View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Code 7, switch TPS several times
- Now that My Motor Fits.....It Wont Start! HELP!!!
- Just purchased 88 Civic Std or DX?
- civic EF hatch rear bumper differences?
- motor change in my 85 crx
- CRX Gauge Cluster
- Camber issues when traction bar installed
- Should I buy this CRX???
- EF9 "Cheap Tricks"
- what to do with insurance money
- RHD REX
- Could some one post pics of there vacumm lines?
- My B16a Swap in Progress Pics
- what setup should i go with ?
- Wheres best place to by HKS sport exhaust???
- HID ballast ??
- Small ammounts of rust?
- temp gauge...or electrical prob...or overheating issue..HELP
- is building a d16a6 worth it?
- 3rd gen civic HELP!!!
- just got my Rex
- Vtec Head on a ZC. Can it be done?
- car down
- New Honda Guy.
- OEM Honda power
- 89CRXsi - Which speed bleeders fit? Anyone tried Speed Bleeders from Autozone?
- map sensor
- Finally found my car
- Looking for Camber Kits
- how do i make my 89 hatch jdm
- no oil light
- Brake problems making me go mad!!!
- CRX for Sale, NOT MINE!! $2,995 obo
- EK Seat rails
- what motor comes in a crx hf
- need crx pics
- white smoke wizards
- New 2 Honda and need to learn. 88 HB DX 2 sohc VTEC
- puzzled why hatch won't start....
- Drieability question OBD1 SOHC VTEC swap in 90' Std. h/b
- What to look for in a real Mugen Header?
- Installed 89 Prelude Master Cylinder on the Crx (results)
- Smelling an Oil Leak!!! Need Help Quick!!!
- 3" exhaust on a na b16
- SPARCO SEAT AND 5-POINT HARNESS SFI APPR
- removing rockers
- skunk2 springs???
- 90-91 Si seats into STD?
- WTB: Hood and Passenger Fender
- hey guys quick sunroof and trim q (i already searched)
- '89 civic dx burns oil
- useing gsr manifold and head in an ef body
- Whats the latest status on the EF Omni Power Coilovers?
- Help me diagnose a problem. Fuel pump is not working, V-AFC not working.
- stripping interior...how do i get rid of this?!
- NEED MAJOR HELP WITH ZC TIMING BELT!!!
- H22A1 in a CRX...
- DOHC ZC cap + rotor
- a LOT of smoke
- FS 88 CRX HF MANY MODS AND EXTRA PARTS
- rpm signal ?
- OBD0---OBD1 Again and YES i searched
- Radiator fan not turning on? (please be nice to the noob)
- ***90 CRX Si PARTS WANTED***
- wtb 5 speed tranny for civic crx 88-91 asap in midwest, chicago wisconsin area
- make her lighter
- Weird Plugs under Hood
- Solid Red LED ecu, Limp mode, what would cause it?
- Best engine swap for a daily driving CRX.
- Question d15b swap
- Tranny Help!
- Need help - Starter problem or main relay?
- electric waterpump
- LOOKING FOR 92 EG TO BUY!!
- pic request: SI rear sway bar bracket
- project 1986 crx
- 89 CRX DX GAUGE CLUSTER WIRING
- Crx's w/ rear lower tie bar
- opinion on how to start out
- A/C Swap from DA integra to 88 hatchback
- Digital Horsepower Readers????
- AC question help summer heat
- ef with tein springs
- Crx Gas tank door relocation
- how to get out 88 back seats?
- i think my guage cluster shorted out
- What clutch for my 1st gen B16A cable tranny??
- Loud Tranny
- HOw would you go about...............?
- USDM to JDM CRX conversion
- d16z6 vs b20z: (Cost, and effectiveness)
- fuel on the ground around car !!!
- Why drive a CRX?
- Your ideas for my CRX...
- what will my track time be like with my setup
- 90 CRX SI no spark
- 88 crx firing test?
- Swap'd n Boosted CRXs w/ EG rad sign in....
- idling problem??? help!!!
- cabin filter for my car? any1 with knowledge
- Intake Question
- Will struts fit?
- engine installation $$$
- BLINKERS DONT WORK!
- Just got a Crx with no engine, I need ideas for the engine!
- 91 LS tranny LSD
- 91 Ls in 90 hatch
- 88' Civic engine swap questions?
- What Wiring will i need for D15B2 mini-Me swap with MPFI swap also??
- CRX Best FWD?
- how do i time my non obd b16
- NEED DISTRIBUTOR
- Restoration of my CRX will be finished soon..
- RADIUS ROD
- Ideas to deal with the Texas heat in my rex.
- CRX Cooling Fan system
- fuel rail nut and washer?
- A/C Hot/Cold Knob and Panel? Where to find, which will fit ? 89CRX
- 2006 Honda Crx
- ls/vtec or poormans type r
- Honda Civic wont start!
- Air intake question?
- 94+ Integra cluster into EF; fitment
- b16 dizzy on b18b
- INVITATION
- Engine shuts off, V-AFC shuts off, and oil light comes on
- Wiring in MSD blaster 3 coil and MSD 6A.
- Main Relay woes.....
- LS/Vtec wiring
- way high idle prob...
- A/C controls fan switch
- how to check CEL's
- need obd0 b16a distributor!
- v-tec
- Buying a CRX
- windshield.....
- Weird B16 harness
- CLUSTER SWAP HELP!!!!
- D15B2
- Hey Honda Guys...
- building a full race crx
- Headlight positioning..
- C Pillar bar for EF Civic in carbon fiber?
- Need help from you fellow B16'ers
- whats better???
- Question about engine swap?
- need D16 block
- CRX interior swap
- need to buy new cluster
- My Project 88 CRX
- ls/vtec swap/na or turbo questions
- my civic "stolen"
- Looking For Body Parts
- '87 integra seats in '89 CRX?
- Looking for a pic of hood for LS/VTEC swap
- Somethings wrong...feels like I have power steering.
- turbo LS non-vtec parts list
- 1990 CRX miss....
- d15b7
- turbo timer
- U.S. & Canadian Honda Part Numbers ?
- CRX Electrical
- How do you make 12 sec. CRX
- FAQ: DIY: How-to: Fuel Pump Cut Off Switch
- Code 9, questions.
- Which clutch to buy??
- Ex knuckle/brake clarification
- I need your judgement.
- B18a JRSC
- speakers
- Traded my B16 Si for a 91 EX
- Question: starter---battery --my car wont start question
- 12v ignition problem
- pm3 ecu help
- Head problem!!
- wanting to buy swapout motor
- FS: complete JDM type R
- power always on?
- Needed : BLOCK OFF plate for the Evaporator hole on the passenger side...
- Those of you with tall front moutns, please tell me how..
- any one ever dealed with noyan-usa
- valve adjustment?
- planning to buy a Jdm d15b for my civic, questions!
- Ryan Basseri, are you out there? OBD0 to OBD1
- Lemme know what ya think of this!!!
- Finished installing ZC, a few strange issues
- HELP!! PLEASE, Doing VALVE Adjustment on SOHC
- CV problems
- I want to strip teh rear of my CRX and...
- finally getting my swap done cheap and fast
- Simple front crossmember question
- 91 civic dx with airbags?
- Shift Light on Hf I.Panel.
- Hesitation + Miss = igniter?
- taCH wiring diagram ?????
- B16a Problems
- D16 pistons
- high idle after master cylinder swap!?!
- D16z6 falls flat at WOT. Dont know what to check
- what is the bore size on a b16 bored 20 over?
- My exhaust is on
- vss (speed sensor)
- Who has the fastest rex?
- HELP me out....uggghh!
- New to HT
- is sleeveing really neccessary on a b16 turbo?
- Sell my CRX??????
- Engine Swap Process: Lightweight weight or stock pulley?
- Need some help
- Need Help On which exhaust is better.
- need help 80 somethin race civic....
- automatic transmission adjustments?
- place racing
- leakage in the car
- Can you interchange the gauge cluster Cover between an 88 style dash and 90+ ?
- What sort of Bhp will this give me ?
- 98 Civic DX motor into 88 CRX DX. Possible or Even Worth It?
- maybe alternator going bad?? car no start.
- sohc questions
- Vacuum lines on an 88 DX/ZC?
- Do i need to convert to mpfi while conv. to obd1????
- bumper lip
- ecu burn
- Pilot bearing help.. On 88Hf
- CRX FUEL PUMP PROBLEM
- 88 CRX radiator help
- 25 PSI on a stock DOHC ZC Look what happen!
- 92-95 eg front seats in a 89crx?
- help!!! bad idling
- 89 crx si cluster into 88 civic hatchback dx
- OBD-0 B18B into 91 Civic Si
- MY MOTOR WONT FIT!!! Anyone have any solutions?
- Found this "Very Rare" Mugen CRX for sale
- i need some help plx
- **MINT** 91 WHITE 4 DOOR
- CRX seats in an EF?
- quick question! h22a1 or h22a4?
- zc swap
- 2000 integra brakes in crx?
- REVIEW: Megan racing header for B16
- What is this and where does...
- Thermal R&D Exhaust
- Will a Si throttle body bolt on to a HF head?
- CRX hoods
- how often to replace rad. cap?
- JDM product importers?
- code 16????
- 2 Radiators, 2 FAns, & New Head Gasket and yet Still Overheating???????????
- Which Ecu? D-Series guys help me out
- Zc nitrous
