View Full Version : Honda CRX / EF Civic (1988 - 1991)
- gsr swap in 91 crx si
- Sparking when turned to the "ON" position
- clutch question
- b16 obdo or obd1?
- I need water pump,tension pulley, and timing belt writeup for jdm d15b vtec
- what motors are usuable with my set up
- supercharged b16 questions
- what exhaust should I use on my 89 crx si
- Help with Rack and Pinion Rebuild
- Witch one would you go with
- Anyone use the Hasport hydro conver?
- honda civic ef b16a pwo ecu problems with vtec
- i need advice.
- B16A.... Tranny (J1)?
- New to the EF world... HELP!
- Revo or Rhino upper controll arm(camber kit)
- will this work (trans)
- third plug on passenger side for b16a2
- jj's civic project thread
- steering wheel starts shaking @ 50 mph +
- cable clutch problem
- replacing clutch
- 90 civic sedan> in the making part 2!
- 15/16" to 1" MC question
- crx trouble codes
- Valve Cover Gasket
- turbo d15
- just dropped the new tranny in my EF
- 91 dx dpi to mpfi to z6 odb1 mini me???????
- crx help please
- 90 ciivc wont stay running
- F22 Swap into a 90 CRX
- intake question help
- 16v Wing Install(w/pics)
- AC autotechnic precision vtec controller, but no diagram
- SOHC ZC into 90 Si plug trouble
- b16 swap?
- knock sensor cant find it
- guage cluster help?
- JDM Fog Light Install (the RIGHT way)
- EF Squad??
- B16 Spurtin' Oil (first gen)
- check engine light
- rpm question
- Quick distributor question
- mini me distributor question
- mount question: AVID HCP
- What site is good to buy motors from?
- code 9?
- b17 build
- cel code 10 help
- Civic 1990 Dx Hachback Not Fireing
- Best LCA
- ecu trouble code
- sohc head cracked between cylinders? is this still usable?
- Not firing?????
- What do i do?
- Starting trouble....Please help!
- Better for HID??
- Rear sway bar on DX, Si LCA's needed?
- replacing door
- compression ratio of a sohc zc? Quick question. Please Help
- Swap wiring question
- New Car/New Project/New to site
- cv question on ls swap. . . .damn making too many trying to search but not savvy
- Is LS Vtec street legal?
- what interior plugs are these? i'm going from 90si to 89si plz help w/pics
- saying hi to all of hyper16valve
- 99-00 si rear discs brake fit a crx?
- B16
- question about fog light wiring
- Starting Problem
- seats
- d15b2 need help to run a turbo
- JDM D15B Vtec, what distributer??????????? SEARCHED!
- problem regarding to setting the timing on CRX
- integra seats in ef??
- defrost probs
- To JJ's civic
- sensor question, how was this MISSED????
- Tach install
- need to make sure this is the right one..
- help with DeVac
- no power at dash need help.
- My last post didnt make sense. But does this sound like an ECU problem?
- type r vtec solenoid
- crx tranny problem
- 1989 civic timing belt change
- Are all D series rear main seals the same/compatible???
- Sputtering from idle to take off...
- Help!!! Code 20 Electric Load
- AC UNIT
- PCV Question
- a6 block with a z6 head?
- pcv hose collapse
- Can someone tell me what sensor this is on D15b Vtec *PIC*
- AEM Short Air vs Ebay Specials
- wings west kit for CRX
- account
- b18c5 swap
- HOOD QUESTION HELP ME FAST!
- b16 no power?
- next project...
- A/C gurus, dryer-reciever question!
- full DOHC ZC head help/question part 2
- axel cluch grinding?-
- :Need help: Changing B series transmission
- quick Q. EF not starting.
- Bad Synchro or trans?
- REALY BAD BOGGIN OUT???
- h22 to b-series tranny
- Got a 91 hatchback SI!
- What should i do, with this crx
- intake manifold swap on dpfi
- Harness Question... yes I researched first!
- wiring diagram for obd0 si ecu
- obd0 -> obd1 distributor wiring woes
- Braking System Upgrade - Need to know my options
- code 4/10/14/15...HELP!!..91 dx obd1 ls
- b16 problem. am confused
- tanabe or greddy?
- Could this be pulled out on a rack?
- rhd conversion
- Swithcing seat pans onto Del Sol seats....
- sedan engine ticking
- RMF header fit in an EF?
- YS1 tranhy from B17?
- ecu question
- Me and my car!
- si-r front end
- b16 error. please help
- Unique VTEC problem and boost Question
- coolant diagram
- SEARCHED CANT FIND HOW TO REMOVE REAR MOUNT BRACKET B16 IN CRX info ASAP
- Help Si won't start.
- Drag CRX
- 89 civic sedan b16 bogs when you hold the accl. steady.
- Sorry to ask...but 1989 Cluster help
- MSD (or comparable) ignition?
- Exhaust Noise
- bypassing dimmer
- hatch si seats in dx rex....
- What could it be?
- Vehicle speed sensor help cable to electro
- Going deaf need to get rid of apex N1
- 88 Crx wont turn off
- Kinda Funny story/ Starting issues, What could it be
- My new wheels. Time for fender flares.
- Master cylinder issues
- 89 honda civic b series exhaust question
- 90 Civic HB Headlight troubles. High Beams Only.
- S1 tranny
- civic ecu upgrade????
- Need 02 sensor wiring help.
- Bride brix into 90 civic hatch......
- Injector question
- zc stalls
- CRX Bra Part number?
- "90 Si Hatch's" tare down of a D16Y8, and my new Build JDM D15B Vtec 56K Heck NOOO
- 89 crx- front support
- Speedo cable
- starter wont come out
- Steel braided brake lines for 88 CRX
- JDM Bodykit(s) clarification
- 91 civic b18 swap
- dual cam dizzy help!!!! ASAP!!!
- Snapped stud replacement?
- Alternator replacement, no master cylinder, no half shaft removals
- need the ecu harness wiring diagram for my 1990 civic!
- Which springs/coilovers for biggest drop
- question about bleeding the coolant system
- Back in the game again....You knew I wouldn't stray too far
- engine wont start, suddenly shut off...baffled!
- Need a distributer
- Rattling while Braking.Is this a tie rod issue?or warped rotors.88 crx si
- front suspension refresh kit on ebay
- Rattling while Braking.Is this a tie rod issue?88 crx si
- Is the CRX hub-centric or bolt-centric????
- OEM JDM crx sir muffler
- question
- gauge...where?!?!
- code 15 no start and other q's bout 90 si to 89 si becuase of hacked harness
- ebay brake lines???
- Bye-Bye CRX
- new addition to my EF family.....
- crx 88-89 dash possible to convert over to 90-91 with dash cluster
- prelude seats?
- B16 Swap Problems
- Mysteriously losing coolant
- rod knock is the crank still good?
- d15 with zc pistons
- 1990 honda civic cx 1.5l to a zc
- my car doesnt start (fuel problem)
- 95 jdm h22 into a 89 si hatch
- D15B1 engine
- Starter Problems-Searched
- eg seats fit a crx??
- got crx lower control arms!!! help!!!!
- OEM Metal Guage cluster
- apexi neo helppppppppppppppppppp
- j-k tuning conversion
- D15B2 Distributor question.
- distributor question
- Sexy New CRX seats - $25/each
- D15B7 on a 90 hatch
- No spark
- sensor help please?
- amber light
- GSR swap, no v-tec and no codes?
- knock when turning
- 92-95 Tranny In 91 Civic?
- oh... rusty tank oh rusty tank...
- AXLE HELL
- spoiler adjustment
- CRX questions
- i broke my hydro conversion (innovative)
- i arched for an hour didnt find anytyhing on what i need to know
- i can't find the iat on my hf
- GSR engine is acting strange
- JDM style bumper for USDM front end?
- help with 91 civic
- emission for zc!!
- 91 crx si sunroof and 91 civic si sunroof
- obd0 -obd1. installed. butt...
- y8 into 88 hatch
- 91 hatch, wire tucked B16, no tail lights? looking for some help.
- Low compression in D16A6
- oil pressure / bad headgasket related problems ???
- a/c from hb to crx
- auto to 5 speed
- 1989 SI Project
- obd0-obd1 workin/problems in my rex
- Noob from Australia sayin hey - EF8 CRX
- NEED HELP
- what rad do i use with ab18 swap in 91 civic
- JDM EF9 DORI DORI!
- Will the wire harness from a 89 Civic Dx work for a ZC DOHC engine?
- d16z6 swap, need help
- axle question
- b16a hesitating
- help, no spark
- Throttle body/cable reinstall????? Honda CRX Si
- nedd help finding a LEGAL swap for my EF!!!!!
- Cluth cable HELP!!!!!!!!!!!!!!!!!!!!!!!!!
- buddy club seat rail
- does any one know
- mini me swap? $$$
- LS/VTEC Project from Costa Rica... Headers HELP...ASAP
- b16a harness question
- OBD1 swap using d15b2 head
