illinois
- Intercooler becomes Air conditioning?
- shifter & bushings
- b18 swap
- Brakes 1991 SI/ Brakes 90-93 Integra???
- Front Wheel Noise (low frequency hum) When I Turn Right
- valve seal question
- spark plug question
- Right Hand Conversion........
- 2 CRX's, need one running.
- need help with side moldings 88 crx
- anybody seen this... What do you all think some good info here
- when should i tune my ride?
- resurfacing drums
- y8 mini-me help :)
- Front Tires Rubbing
- d16a1 trans on a d16a1?
- Opinions on what i should do for a 91civic hatch Dx.
- d16z6 questions
- Baring a CRX
- Oil Pan Gasket Problems
- 88 CRX tail lights
- question about integra Da dashboard...
- bad gas?
- reading codes on obd1 conversion
- Problem with Speedometer after swap!!! Help!
- There a Glass Top Crx part out at the forsale
- crx accident
- Where to buy 3mm wheel spacers in Houston?
- wtf
- ECU Codes
- need a new timing belt = new water pump too?
- crx exhaust....pic of near cat with teg swap
- How do I make 94-00 Integra seats fit into my 91 CRX?
- NOT AGAIN!!?? tech question.
- CRX DX build part 1
- Car won't start
- brand new 88-91 b16a distributor
- What engines will fit in 1987 CRX?
- Need new tires and some opinions.
- 91 dx wiring diagram
- code 10
- what do you guys think about a b18 with a b16 head in my 89 crx
- finished swap firing problems
- 16" rims and tire size opinions
- New CRX Owner
- Are these 2 problems related
- I need to pick an engine with my crx
- What's a good 13" tire.
- manual fan switch problem
- My 88 crx SI build.... finally got another one
- Certifit parts..?
- no crank...just click
- 14" or 15" wheels whats your take
- Help spark problem need pics of dizzy plug and ecu slots
- where is the best place to try to sell ef turbo parts??
- bought me an EF!!!
- ef 4-door front end
- doorpanel and seat swap
- rear windshield wiper hole...
- will civic exhaust work on a crx?
- Rod Bearings
- car wont start
- rear lower control arm question
- Bleeding brakes need help!!!
- no fuel?????
- 85 crx hf....any ideas?
- auto-manual.... is speedo cable interchangable???
- Bearing puller, bearing separator? (differential bearing)(searched)
- jdm d15b in 91 crx dx
- I know everyone loves painted moldings, so how do I do it?
- V-AFC 2 wiring help on a PR-3.
- turbo ef?
- Dizzy question??
- odb- to obd2
- Help please guys! Crank/Rod Bearings!!!
- Signal Light??????????????
- 1989 Civic DX Manual Trouble starting
- stock fuel pump on turbo b16
- D16Y8 into a DX sedan......
- std or not?
- d16a6 from CRX into Civic - wont start
- cam gear help
- B18a in 90 Civic SI hatch wiring problem/question....
- b16a.. 2 o2 sensors??
- Finally here she is
- King of Swaybar's?
- My Dizzy is goin tick tick tick. HELP ME!
- Radiator Options?
- JDM B16A from EF 8/9
- Fan Relay
- turbo diagram
- rack rebuilding concerns
- New A/C Compressor
- i know im stupid for asking but...
- question for the EFers!
- 90 civic lx 4 door convertible?
- have you seen this?
- Sorry guys but the fucker cut me off and I couldnt brake in time...SORRY
- larger steel rims
- How to take off Headlight?
- Obd0- obd1 wiring, Extra wires? wtf
- A b16 swap
- rear mugen kit bumper alignment
- SKUNK 2 TEST pipe
- need info a b16b
- Rewiring the Safety for the Clutch
- b16a shows code but vtec still work??
- moon roof
- What does Honda make its engine blocks out of?
- Brake booster swappability?
- what did you do for your rex this weekend?
- 88 CRX suspension differences?
- EF9 JDM WINDOW
- minime conversion HELP
- HONDATA , RC Injectors, T3 Manifold going cheap!
- any pics or a write up on the password lip on 90-91 crx frontends
- dc 4-1 header for a d16y8 fit in a 91 crx
- b16a crank + b18c block. Poor man's b16b?
- I HAVE A QUESTION PLZ HELP!! ZC DOHC
- New CRX owner. have some Q's.
- EG or EF turbo drag car....please help me decide!
- em racing good, bad, bling, function...? whats your take?
- how do i do the S-AFC HACK!!!
- Exjaust flange question!
- B series Axle Question....
- JDM Black valve cover
- JDM bass speaker thingys for sale
- I Don't know which i should do first
- Will an 89 crx si engine harness work on a 91 crx hf?
- lambo doors
- 91 Civic Sedan Motor Question
- obd0 to obd1
- o2 sensor wire help
- B18A
- Engine swap fun :o
- Brake Kits for CRX?
- 85 crx hf
- Axle back exhausts
- Violent shaking rear end possible bend??
- vtec or no
- stolen crx in ottawa ontario
- 2 Questions
- door swap
- v-tec question
- Emissions...
- b16 not running right crx
- Suspension/Shock Absorper Question
- head studs torquing!! ???
- Modified B16 Shift Linkage VS Hasport Shift Linkage
- coolant overflow nipple broke off (please put suggestons)
- innovative crossmember question. has any one had any problems with the bar hanging so low
- Problems with a civic 4dr! *HELP!*
- Help with ignition Starter button?????
- HP calculation
- need help. dx to obd1 d16z6 swap (only injectors 1 and 3 working)
- Is this an 88-91 fender or a 90-91??
- D15b2 fuel injector compatability!
- 90 civic fog lights???
- RWD CRX under construction!!!
- Is this real of a fake/rip off?
- 90-91 civic/crx si transmission... any good sites for buying?
- msd? does it actually make a difference?
- Outer tie rod end help needed!
- just got done now its running like crap!!!!
- 88 crx si speakers
- CRX still bogging!!!
- help
- 88 si?
- 91 Civic HB parts will fit 91 CRX??? help please!
- car wont start when its hot outside?
- will a 92 hydro clutch work with my 89 dx cable tranny?
- Tachometer help
- Battery Question?
- Bulb #'s For 91 CRX
- Who has a pic of FMIC with Vis Pro2 front bumper?
- HELP POST
- What is wrong with my car? not the ignitor 8(
- VX rims my center caps dont fit. Any help?
- Non OBD to OBD1 conversion on distributor
- '89 Civic Si B16a Swap and Transmission compatibility Q's
- what parts will fit
- b16 Y1 turning problems not the axle
- Guy on here that made EF charge pipes? water bottle friendly
- broken bolt hole. What to do?
- Steering wheel removal problem............searched
- Which housing is better? stocky or projector for HID's??
- what kind of LCA's are you guys running?
- 2 questions!!
- one piece headlight for 1st gen crx?
- TPS Question.....for the pros
- CRX/Civic Radiator Sizes... what works?
- Have a CRX with a B16 swap?...
- Frame rail > Crank Pulley
- tranny question/b16 question
- sounds like nails in a can
- question(s)
- B16 running wierd after car warms up. Someone help.
- New member - with xtreme JDM pics ;)
- b16a
- would camshafts, camgears, valves, retainers,springs help out my b18a?
- exhaust question
- 92-95 EG lower tie bar
- Helms manual
- i need some help on what to do with d16
- Vtec Solenoid
- O-rings Melted...
- Ls motor
- Car Died Slowly -- Fuel Pump?
- Engine torque damper
- do i buy spark plugs clutch etc. from a 99-00 civic for my b16?
- Separating door panels on 89 CRX
- swaping B18a into crx/civics
- anyone know where to get a silencer from?
- "Will this downpipe work?(ZC)"
- B16 swap in Civic 86
- map sensor by pass????problems running
- coolant temp sensor QUESTION and idle q
- Turned car off, now it won't stay running and runs like crap
- Pryinh head off block! HELP!
- VSS check engine light. installing vtec.
- injector swapping
- 36 valve honda engine
- pg7 ecu in 91 crx dx
- motor site
- LIP KIT FOR EF"S anyone seen any>???????
- Power Surging, Dash-Lights Flicker, no starter signal! HELP!!!
- engine decisions?
- Friends Crx - my time slip
- crx 255cc injectors
- Help!! CRX AC lines
- obd1 conversion...problem?
- LIP KIT EF"S calling all ef8's/ef9's anyone seen a lip kit except for road race?????
- D15b vtec motor swap??
- expletive Thieves
- b16a? someone has to know
- I need a fuse diagram
- custom made side diffusers?
- VSS stuck in tranny
