View Full Version : Honda CRX / EF Civic (1988 - 1991)
- civic 4gen b18b turbo need help with stuff
- Experience with hitches.
- MPFI swap questions...got it running but still need help
- just bought an 88' Crx Si for $600.
- 92 Integra seats into 88 CRX Si
- si into std hatch swap question
- Speedometer problem
- *** are TEIN ss a good setup for my crx ***
- Y8 O2 Sensor
- need to know there to get jdm power window and side mirror for a 91 civic
- sohc wiring harness
- info on mini swap 88 crx si /d16y8 long block
- Car Heats up bad!!, hELp!!!
- does anyone make aftermarket lower control arms for 89-91 crx's
- d16 14b turbo info please!
- cv-joint replacement.
- mpfi swap finished- will code 17 (vss) cause fuel cutoff?
- EF sedan cage-
- When is Ben Ogle going to make a b-pillar or hatch strut bar for a 88-91 CRX?
- speedometer stoped working
- The Mud Civic
- need afc
- Need help on my on my sawp
- My Barris Kustom CRX Si
- code 1, 14 and 20?
- Starter help
- how do u put a 94+ integra cluster in a crx
- Test pipe
- where will I get a Fuel tank for my 86 CIvic wagon?
- wiring harness gurus .. help
- Tokico Illumina coilover kit?
- O.E. Tuning Carbon fiber Hood
- OEM wheels/tires
- Tranny swap in a 88 crx...
- Did they make these clusters in 88-89 style? (pic) UK VTEC
- tein SS ? koni/gc for crx?
- HELP
- what harness?
- 91 crx si parts for sale must sell everything
- Will these mounts work with my new b16a1 in my CRX??? I got pics!
- Anyone got a O2 sensor 4 D16
- 92 GS-R seats into 89 civic si hatch
- Anyone have a ProClutch stage 3 clutch? any decent? Stock isn't cutting it anymore.
- Civic's gettin a new battery...woo hoo super duper cheap and light.
- need SiR cluster wiring diagram!!
- Best Engine (for my girl friend) for her 4Door
- No search Results. Simple Blower Motor questions
- rear brakes removal question
- what is need for y8 to a6 manifold swap?
- WHAT DO YOU GUYS THINK????????
- reason for grinds?????
- D16Y8 swap wrap up (need some help)
- SI TRANNY.."mainshaft bearing "
- earing is going out?SI TRANNY.."mainshaft bearing "
- How to fix a FITV its as easy as 1, 2, 3....
- Stage 2 clutch
- dpfi to vtec/itr im
- which parts swap from a y7 intake mani to a z6?
- WTB: B-series mounts: FS: 90 DX knuckle
- what color did the hf's come in?
- which wires go to what on rear of b16a
- B17 boost
- crx carbon fiber hoods, what does yours look like!
- ::did a search?? EF harness bars??::
- mpfi sedan...Runnin rich, misfires, fails emmisions, code 7...
- about rebuild parts
- D16Y8 swap in 90 si (auto intake mani)
- cant find writeup on 5th gear swap in an s1 tranny
- new and need help with a d16y7
- Lets see pics of 92+ radiators and mounts
- Racing Harnesses
- just to verify...for B series does it matter if the clutch is from cable or hydro??
- pics of side mount intercoolers
- road race
- JDM radio tape player & EQ
- gsr motor mounts
- shift linkage help
- curb weight for 4doors
- B16 turbo or LS turbo? what to choose.....
- hcp motor mounts
- Hondata
- ::front cross member questions??::
- compression checked.. 90 civic dx
- Any of you guys have this arm rest in your rex???
- Advice on current and planned setup requested...
- DA piping on my hatch
- what is the best turbo in crx?
- steering problem please help
- anyboddy have the hook up in insurance i live near LA
- Stock Rex Si
- coolant leak
- skunk 2 manifold on and now it idles REALLY high . any ideas?
- b16a1 Wiring instructions??
- Who has built a turbo EF with a FMIC? Where can I route The Hot intercooler pipe, from t-bo to FMIC
- another b16 idling too high still after warming up. **(please read)**
- crx leaking in the hatch
- parting out 88 si
- What kinda time can i run with a stock gsr in my rex
- 5speed engine harness on automatic dash harness
- @@@swapping crx SI into a hatchback DX question????@@@
- Sprint 3.25 inch drop?
- totaled white crx(hf) w/ small mods sellin parts+aftermarket parts
- smog ref.. i want BAR sticker... need help??
- b16 wiring harness problem HELP!
- 87 crx si=need help!
- just got back from dyno, and i'm super happy...
- Crossmember/Radiator problem.
- Front lip
- Different honda sways to put on crx???
- will a dohc zc head fit on a d16a6 from crx si
- B20Z IDLE PROB
- Suspension problem, AFTER alignment
- Any hatches with Konig???
- DPFI to MPFI....gauges
- EG tranny internals swap into an EF tranny casing?
- tons of glee....
- STICKING TEMPATURE GAUGE
- New CRX gal
- need to find out color of wires for this sensors !!! pls
- New EF7 - EF Squad T-Shirt
- oh might crx gods help me out please
- shinchan ef8 update!!!
- Recalls and warnings
- **Door window question** for 91 hb
- engines around the bay area?
- Got my JDM tails but no CRX?
- Where and how much for ZC swap?
- Skunk2 Coilovers
- D16Y8 swap into 90 Si!!! PLEASE HELP!
- Stupid question -- Why hood pins?
- show me pics of your trunk mounted battry
- clunking from rear left tire
- What Would You Do? Have some money$$$
- just sayin hello
- sold my car...last sohc power incar video...for now
- Skunk2 D16z6 IM Dyno ?
- ANYONE EVER TRY AEM V2 WITH B SERIES SWAP??
- JDM OBD0 B16 Wiring harness questions.
- Anyone have pics of a 1 gen Integ armrest?
- Took a trip to the Honda Dealer today about Seatbelts
- Fellow CRX'ers - Please help me find a set of these tail lights!
- shock question
- snow tires / wheels?
- b16 and aftermarktet?
- how much for this badboy....
- Pics of my accident!!!
- CEL for b16a crx
- Will Azenis 215/45/16 tires rub with my 5zigen fn01r-c wheels??? I searched...found nothing
- Honda Yard near Schenectady, NY?
- Radiator Problems
- Car can't keep constant speed during emissions testing
- B16 ?'s...help please!
- any 88-91 multi port sedans?
- couple of questions, need serious help
- JDM front end??? will this work
- anyoen know of a that big oem hondaparts website?
- anyone have a OBD I p30 ecu i can borrow?
- S20 tranny converted to cable?
- sunroof won't go all the way down, on only one corner???
- remove trim from fenders/quarter panel???
- I am almost talked into a SOHC Build....
- Comptech Icebox on EF
- Over heating???
- motor swap
- HOW TO MOUNT SEAT BELTS??
- Anyone heard of using a S2000 oil filter on your Civic?
- hoodpin installation: which pre-existing holes to use?
- people with y8 manifold .. coolant hose question...
- B16 Problem Vtec engaging at 4300 Rev Limiter at 7
- best camber kit for crx?????
- Civic hatch vs. CRX vs. Festiva
- Should I do the JDM susp swap and brakes?
- wanted 88-91 civic hatch
- headlight relay?
- CRX bigger fuel injectors 450cc
- Good price? (looking at an EF beater car)
- Differences on clutch pedals between trim models
- B16A head same as a B18C5 head?
- Clutch Pedal doesnt work..clutch wont engage
- Wiring B18C into an EF
- b18a throttle body to D16a6 IM...??
- rear brakes from 91 crx si to 91 civic si
- b16 o2?
- EG seats in EF HATCH???
- will a 90 ls distributor work wih my d15b vtec in my 89 hatch
- wiring diagrams?
- lol crx took a shit
- IAT location on 89 CRX Si
- leak help me!!!anyone had this problem?
- NEED INFO! QUICK
- cluster swap
- gauges?
- whats the difference between the std and dx engine harness?
- b16 in so. cal
- Want a high flow fuel pump that actually fits?
- Halo reverse glow gauges no tach for sale....88-91 civic
- Help...B16A3 swap into crx. how to turn crank?????
- D series oil pumps....
- B series rod question
- frist gen crx anybody
- please help!
- my new 1990 wagon 2wd :)
- odb 0 injectors...... somebody...help....... cant find.......
- Where to buy?
- wiring wurus.. help
- Cam Gurus.. Identifying..
- Engine Models
- check engline light is on
- I bought a junker 90 integra for parts any ideas?
- So whos got winter tires for their Civic?
- Camber Problems
- 1990 crx disk breaks?
- who is running Blown90hatch 0bd0-obd1 harness i need some help!
- Who would like to see a How-To on the new EF2 Hasport kit?
- Civic 1991 D16A Cam Gears
- car won't run, t
- zc and si tranny confusion
- LS swap
- Advanced Autopart Order
- slipstreams?
- Ef detachable steering wheel???????????
- Crx window question....
- what model car do i have???
- jdm? bumper on ebay 100 bucks
- Auto to Manual. (check to understand what i mean)
- 1989 Honda Crx *HELP*
- D series tranny Questions...
- ITR Steering wheel in CRX: Questions and Ideas
- help I need a JDM signal light (pass)
- sedan rear seats
- d15b2/16a6/z6 hybrid good or bad?
- Pic Request: CRX Climate Controls at night with all bulbs intact
- Anyone wants or need a Front Tower Strut Bar? CHROME =)
- how much is an obd 0 b16 dizzy worth?
- Spark racing motor mounts with what shitf linkage?
- ZC Tranny
- SiR bumper question
- 10 second dx??
- z6 header and exhaust?
- tranny rebuild?
- HUB/WHEEL NUT HELP!!! Axle questions!!?!
- sohc zc help
- will 86 clutch fit my 90
- i am new at this please help, which ecu
- overcooling problem help
- Swap problem
- 7 psi on a b16
- Exhaust pipe too low...any tips?
- got my MOTOR today!
- WALBRO 255 LPH Fuel Pump
