View Full Version : Honda CRX / EF Civic (1988 - 1991)
- crx questions
- VAFC HACK NEED HELP
- intakes
- Fuel tank full but gauge at 3/4 tank? Why?
- ZC swapped hatches...
- Yes or No? Fidanza shifters
- crx gsr..should i? im in cali i can BAR it but is it fast?
- Help Failed Smog Big Time in CA
- A/C questions
- Axle Seal Replacement, what seal?
- did my ecu reset itself?
- 86 Civc Heater Core removal
- Konis (best price)
- A few Brake Questions..
- ls vtec
- post here if you are working a d series motor
- How to remove right side axle.
- weak ass rear defroster
- B16 Displacement vs. lsvtec
- Tokico Blues
- D16Z6 => 87 CRX
- CRX Dash swap questions...
- i need help with wiring a 5 inch monster tach
- How do you shave door handles
- climate control crx 89
- fitting a d17 in a 91 crx
- question about oil pans...
- tranny to block bolt hole stripped
- crx suspension advice wanted
- while my CRX is in the garage for the winter...
- FL Civics/CRX w Urethane Body Kit, Warping Problems From the Sun????? Anyone
- B18C5crx's new project (56k go to sleep)
- who sells a smaller Radiator for a crx ????
- finally got my 14.8 d15b vtec slip
- steering wheel
- Hottest/Fasest First Gen CRX SI?
- CRX RACE
- cant get my valve spring on :( need some tips to get it on
- Did my DA front brake swap tonight...
- body kits
- It feels like I lose a cylinder sometimes
- Need a measurement.
- Are Phantom LSD any good
- Bolt on Hitches..
- 91 civic starting problems lately...
- 88 crx. 90-91 doors but not seatbelts possible?
- exhaust question
- b16 question
- speedometer rattle?
- will the front springs from an eg fit an 89 crx?
- problem with CRX bumpers, need help now
- help have a 88 civic hatch
- crx + turbo + bov + Turkey call = not so funny video
- SAFC 2 wiring for PM6
- help with new struts
- Major J-spec d15b issures need hel[p fast
- 4wd civic
- 90-91 Speedo Sensor different then 88-89?
- crx wiring and shift linkage -HELP!
- How many rattle cans...
- jdm itr gauges
- jdm conversion for 91 crx
- D-Series LSD trans for $995* gauging interest.
- Anyone have the 10.2" FastBrakes kit?
- Broke volve cover bolt!! :(
- Mounting a digi cam inside your car.
- where to buy JDM 4dr conversions??
- Who here has a Y8 Head on a stock B2?
- need help my hood closing properly
- Prelude brake calipers
- What needs to be done to my car in order to make it run?
- 90crx dx to zc not working. :( need some help !!!!
- CRX in need of help
- spark plug analysis?
- Code 17 (VSS) No Vtec after EDM Cluster install
- jdm power windows/switchs
- Omnipower's EF Full coilovers are now out....Yippie!!!
- DIY respray questions?
- Walboro Fuel Pump Issue
- CRX and Hatchback Door Panels (Cards, whatever)
- problems with b18 swap
- CEL 90 CRX DX?
- Special tool to remove chankshaft bolt?
- j-spec d15b with er si ecu, need help
- 85 civic... need help with vacuum garbage
- Bigger Brake/Rotor Option? - Keeping 88 CRX DX Knuckles!!!
- obdo to obd1
- Need help ASAP anyone that is awake please post
- my crx needs doors, its getting cold
- injector question
- need lots of help please!!! EF civic
- B16A, need throttle help
- B18CR TYPE-R swap into my Honda Civic Wagovan
- Strange prob with engine swap
- Which Header?
- JDM climate control
- need advice on swap
- Got Spark, Got Fuel, No Start....
- oil leak from where tranny meets the block
- will 92 integra sway bars fit 88-91 crx's? what about if they have the teg suspensions?
- quick question bout this engine setup
- B16 Civic Shakes While Driving Normal
- radiator swap
- Look what i found at work!! 1987 & 1991 accessory books
- Cool product for the hardcore AutoX/Road Racing people
- Quick stupid question....
- Rear wheel bearing install (done hopeufully)?
- i need an answer to this
- question on my RHD conversion
- Opinions on Exedy organic clutch?
- Quick question about DA front brake lines....
- Hood lock part number?
- Fuse #12 keeps blowing, short?
- conquest/starion seats. anybody tried them?
- 1500S Firing Order
- New to the world of Honda, how can I get more performance out of a D15B2 engine?
- help on my zc engine
- b16 head gasket what will fit?
- quick ??? on interchangable 88-91 CRX parts
- Should I do it or let the mech?
- problem with my stocker - valve/timing belt issue?
- zc axles
- conversion harness
- Poping noise when i open my door??? Pics inside
- Brake upgrade
- is there suppossed to be a brown ground wire...
- headlight exploded!
- So I finished my MPFI swap ! !
- will a eg mpfi intake manifold work for a dpfi->mpfi swap?
- Altenator Replacement
- Race seat
- really need help w/dead 86 civic si
- Shock or Strut?
- 88 Civic problem...please help
- how high comp?
- B16 code 21 and 23
- i need a pix please
- Need Some MAJOR HELP!!!
- has anyone installed aftermarket lower trailing arm bushings?
- Steering knuckles on EF with B16
- turbo d16 camshafts ??? crane?
- DA radiator installation
- turbo d16a6 camshaft
- DX > SI distributer wiring
- Crx with 13,000 miles..
- b16 not starting...have power but just a hum when i turn the key?
- what is interchangeable?
- SI CRX Ecu Putting it in a DX civic 89
- climate control problem! help!
- From Nothing to Something! Extreme CRX Make Overs and Recoveries
- Lost to an explorer?
- Gunmetal Grey
- D15B help
- HELP!!!!!!!!!!!!!!
- d-series VSS
- crx si ecu
- Single stage Paint on EF's ??
- honda tunning magazine gray crx
- ahh what header will fit my b18??? im confused
- Fuel pressure problem...
- Emissions problems!!!!!!
- EF 4wd waggon
- Not much.
- b16 vs. b18 what would better suit my CRX?
- FS: jdm EF8/EF9 ZC cluster -240kmh..........$65shipped(nor cal)
- FS: jdm EF8/EF9 ZC cluster -180kmh..........$65shipped(nor cal)
- any write up or pictures on installing racing seats into CRXs?
- fiberglass parts???
- CRX Si w/ GSR Motor ( rad hose ? have searched )
- REF'd B17A1...Can i be a member of the BAR club? lol
- HOW-TO: Setting your Odometer to it's proper mileage.
- B16 ECU
- Z6/Y8 Distributor Questions OBD1 OBD2 Timing
- b16 Oil
- rebuilt civic, now wont start.
- code 21 please help.....
- Radiator Fan Question / Diagram Request.
- str 570 cam gears good???
- where can one buy a d16z6 swap?
- using d15 altenator on b16 ?
- Does it matter which way the thermoswitch is wired up?
- drivers side heater vent----crx
- stock 88' crx hf front sway bar size?
- Traction bar
- Anyone ever run into a problem like this ? ( axle related )
- A6 + ARP ??
- Water leak....from the bottom?
- Autopower rollbar question...
- Car trouble... need some help.
- Looking for a DIY weld-in NHRA compliant cage for my CRX...
- Please help me not sound like an idiot: need correct terminology for 87 CRXsi wiring harness
- 3 inch down pipe on my EF8. Do I need to swap out my crossmember?
- What else do I need to convert from Obd 0 to Obd 1?
- bad gas smell from exhaust
- airbags
- Convert your obd 0 B16 (2) single wire O2--->to (1) heated 4 wire O2 ?
- Gsr guage cluster
- REX STOLEN! SAC, CA area and Roseville, CA area.
- where can i get some JDM tail lights for my crx?
- my Integra center consoul & armrest in my 90 Si hatch
- which tranny do i have...no serial number
- OEM Honda Parts from a Dealership...a Racket?
- Starter Relay
- A possible swap for crx(automatic) and keeping it automatic
- Fireing order
- Question about service limits on D16z6 Cam?
- EDM SiR Gauges into USDM CRX
- y1 tranny. and sir axles
- Where to buy a stock civic Si H/B bumper??
- www.norcalcrx.org The Northern California CRX Club! *new site* *badder ass*!!!
- B16 0r b18 motor for sale let me know details inside
- WTB...crx cheap...
- ef hatch.. boosted
- where to get a roll cage
- Time for a new harness??
- HCP Mounts.........
- value of a DX tranny?
- Obd 0 to obd 1 conversion harness help.
- Are Exedy clutches any good
- Busted Tension Pin in rear drums of CRX
- Ok so now what the hell do I do?
- Oil Annunciator light
- how does del sol rims look on a ef hatchback
- trying to hook up a vafc2
- how do you distinguish between pressure plate or clutch problem????
- whats up
- Distributor help
- Where are fuel injectors located on 91 civic dx hatchback?
- quick cable tranny question
- So i let my friend drive my rex
- LS swap questions
- EF 4dr. seats in a hatch?
- CRX SHELL
- Del Sol seats
- 89 civic ignition f'ed up
- Replacing Heater Core help
- DA integra brakes on EF chassis??
- 3rd generaton civic lip fits
- DPFI 2 MPFI resistor box wiring
- code 8
- WTB: jdm front end conversion
- 91 crx si, battery light (new alt, new battery, good ground)
- Has any one tried this yet.....
- Help with tranny reverse idle gear??
- no power in 4th and 5th in 87 CRX (1.5L carburated)
- 91 Civic DX ---> k20 vs h22
- just noticed PR3 cam gears on LS any more power from this?
- suspension trouble
- How to add intermittent wipers to your base 88-91 civic hatchback
- POS hood stuck 89 Hatch HELP HELP HELP
