View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 87 crx motor options HELP
- Anyone in washington state interested in a mugen 6 peice body kit *CHEAP*
- 88 Crx Rear Shock Upper & Lower Bushing Set, Where to go?
- Timing belt cover DOHC ZC
- which seat rails to use in my 88 hatch...help
- Best way to go vtec
- will a 2nd gen zc work for an 88 crx si?
- carbon fiber wings???
- black housing headlights????
- D series cams? (searched)
- DOHC ZC Questions
- desparately seeking zc in southern california, need it before spring break ends!
- Pics of freshly cleaned engine bay and car - JDM B18C Rex - *56k warning*
- KYB AGX's in and THEY @#&*% ROCK!!!!
- top caliper bolt is stripped!!
- where can i get a camber kit for a 88 crx hf lowered atleast 2"
- HEY, YOU!!!!!!!!!!
- What to do with my BY 90 Si
- Is this the correct ST Sway Bar?- Want to make sure
- J's racing/ Imitation J's racing intake
- 90 civic Dinan ECU - ?'s
- 88' Civic DX Hatch threw up
- Gauge cluster swap into 89 CRX Si *ALREADY SEARCHED*
- Need to replace my engine
- D15B2 Mini-Me Shopping list complete?
- Code 6 10 13??
- Which quiet 2.25 catback exhaust will bolt right up to CRX w/ B18C, JDM ITR header, and OEM ITR cat?
- ECU Question
- WTB 88'-91' HB, my 88' had a battle with a falling tree and lost :(
- What injector o-rings to use?
- b-series valve cover!
- Whats a good STIFF single setting Shock for a good price???
- Ecu Question
- Who Has An Idle Screw Picture?
- Jim Fab Crossmember clear 3" downpipe?
- obd1 ecu question....
- What would cause my car to vibrate around 60mph?
- How much should I expect to pay for a CRX?
- need help with why my flywheel keeps coming loose
- How do I hook up an ITR headunit in my crx?
- Tranny Caseing Question
- Lookin for 90-91 civic amber bumper lights?
- EDM CRX VTEC LEATHER SEATS
- 87 civic motor problem...daily driver
- What kind of front lip will fit on 89 CRX OEM bumper?
- favorite sohc header?
- oo my bad about second post del sol strut bars
- jg throttle body...
- obd1 crx
- roll cage in pittsburgh
- need help with my 89 hatch
- Looking for Catbon Fiber body kits
- Quick question(90 civic dx, b16a swap?)
- CRX with a 92-95 civic front?
- Bubble in my relatively new tire, about half an inch diameter
- door or seatbelt sensor, 89 Si?
- still scratching my head... *pics*
- Rough Ride Questions in my CRX
- Volt drop in my injectors
- 2001 15 inch steelies onto 89 hatch, will they fit?
- Anyone needed their motor swap?im in So.Cal
- Anyone know what is the longest Honda flywheel bolt??
- Body Rust Fix
- 89 civic hatch with turbo.
- DID MPFI not getting spark im guessing dist...
- question about tranny
- which engine?
- Black box under IM bracket... What is it?
- Do you thimk a DOHC ZC can pull a 15 sec 1/4 or better
- A few more motor questions.....
- Valve Cover Bolt Torqe Specs? How many lbs?
- Code 15, no spark (searched)
- where is the redline?
- z6 head on y8 block
- Tenzo R seats
- 1989 honda crx si manual 5 speed HELP
- Run a OBD1 Dizzy with a OBD0 PR3 ECU??
- I need help with a motor....
- Replacing Autozone crap with MSD
- Exhaust Leak (Manifold Issue)
- What is wrong with my car? Dies intermittenly and won't start
- Carfax- help a girl out
- i need an answer
- JDM 4dr front end on hatch, anyone ever see it before?
- Hating My b16 Crx today..Need some opinions / advice
- I could use some help...
- Steering rack: What year civic steering racks will fit my 91 Si?.
- I am a crx owner 1989 mrk2 – 1.6i/16v-I need help
- bogging issues with b16
- I need an ignition coil
- what happens with MPFI conversion and DX dizzy?
- crx parts
- TurbTurbo GSR
- d15 MPFI swap 1/4 times?
- Which bumper lights do I need?
- whats a good racing but also daily driver performance clutch for my stock b16a with a cable tranny??
- need some good advice
- Stupid question...Just curious
- DX block with Si head?
- An-r header vs. Ericks racing header vs. Bisimoto Header
- how much will a b18 throttle body help ??
- front mount on a b16a
- Dent oil pan. problems?
- dpfi to mpfi swap
- Interior lights in hatch area
- are all PR4 (integra) non-vtec heads the same?
- CRX Bodywork
- I think I blew A Headgasket
- An-r header vs Ericks racing header???(need advice)
- turbo for a d15a
- Will i get spark if my ignition timing is off??
- Replacing Busings
- Car stuck at high idle after long storage period.
- need parts for my dinosaur 85' HB
- turbo for my b16
- 4-puck clutch disc with stock pressure plate and flywheel or complete street kit??
- performance parts 84-87 CRX
- Best Cam Gear
- wiring ob1 to a ob0 b16 distibuter
- b18a or b ? ( turbo )
- frontend conversion ... i do ask a lot of questions
- i have 1990 crx .have swicth beside steering wheel. wtf is it?
- torn cv boot/axle problem
- my hatch needs power
- HELP ME READ THIS
- What is needed for wiring to do a B16 swap into a DX CRX?
- is my crx si EF7 or EF8??
- Quick test.
- WTT Civic disc Ebrake cables for CRX disc cables
- JDM Taillights
- Looking for a picture of a 1st gen crx door panel and dash!!!
- Whiteline products?
- for my first car
- Car want to die at 75-80mph?
- Spark Plug Wire Order
- Quick tranny question.....
- ac conversion
- Another engine weight question
- upgrade master cylinder w/ disc swap?
- Fiberglass Door Panels
- a simple suspension explanation?
- P30 ECU?
- Calling CVC9216....
- Doorpanel modification?!
- Need Information On Early Model Civics...
- oil pan help
- B18a interchangable parts
- crx vs. 04 supercharged cobra w/ NOS! HA!
- integra rear disc brakes
- sweet EF for sale
- 90-93 teb front end?
- What size Piping for a DOHC ZC
- Positive camber after rear suspension installation???
- jdm fog lamps
- how to install ignition key?
- obd 1 zc should i stay obd1?
- jdm fronend conversion
- Mini Me on a SOHC Zc
- Need a rear hatch preferably northern or central CA
- ok lneed help
- Will 18 inch rims fit on my CRX?
- All wheel Drive EF
- INSTALLING AEBS TYPHOON INTAKE / QUESTION
- Camber correction Kit using KW Innox Stage 3
- honda 87 crx si (help)
- Help how to check TDC on a 91 dx auto??
- GIRL needs help with CX MOTOR.
- weak spark in 88 civic lx
- how can i eliminate the ficv/fitv all together?
- which camber kit replaces whole uca?
- Do the ingalls front camber kits come with new upper ball joints?
- Anyone can help fine tuning VAFC?
- 89 civic si seats won't fit in 91 dx hatch
- exhaust note
- Exhaust interchangability???
- Starting Up Problem B16
- WOW! Pretty nice problem here
- header installed but car turns off!!!! help!!
- b20 in garage
- front rotors warping
- good replacement seat? where to buy?
- hello, heres is a new link to add for anyone into SOHC Honda's
- timing belt keeps slipping and car back fires...
- i'm confused
- squealing sound...maybe a brake issue???
- axle or tranny problem?
- EF Door Panels
- just cannot get it to spark, my b16 in 90 ef9 dx
- b16 cable trans best way to put lsd in it?????????????
- dseries axles
- inaccurate fuel level guage
- What YR tranny do I have ?
- opinions please
- To those who want a direct fit Momo steering wheel/hub...
- HELP! Stock tach/temp/gas tank guages and instrument lights Not working...
- std model harness to si engine bay harness(b16)!!!!
- how to reinforce crx climate control?
- Stripped dizzy bolt
- brake pads
- ***HELP ASAP-ROLL BAR doesn't FIT!***
- Moisture
- Looking 4 stock 91 crx fenders?!
- code 4...crank angle sensor
- on the temperture coolant sensor.
- Car idling jumps when slowing down...
- New here , need opinion on CRX
- ***CLICK FROM LEFT SIDE DASH AREA, CAR CUTS OUT?***
- crx 2g aftermarket floor mat? where to get one?
- SOHC V-TEC HEAD SWAP?
- HELP , quick question, Throttle body Idle ...
- FS/Trade/Parts 89 Honda Civic DX HB
- I'm stumped....can you figure it out?
- How does your car handle with B16 or B18?
- EE9
- OOPS too much nitrous!
- Gauge cluster lights not working
- B20 or Ls motor?
- just curious...
- 84-87 CRX Steering wheel
- Cluster lights not working!!
- help, getting CEL 1 and 9
- CRX import vs muscle NOVA : starting to reconsider...
- Vendor sites for complete engines
- B16a1 intake manifold - worth anything?
- what year crx, aluminum rear drums?
- 89 Crx, what ACT clutch should I get?
- I got a 89 hatch...
- Installing VAFC, which pin is RPM signal on PR3 ECU???
- suspension problem!!!! HELP!!!!!
- JDM ?
- I need parts for my 91 ex sedan!!
- Thinking of ditching my B16 and dropping in a built mini-me.... am I on CRACK?
- Need Idle Adjustment Pic
- WTB: Crx
- MPFI swap complete!
- Do anybody have a back bumper lip for a 91 Si?
- need help hooking up external coil
- do you think its worth it
- Crx Fogs up like crazy when it rains, Any suggestions as to why?or what I can do??
- d16y8 in 90 ef4d using dpi and mani?
- car wont start when cold
- Will saturated injectors work?
- Can my car detect when its in gear??
- Identify my rims... OLD SCHOOL FO SURE!!
- whats causing car to leak from here???
- b16 in a 91 crx si
- Front lip How-To
- 2 problems with my EF. Pls help me!
- Difference between the PW0 ECU and the PR3 ECU?
- B16a or D16a8ZC in a CRX? I did search.
