View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 90 Civic HUNTING IDLE at warm temp with new motor, old one did the same thing...?!?!?!
- exhaust/muffler system for a zc dohc swapped 89 crx?
- One last try--code 16 and Limp mode problems!
- Brake Pedal too stiff?
- Lowering Problems
- My New Sedan.
- Q: jdm front....
- Help me figure out my suspension woes
- help
- 90 sedan ex,,,
- CRX & Civic Axle Interchangeble?
- TO MUCH SMOKE
- CRX Thermostat
- 215/50/15, 2.5in drop
- making lower bumber lense a fog/ blinker
- ? about fenders
- clunking noise in frnt end.
- burning smell at high rpms
- brake problems
- stock b20
- PR4 Code 43
- Loud Knocking
- Walbro fuel pump
- 94 civic 1.6 swap to 91 civic hatch
- BOOST QUESTION
- whats the USDM part that is hardest to find ?
- What valve seals to use for ZC?
- Do YOU know which sensor this may be?
- Master cylinder resevoir bottle....
- crx timing belt
- gsr bades, or ls mesh?
- anyone know where to get a glasstop installed in the nor cal area??
- New JDM EF headlights need help
- Starting Trouble B16a - Takes a few tries, dies, shuts off if you give it gas right away...
- Distributor for the Jap Spec b16
- another CRX JDM SiR found here!
- No CEL but ECU has codes???
- Water leaks in CRX interior
- CRX Engine Bay
- weight reduction list please?????????
- ground wire issue?
- help plz
- My CRX Valve Cover..........
- D.I.Y. 89-90 Camry Front lip
- HELP!!ef five speed pedal assembly
- crx harness problems
- custom exhaust
- oxygen sensor
- cost vs. power
- Reverse blowing fuse HELP PLEASE
- 1991 CRX PARTS
- Need Help Bad (Searched and Searched) Solid CEL and Bogging Issues
- oem rims??
- Wheel Arch repair panels - follow up from old thread
- 89 SiR CRX - Adjusting cable clutch??
- p72 IAB sensor
- oil pressure
- vtec pins on ecu i dont know
- fuel pump question
- Swap dont start HELP
- Fuel Pump Bad or Not, that is the question?
- ZC tranny seal same as SI trans Seal?
- Clutch Pedal Broke
- What is this called?
- Explicit Speed Performance H22 mounts
- New member here
- 1.5 Dizzy Cap vs 1.6 Si Distributor Cap - searched
- CRX, Bumper-Headlight removal
- 91 DX to SI motorswap question about dash harness
- 90 si runs really rough.
- b18c type R swap
- is this the easiest swap for a 89 civic hatch
- Crx wont start
- 88 Crx Si master Cylinder replacement.
- 91 crx seatbelt wiring. where do the wires coming off the door mount seatbelts go?
- Oil Pan Drain Plug Stripped! What now????
- Isky valvesprings+stock retainers?
- gm coil packs???
- d16y8 with hydro transmission in 88crx
- whats a good turbo piston???
- opinions on a possible set up
- help with gsr swap into crx anybody have a walkthrough?
- Why does my CRX hate me?
- got me some EM1 brakes/hubs ?'s
- b16 still wont start
- Should the downpipe have a hanger?
- New EF on the block
- NEED ECU AND VTEC HELP!!!!!!!!!!!!
- hood for a wagovan
- b20vtec not starting!!!!
- 89 civic dx...how to fill the tranny?
- How much is a shell like this usually worth?
- RHD Turbo Dart B18 CRX project dream
- Car dying while driving...
- Post Your X-Mas List
- PM3 Head??
- Anybody burn programable chips in west michigan?
- 2 CRX's, 1 brake problem, 1 solution?
- Fuel system for my ef swap?
- 90 crx brakes jammed!!
- leaking windows HELP!!!!
- Gimme some EF Hatch INSPIRATION!!
- Vented vs. Non-Vented radiator cap? Is the stock Honda cap "vented" or not?
- stock crx radio q
- clusters that will fit in a crx...
- too much fuel going into throttle body?
- Hasport EFB2 Hydro kit in RHD CRX clutch cable problem
- how do i tell wat tranny i have si or dx
- Transmission Halves
- need 2 get a set of 87 civic taillights
- CRX with ramhorns please chime in...mine doesnt fit..
- radio/climate control bezel
- B16A driving SLower
- 1990 CIVIC EX...
- 91 parts
- 91 Crx SiR Carbon Fiber Hood
- CTR pulley/alternator belt
- DA integra knuckles in my 91 crx DX
- Has anyone tried towing a jet ski with a crx hf?
- Question About HX Rims?
- where to buy crx window visors?
- vafc b16 optimal settings?
- USDM cluster ID
- what motor is a ps9 ecu for?
- Doable? Need to fit a b16 with tranny and a body kit into a crx?
- If anyone needs the REAR LEFT caliper w/ bracket and pads I have one
- leaving the EF comunity...
- H22 in a CRX, Where to buy mounts?
- CRX front clip
- CRX Catback
- Can someone please tell me how to convert to mpfi?
- turbo questions??????
- Anyone know if a DA integra's heater core will fit an EF(ED) civic?
- What clutch to use?
- shifter
- maaco paint job
- transmission problems...
- Good Price for sleeved Z6?
- mod to header cost vs replacement
- i just got a 1990 crx si..
- Avid Racing traction bars?
- obd1 CEL help please!
- stupid tranny question
- New project car: 91 Civic Si
- will 88 crx seats with rails fit my 91 hfcrx?
- crx budget project
- Anything i can do to my head while its off? d15b
- shift linkage & torque rod
- sub and amp install
- my heat sucks any suggestions
- parking lights
- 88-91 ZC DOHC (similar to D16A9 engine) into my 89 HB DX...yay, or nay?
- Is there a difference in fuel pressure regulators?
- No...that wasnt it, next suggestion??
- INJECTOR PROBLEM
- Throttle body question
- jdm header
- cheapest braking power
- temp gauge!
- HX RIMS
- coolant routing for poor man's type R
- exhaust
- d15b thermostat question....
- speedo cable installation help!
- noob motor swap
- 89 civic hatch b20 or b18a/b
- what to use to clean interior paint?
- throtle body sizes?
- Can the 92-95 Civic Si transmission mount in a CRX at all???
- After swap question. Please help.
- CRX front seats swappable?
- What Rims
- What Would Be A Good Price?
- Changing from fuel injection to carby on 16V SOHC VTEC 1500 cc
- b16
- suspension question
- looking to sell
- JK traction bars
- stock
- My Dad just purchased an 86 CRX DX with 28k original miles...
- odb1 dizzy question?
- code 13 on a b18b swap
- cranking engine after rebuild - timing problem
- what piston should I use in my ls
- ecu error code 17 - vehicle speed sensor
- Timing belt keeps slipping. Valves bent or broken?
- Broken windshield on hb
- are block guards any good??????
- GSR ef
- Intercooler piping question
- My project log thread: Rear suspension rebuild and build...
- Ef b16a1 swap
- Swapping, LS; help with DPFI to MPFI; used FAQ 2.0
- Looking to go with a budget Bolt-on + Nitrous setup - B16A/Crx
- y8 to z6 driver side motor mount Q
- Somebody stole my valve cover, WTF. Theives need to die!!!!
- WTB: Manual transmission for '83 Civic Wagon
- another trivia question
- civic si and crx si differences.
- Center climate control
- QUESTION OF THE WEEK....
- Sunroof misc. part question.
- ANYONE SELLING A CRX FER UNDER 500?
- Fog Lights
- Got into a little accident and need help.
- how much can a stock ls hold up 2??
- Which modern mount kits give the best fitment?
- 91 si to 88hf dash
- Quick Interior Question
- need some help.
- Vehicle Speed Sensor...NO VTEC:(
- engine swap
- Who's got the lowest mileage 88-91 crx?
- 91 crx hf + b20b turbo questions
- $50.00 paintjob..( 4 real..)
- I have a question about the zex stage 2 camshafts?
- Tubing the frontend?
- need help finding a part
- A few dumb engine removal questions
- Help replaced map sensor
- My 93' Civic Ex won't start!
- 90 civic rear speaker wiring question
- sohc zc going in and out of limp mode!
- Help! My CRX is in pieces but, it will be o"K" GearspeedEF7 Project Log
- Win this CRX and help a worthy charity
- Crx roll cage question
- igniter on b16 n 1.5 dpfi
- wiring harness help
- zc wiring
- Has anyone ...
- Help me decide on a rim size...pics of your ride are welcome.
- sputtered, shut off n wont start
- heater coolant hoses crx z6 question PICS
- spark plug gap on b16
- Interested in following the build of my 1986 CRX Si?
- no spark from dizzy
- fuel injector problem
- converting a b16a ls/vtec obdo to obd1 ?
- got a couple questions if anyone can help???
- PIc REqUesT....strut bars..
- Looking for orginal instuctions/diagram for OBD0-OBD1 conversion.
- motor mounts stiffen with hose tubes?
- CRX Tach
- opinions...z3 fenders what should i do with them
- Will 88 civic fenders fit an 88 crx???
- Where to buy a D16z2 Valve Cover?
- looking for tokico sponsor?
- Tachometer problem, not working properly...
- how much?
- 91 dx with ls fuel issue
