View Full Version : Honda CRX / EF Civic (1988 - 1991)
- red gab sport wheels
- clanky noise
- MPFI SWAP PROBLEMS "HELP" "CODE 8" CAR WONT START
- California BAR'd EF's w/ OBD1 conversions?
- Anyone ever try this?
- 91 crx si want another opinion besides my own
- mini me vtec ? z6 head and sohc zc block or dohc zc block?
- Replacing trim below window?
- 94 Integra LS with Hydraulic trans into EF. Which axles?
- i need a close-up pic of a complete a6 intake manifold+ tb
- new CRX mats on ebay
- i have a 88 crx si............
- 88 CRX Si(B18a) Camshafts.
- z3 fernders
- 1989 honda civic dx fuse box
- whats the best clutch for b16
- HF Mani Question
- What Code is this
- B16A2 1990DX SWAP HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Re-loacting Fuse Box
- PGMFI to MPFI...
- code checking in an obd0 to obd1 conversion?
- anyone ever spray a non-vtec motor?
- 1G CRX Questions...
- Engine swap
- Need b16a oem header
- Help! Steering Rack Problems
- rear seats?
- speedo cable
- Wiring dx to a zc.
- Anyone know what this is?
- zc tranny in 88 crx si
- I Need A Passengerside mount
- what do you think??
- Help! My car is not running right, would start than die immediately!
- Larger ef forum?
- o2 sensor
- Need help choosing the right engine mount for B18c1
- 1990 Honda Civic Hatchback SI for sale 949-351-8437
- help..
- Need unbiased opinions (EF vs EG)
- si cam in d15b7 yay or nay
- axle problem
- Tranny question
- MPFI'ed d15b2 w/Si camshaft timing question...
- Best ecu for GSR setup in an EF hatch?
- Just bought z3 fenders
- Weird speedometer problem?!?!
- Hey Stock Bumper question
- Is there anything I can modify with my car to make it fast
- Moving O2 sensor on aftermarket header with obd 0. Worth it?
- Need help w/ side panels and dash...
- 88-91 Si fuel hose: Can it be used on a 92-95 fuel rail?
- 90 dx hatch throw out bearing
- zc crx problems
- '94 + 'Teg Ground Controls on '89 Si?
- Failed emissions 3x, next on list oxygen sensor location?
- Best light output?? -> 9005 conversion vs. Polarg/Raybrig H4H
- d16z6 block, y8 head.....pm6 or pg7 ????
- B16A finally running
- estimate my max boost
- SIR tach into stock cluster?
- B20 B18HEADS OR B16 HEADS WHICH ONE CAN N E ONE HELP?
- Newbie Just saying whats up
- woohoo! no more cel!
- Teg rear brakes question
- B16 Civic for sale.(SO.CAL)
- hydro conversion
- Engine question on 91 Civic
- Ls seats in 88sedan
- Vacume Lines 88DX to Z6 manifold (MPFI SWAP) SEARCHED :(
- need jdm b16a timing belt
- 1990 civic motor swap
- No Y1 tranny replacement parts?
- HASPORT: Story about axles for B16 into 88-91 Civic/CRX is Back! link inside
- NEED ANY PARTS.... crx,itegra,more
- Rear Rotor size for crx/integra?
- daily driver boosted d15b2 questions
- tach fo sell yo, its the coolest
- burning lots of oil at idle
- Newbi from tha other side!!!!!!
- Bought Integra Seats What now
- are STD calipers same size as the SI/DX?
- Still cant separate L3 tranny bell housing
- AEBS typhoon manifold , FITV hoses ??? ,,,, just installed.
- have to use the key to lock the door, why?
- Paint bumber?
- jdm b16 4 sale
- b16a swap question
- Prelude Fog Light Install, going to do write up... need pics.
- Opinions on my turbo kit...
- road vibe tarmat crap
- Need help with LS Civic value
- Compression Numbers on D15B2 too low?
- FPR needed with 255lph pump? yay or nay
- R134A retrofit - NEED INFO
- Racing clutch or not??????????/
- Where can I get a 3" mandrel bent exhaust for my 91 si?
- tires
- ECU Codes?
- Need advise on what the best engine(Boosted) for my 95 hatch would be currently have a d16A..
- Looking To Trade Trunk Lid With APR Wing For Stock Trunk Lid.
- new Honda owner, new member
- need help!!!
- GSR fuel pump
- b16 swa questions
- detent balls, anyone get this far.
- what motor do I go with?? D15b or D16Z6 or D16Y8 Help!!
- IACV wires
- WTB: IACV for JDM b16
- D series? or B series?
- Can Someone Clear This Up For Me...
- if you have 89-90-91 CIVIC HELMS
- What would you suggest for an si motor?
- FS: b2o turbo swap 88 crx si
- Inline Fucl pump question
- hose diagram
- I've Searched and Cannot Post in F/I Either....
- Can you identify this fuel filter?
- Good shop for a clutch in LA
- oem brake upgrade, is 10" big enough???
- Troubleshooting help needed; b20vtec crx with misfire and map (3) code
- ECU QUSTION NEED HELP
- CRX B18C1 NOISE PROBLEMS
- Civic engine swap -- what are the options? Need the car to be "balanced" still...
- check this out please
- RS-R Ex-Mag Exhaust Systems
- camber kit... confused about camber. ingalls extreme kit users plug in.
- EF>B16 wiring services?
- si guage cluster
- Need advice on replacement bushing kits
- Paint prices on your EF
- need pics of turbo EF exhaust
- 86 Crx si leaking coolant...
- Type R cam gears on a LS/Vtec B16 head?? any good??
- '90 DX DPFI to MPFI relay buzzing under dash!
- CRX LS/Vtec Bogin like a muthaF*#$... HELP.code 4 here..
- ecu trouble code?!?!
- Tranny problem
- probably been asked before but..........
- WHAT'S WRONG WITH MY CIVIC CAN N E ONE HELP?
- whats the differents between obd-1 and obd-2?
- 420!!!!
- RUSTED BRAKES....
- daaaang, check out this crx
- car runs like crap need help
- CRX BACK SUSPENTION ARM...
- tuning question
- Injector size?
- What should my fuel pressure be with my mods?
- calling all people in the middle,TN area......
- FINISHED MY PROJECT THX GUYS!! One more small problem tho ..
- anyone want a VIS JDM cf hood?
- resetting my ecu
- Ok, here it is boys!?!?!?
- crx exhaust?
- where to get a jdm front end for a hatch?
- differences in weight : 5th gen civic
- pipe size
- Advanced Auto Parts Axles......Are they worth a crap??
- What do i need to swap the b16 head on the b18b block
- Should I get W.W body kit?
- is $650 for an ls tranny good.
- Tips on a new 88 CRX? (B18A1 swap)
- PM6 vs PG7: Emissions wise?
- need ur help on what else i need.?
- LSVTEC Dyno Runs
- B16 idles at 1500 constant
- A/C Expansion valve
- is there such a motor as "D" series JDM SOHC VTEC ?????
- ATL , Georgia People...PLEASE READ THIS
- Is 500 good deal for d16y8
- MX-6 turbo on D series...
- Cant get rid of Wobble that starts around 50mph after Swap, Need some Ideas!
- Teg throttle body on ZC?
- Old school Rex meets ZC motor ?
- Falken Ziex Ze512 195/55R15
- will d16a6 cylinder head bolts work on my d15b2
- Update on swap..
- how much $ to have a shop change head gasket?
- Hondata, VAFC, or Greddy eManage?
- air fuel ratio question... need answer asap
- Building a rollcage.... HELP!
- air bag deployment sensors
- are the front dx and si calipers the same?
- Cleaning up the engine bay... what goes, what stays?
- D15B2 on Nitrous....
- Stock CRX Si roadholding?
- header o2 location question
- swaybar info
- Newbie with 91 crx...needs help and suggestions
- What is better? D16A6 TB or D15b7 TB?
- p28 surges at idle after reseting ecu ??
- wich axles
- Resurface flywheel after 10K (changed tranny)
- LS/Vtec, obd1 gsr, obd2 gsr, what do u guys think
- MASER CYLENDER
- swap runs really to cold, and wont warm up and will hit cold rev limiter...
- rpms driving me crazy
- *SNiff *SNiff....She's gone fellas....
- 89 CRX mirrors
- engine
- One more "my car won't start thread"(ignition switch maybe?)Please help
- IACV ?
- Skunk2 Adjustable Upper Control Arm??? YAY or Nay???? Pros and Cons
- Sidemolding on 90 Crx? Yes or No
- Can somebody help find me a CF Hood!?!?
- lower strut tie bars
- 89 CRX rear suspension squeaking
- throttle body
- 91 Civic HB DX, Doing ls engine swap, What cable tranny should I use
- intake manifold?
- b16 swap in, rev limiter at 7500 rpm, code 22 (VTEC press)...
- Clutch Opinion
- What is this bearing called??
- oil line or no oil line in a mini me swap
- upgrade master cylender?
- dizzy
- Need help IDing a TB (pre-93 Teg or D series?)
- 1.25in drop with 17s
- lsvtec in my crx wont start need help
- after swap droped car on wheels and this part fell on ground... what is it!??!
- b16 intake
- Idle Problem please help
- Integ armrest/center console mod :thumbup:
- jus thought i might share
- What is on the throttle body
- cracked jdm ys-1 case. what crosses over from acura so i can order?
- Loose shifter?
- engine questions
- Looking for seats!!!!
- msd ignition
- MSD on the crx please help!
- need help.. put new head on..
- cat VS hollowed cat?
- I'm too lazy to take pics of my plugs (lean and not mean)
- buying a hatch...
- Intercooler w/o Turbo?
- Whats this car worth to you EF experts?
- Almost done w/ Fuel pump, few questions
- no passenger mirror on 91 dx:what did you do???
- Civic Pinouts
- If u own a 4G civic u gotta look at this
- WHER ARE MY INJECTORS??
- Did search nothing. Spark plug wires setup on distrib.
- hf vs dx vs si intake for mpfi swap
- replacement parking brake handle
- d16A1
- new throttle cable for mpfi swap????
- Seats IN 89 DX HB
