anyone see a pattern with this bad luck
Old Sep 4, 2015 | 03:01 PM
myefhasaname's Avatar
Default anyone see a pattern with this bad luck
1991 civic with a b16a swap running p28
so motor stops on the freeway and the motor would no longer turn over. get it towed home. first i find a bad igniter unit, next i find 2v at the main relay when i should have 12v, then i find a bad alternator, and finally i find 9v on my vss 5v ref wire and no continuity between the vss and the ECU. been a rough month for my car. can anyone see what might have caused all this, or was it just shitty luck.
thanks brothers.
p.s. she is back on the road but i haven't run a new wire from the vss to the ecu yet
Old Sep 7, 2015 | 04:07 PM
BLU CIVIC's Avatar
Track Advocate
Default Re: anyone see a pattern with this bad luck
Previous owner shortcuts?
Old Sep 7, 2015 | 06:35 PM
i wish i knew. alternator is new and battery is still dying -_-
Old Sep 8, 2015 | 08:56 AM
whited's Avatar
CRX God
Maybe a voltage spike caused all that damage?
Aug 2, 2008 03:59 PM
JdmEG6Si
Dec 30, 2007 08:30 PM
JdmEG6Si
Dec 29, 2007 03:15 PM
=-JDM-EG-=
Mar 17, 2007 12:11 PM
