View Full Version : Honda CRX / EF Civic (1988 - 1991)
- CRX carbon roof cap
- clutch balancing
- Real Long throw??
- 90 crx si wont turn off
- Help making a decision, buy 88 si CRX?
- crx MISSING LINK
- b18a using a PM6,PR4,PM8,PM5?
- Solution to Sloppy Shifter
- Quick obd0-obd1 conversion question. Distributor.
- Rotella 5W40 for oil burner?
- Help NOOB
- Stolen CRX In Bay Area
- hks sport exhaust for 91 civic
- Front corner lights question
- autometer autogauge tach w/ shiftlight
- Help: Glass removing from Glass top (CRX)
- ls/vtec swap no spark HELP!!!
- need suspension help
- electrical gremlincito
- gearing(si tranny vs sohc zc)
- MOTOR BUILDERS IN NJ
- Would you put these on your EF????
- wagovan cluster in EF9?
- crx si question
- Timing Belt replacement....Need Help!
- ~ Project CRX Track Wh0re!!
- oil leak on spark plug tube...
- EF8 axles w/ hydraulic gearbox??
- yes or no dizzy question....
- vss help
- need help with filter!!!
- what application to use for when getting parts for a b16 a
- civic 91 question
- Fuel Pump Relay? Were
- 90 civic compl or part out
- ef intake question?
- Zc Header
- 93 vtec motor running like shit
- Blinging the engine "rainy day :P"
- squeeling sound
- Half size RAD mount
- Alternator belt
- Most insane swaps...
- 3,000 rpm problem
- ecu pinouts whats b16?
- HELP IN CENTRAL FLORIDA!
- Starter issues: inquire inside
- URGENT HELP!!!! PLEASE HELP ASAP!!!
- password lip
- why you dont let friends work on your car.....
- jdm 1 peace headlights don't fit my car should I sell them???
- Are axles interchangable
- brake light!!
- My car sounds like a motor boat...
- Differences In Combination Switchs - Civic & CRX
- header on ef with b16
- 85'ish CRX and H22
- what happen
- 89 CRX...
- clutch
- Help: Ignition-related problem!
- 1992 jdm d15b specs?
- 4th gen civic hatches in savannah area
- info 4 91 crx swap
- y i have a 91 hatch with a dohc zc and the bottom end is making some oiseFix my dohc zc or go sohc v
- fabricating a roll cage for my civic need tips and designs
- how much is west wings body kit for crx is worth to sell?
- Does 90-91 CRX bumper lense's fit 90-91 Civics bumpers????
- b 16a swap into 89 crs si
- molding kit from majestic honda...
- Auto tranny question will eg tranny fit in ef?
- what is the exact miles per gallon for a CRX HF?
- Should I buy this crx?
- 02 civic hubcaps fit on 14in steelies? or what?
- LS-VTEC, CRX, OBDO-OBD1- injectors not working
- D16Y8 OR D15B7
- 91 Civic w/ D16A6 code 7 - TPS sensor
- quick question
- need your help guys
- Anyone try these cheap door moldings?
- 1998 d16 in a 1990 crx
- temp gauge
- trouble when stating warm?
- fuel lines
- Weird starting problems
- Cars not starting
- TurboXS DTEC Gauge Unit
- emissions suggestions PLEASE.....
- rim choice
- Transmission problem?
- ecu isse
- possible thermostat/water pump/over heating?
- Is this fixable? bent suspension/control arm, need help asap! pics inside!!!
- can some one tell me
- vacuum leak or iac?
- ANOTHER QUESTION LAST ONE
- GOT ANOTHER QUESTION???
- 88 honda idle ques.???
- SOHC ZC into HF.....what ECU?
- Need Wiring diagram for center consle
- OMG !!!!!!!!!!!!!!!!!!!!
- Ground Control Coilovers and KYB AGX on CRX with GSR Swap
- crx commercial?
- quick question about brakes.
- d14a4 valve clearence
- Running really rich (Code 1)
- Blower Motor Only Works On Setting 3 & 4?
- Someone HELP?
- Body Kits ??
- D15b2 bad - D15b7 long block using b2 dpfi, etc???
- crx si lip on a hb
- mpfi with gsr swap?
- WHY DOSE MY 1990 CIVIC...
- whole in block
- Too many issues to name! 89' CRX Si, B18B1
- camber problem??
- getting a code 9
- JDM Cluster Question
- will dc2 rear disc brakes fit an 89ef hatch?
- Another "new" crx si and new member
- b18 in my 88 hf
- ef8 SiR front bumper ?
- swapping y7 intake manifold
- QUICK QUESTION (JDM FRONT END vs. USDM FRONT END)
- Electrical bullshit!! need help!!
- Odd wiring issue about the alternator. Needing quick help.
- b16a into my ef plz HELP
- b16 into my ef help!!
- K-series Swap Q's (Toda Powered)
- ***brake problem on ef! HELP!***
- n00b's 1st post on HT.
- new hatch
- just got a new 91 hatch...
- Intermittent wiper upgrade problems?
- what obd1 dizzy with dohc zc?
- Starting issues and battery overcharge (90 hatch)
- rod bearing question...
- Advice on tires...
- what shift linkage with innovative mounts ?
- ewww painted interior...
- Classic plates?
- CYP when swaping in a obd1 motor?
- calipers
- Electrical problems...tail lights??
- turn key and nada
- ooh, rhd dash tray... look what i found! super rare....
- b18 intake manifold
- how much power is to much
- RHINO??? adj. upper control arms 88-91 civics
- Which headgasket are you guys using on boost motor?
- some advice
- Brakes
- Which ECU would be better to run with my d16a6/y8 minime?
- HELP!! Code 16
- Exedy clutch guru please jump in!!!
- NEED HELP!!!
- I need a part for a 1981 civic station wagon... where?
- new to ht
- a little crx humor
- Trouble starting cold
- JDM front end for USDM front end?
- 86' 1st gen. swap?
- crx/civic mirrors pinout or info needed
- pr3 ecu vs. ls/vtec
- california zc smoggin
- 2 Crx's...Which should I choose!
- Any ideas on how to replace a dented rear quarter panel?
- tanabe lowering springs
- eg fog light into the 91 crx si front bumper
- Average SI Interior Costs.
- Flywheel & pilot bearing
- Theft rate and insurance rate of civic hatchback vs crx
- Ef being built with parts layin around...heres the start
- HELP on mini me
- WATS THE DIFFERENCE??
- shift linkage????
- Fluctuating RPMS
- Just picked up an 88 Rex for CHEEEEP!
- Motor mount
- Aftermarket LCA's
- bolt demensions asap plz!!
- weight difference between 88-89 90-91 HF bumper supports?
- connector
- Wiper motor location on a 88 dx?
- water leak
- mpfi nightmare
- What gauge is stock battery cable/ post up your distribution block placement
- Cable clutch/ Hydro clutch- Question??
- How??????
- Where Can I Get The Gasket/O-Ring Around Injectors
- Bought a CRX and I Have a few questions..
- took off tb
- ef squad
- 84 civic redline??
- crx won't turn over, battery and starter check ok
- question about vitaras in a z6 after rebuilding!
- coilovers on 89 lx
- white smoke
- I need a link and i`ve been searching!
- b16 vaccum lines?
- Wipers are not returning home?
- 95 integra cluster in a crx?
- glowing cat?????
- EBAY Tachometer accuracy
- REF manana, service connector Q
- My EDM 1.6i-16 CRX +Clutch Install Pics
- Car starts slow...then picks up speed.
- look if you have an sir ->
- 91Si motor in to a HF
- Hey new guy
- DA bb and mastercylinder ?
- D16A6/Y8 mini-me adjustable cam gear question
- camber kit
- ef motor swap
- Sunroof Issues!
- 2 doors, one key
- Spool for a 1991 civic auto trans??
- Engine Mismatching.
- Distributor Question?
- SI TO LS ?
- 2 yr old DC header
- tri-y header clearance for EF crx (b16a)
- GSR rear seats in a EF HATCH?
- exhaust leak
- passing for inspection
- thats weird
- 4-1 Header Clearing Sub Frame?
- fuel problem?
- proper way to check auto tranny fluid
- MULTI POINT CONVERISON FROM SI TO DX
- can a 89 pm6 ecu from crx si be chipped
- //// NEED COILOVER HELP
- ECU!!
- d16z6 assemble
- Deal or No Deal
- throttle body question
- can i boost and use a afc??
- CRX Heating Problem
- Kinda dumb question. How to adjust ingalls camber on crx?
- tranny
- Car shaking...
- need help
- dpfi in a swap
- jdm side molding
- I need a sound clip of the HKS Sport
- Wiring help with ef and a d16z6!!!!!!!!!!!!!!
- Fuse Keeps Blowing
- Engine Problem, See if u can help. ???
- Fuel Injector *Help*
- Help with power windows for EF8
