View Full Version : Honda CRX / EF Civic (1988 - 1991)
- stock b16 air filter
- How much? Rear upper control arm
- swapping passenger seat with driver's seat
- Si trans?!
- Is it possible to get a sterring wheel restiched???
- cam timing gear
- EF fuel mileage?
- Header Question
- Best way to go about restoring a seat??
- will 1990 SI seats and headlights fit on a 1989 crx?
- type r or gsr timing belt?
- GAS
- gearing question
- Rota Group N's on CRX?
- Need a 91 civic 1.6 auto 4 dr sdn ecu
- Need Help with keys
- core support/crossmember, i got some questions.
- LS engine swap "help"
- *weird overheating, engine stumble, overflow overflowing*
- b16 mods>?
- Sub frames all the same?
- Prelude suspension on EF?
- new to hondas have many questions
- individual carbs*** for sale***
- shifter noise
- CRX - HF fuel problem?
- Anyone ever wonder what happend to your CRX...
- help me get this straight
- idle speed for 88 civic
- Cluster and Radio subharness question!
- Need some opionions on CRX
- Knocking.... i know there is alot of these so links anything are fine
- thermal crx exhaust specs?
- exhaust/oil smells like gas
- pics of hatch w/ side diffusers
- OBD0 B16A stock air filter
- b-series into dx hatch
- half shafts
- Which Civics and CRX's come with MPFI?
- help
- oil in tips of spark plugs what does it mean? my car wont start..
- WTB: 90-95 Honda Civic
- has anyone tryed the skunk2 sport struts?
- Short Ram or Cold Air?
- Just Got a 90 CRX SI TAKE A LOOK
- 91 Civic Electrical Problems
- CHECK THIS OUT!!!
- 89 d16z6 hatch problems
- Can anyone help with an 88' Civic Wagon?
- RyWire question
- oil breather chamber on 91 dx
- how to tell if headgasket it blow??
- Do you feel like any Company has done you dirty?
- broken clutch pedal bracket
- code 15 and 16
- Actual drop vs advertised drop
- Your point of view
- help with swap .
- would u ever buy a tranny on ebay?
- d16 vtec head on zc block?
- CRX/B16 wiring ... best site w/ pics?
- Thread info required please.
- Crome or Hondata S200??? Need opinions on either one.
- What kind of catalytic converter should i get?
- 2 outa 3 half shaft bolts?
- hb just dont look right with out a wing
- overheating Ls
- confused
- Can I replace an OBD0 b16 distributor with b17
- accord motor?
- b16a helms manual for 88 crx si
- Putting Del Sol Seats in EF> Questions
- Getting Real Close to Starting this Car
- crx
- harness question?
- zc idle problem
- **Help me pick a turbo manifold that fits b series EF *PICS*
- wirin problems
- is there a obd0 to obd2 distributor conversoin harness?
- EM1 parts on a EF
- Add turbo to 88 Si?
- EDM OBD0 to OBDI
- OMG, another mini-me question (cam gear question)
- does any one in the los angeles area
- code 8? car running fine
- pm8
- What kind of rods?
- What Motors In a 1989 CRX Si?
- catback question.
- Start problem
- 250k HF plus donuts = fun
- 90 CRX Subframe reinforcement brace
- 1989 CRX HFs are the worst for seat swapping?
- Si seats in a dx?
- Ignition Output Signal problem
- 1991 CRx setup
- Some pics of the CRX Project...
- Please help me decide****NITROUS or TURBO****
- Next meet:did a search-couldn't find.So when and where?????
- i finnaly got a motor for my hatchy
- header finish?
- any web sites selling jdm 88 si crx parts?
- toolkit for the car
- My new turbo manifold setup... (56K...bad)
- Question about a tranny
- last chance parts give away
- Exhaust manifold from B18C6 to B16A1
- OMG not MORE trouble!!!! :'(
- Always having problems with my cd player.....Anyone got a clue??
- Hey
- Shattered bearing on Dohc Zc
- crx k20 i have a question?
- Heater blower problems...
- Clutch question d15
- Need To Buy A Catalytic Converter
- ZC parts
- need vacumm diagram
- Lower my ef hb
- I Need help for Axle
- no defrost
- when buying a 1991 Civic Hatch si w/ b16a what should I look for?
- DX B16 swap
- exhause pics
- 90 crx si trouble code 17
- z6 minime questions
- CRX K20 swap??? was told to come here
- need help...
- fuel injector flow rates for a crx si 1.6 and an hf 1.5
- RHD how hard is it?
- what do i need to swap disc brakes into a 90 hb
- B16a 02 sensors
- map and idle problem
- car problem
- What you guys think about these mounts???
- im picking up a 90 hatchback ls swap tomorrow
- DX or SI trannys for boost?
- Problem with lowered rex, *pics included please help
- EF Hatch to Crx Front Bumper Conversion
- In your opinion...best/easiest motor swap
- how hard to put crx seats in my ef
- Nitrous on A D16z6 Motor?
- CODE 20: Electrical Load Detector???
- Camber Kit
- auto radiators different than manual tranny radiators?
- wiring?
- Crx B16b swap Help needed
- d16a6 m/t a/t
- B16 Chugs then turns off??
- how to wire vtec for a crx with a d16z6 head
- TurboDcivics hella tight build thread(4 doors , 2 cams and variable timing!)
- do 86-89 integra seats fit in a 84-87 civic HB??
- Innovative mount problem. please help.
- obdo b16a code 23
- del sol seat swap
- Timing belt change intervals?
- 89 DX-MPFI conversion Code #10 & #20???
- clutch slipping
- Removing bushing ring from lca w/out a press
- timing help
- Idle Trouble HELP
- how much you think for a b20 swap....into a civic si coupe
- Some stuff i just got for my Rex...
- Well guys...
- Quick bumper support question
- The Dr. Is In! D16 on Crack Build Thread
- crx with b16a throwing code 4
- stalling out
- power seatbelt relay/fuse location 90 sedan
- Replacing front lower ball joint
- Cheapo coilovers, a disaster waiting to happen? Check these out.
- Block for 5th gear in hb civic??
- usdm foglights
- 1991 CRX Si
- ect sensor code 6 temp gauge not working
- eg exhaust onto 4 door?
- Throttle Body Injector?
- Gas it car delays response help!
- Rear disc conversion on the civic hb???
- Fitting a 1.5 liter(D15**) cam into D16A6.
- spring opinions...
- 88-91 CIVIC/CRX Power Windows
- last question about this swap dashbord out into civic
- b16 or ls tranny
- exhaust for my hatch
- B20B question
- CRX axles
- Eibach springs
- OBD0 to OBD1 on OBD2 engine what distributor?
- Engine suddenly much louder?
- Wiring a tach into a DX EF w/b16a 5 speed
- Clutch Fluid, Transmission Fluid, and brake fluid; What kind do you use?
- D16Y7 motor + HF or DX tranny + turbo
- Quick Engine Question!!!
- motor question
- SiR front end for ED4 Sedan ?? Need Fenders?
- dpfi tb gasket change for hp gain?
- Volkswagon Front Lip
- obd1 conversion
- D16a6 HEad studs
- can you stroke a B20?
- LS SHIFT LINKAGE PROBLEM
- Quick question : Knuckles of a 90-93 integra RS will work on CRX HF w B16 right ?
- **Shiping engine**
- Sort of new here, need help
- whats the best supercharger for ef9 with b16
- Wagovan front lip??
- Can't diagnose problem
- Weird battery light problem
- questions about a valve job
- Saved Hatch
- Clean Alpine White CR-X Feature
- rear window installation
- 91 Sedan brakes
- 95 EX cluster in 90 crx, what needs to be done?
- b16 with stock si distributor..timing issues.
- will the crx tails fit a hatch
- firing order
- bent strut rods/radius rods... what else is compatible?
- Have a 1991 CRX with the stock motor wanting a little more...
- H22 in a CRX?? Give me suggestions
- milkshake head
- What am i getting myself into?
- mpfi swap problem
- Does anyone know if the obx intake manifold is worth a shit.
- how to remove drivers side fendar
- california emission DPFI to MPFI swap
- another speedo cable question
- EF SEDAN *Headlights Shorting out* HELP!
- full coilover
- OMG EWW
- my pics of my civic.
- Anyone ever make one of these
- Need a JDM hood
- front axle nut/ wheel bearing replacement??
- torque specs?
- stupid brakes
- which vtec head will fit on my 87 d15b2
- axle problems i thing
- b16a head, b18c1 bottom..................
- does anyone know if 89 civic and 89 crx dashbord harness are the same????
- torquing bolts. how do u tell they are torqued to spec?
- no time for search. quick question, obd0 zc, which dizzy for obd1? s200b?
- Advice on rim selection/tire under $300
- Radiator swap...?
- Ltzracer's Crx 56k no!!!
- Passenger mirror for DX
- speedo jumping the motor dies...
- problems with 90 crx si
- now im a bit confused
- my fan doesn't work need help
