help with crx
Old Sep 24, 2015 | 07:30 AM
Michael House's Avatar
Default help with crx
I have a 90 crx with a jdm d16zc dohc swap thats throwing a code 9 Sputters and jerks at low rpms you get past 2 grand and she runs smooth. Checked the timing its dead on new cap and button and coil in the dizzy all grounds checked and cleaned. All injectors firing same with plugs swapped the camshaft position sensor wires back and fourth with no change leave it unplugged and still no change
Old Sep 24, 2015 | 08:28 AM
Freemananana's Avatar
Default Re: help with crx
If you have a code 9, fix it? That's your issue. It is likely a toasted sensor and you'll need a new distributor. Try a new dizzy and if it doesn't fix the problem, you can start trouble shooting other possible issues.
Old Sep 24, 2015 | 10:59 AM
Thanks for the onfo i will give that a try just wanted too double check mainly because ive read serveral forums and it was about half and half that said it could be my dizzy or my external cam shaft sensor
Old Sep 24, 2015 | 01:19 PM
jlicrx's Avatar
the cylinder sensor, which gives you the code 9, for the DOHC ZC is on the end of the exhaust camshaft, not in the distributor - it is extremely rare for the sensor to be bad (but could be) - check the wiring to the sensor to make sure it is wired correctly - the Blue/Green wire on the sensor runs to ECU pin C1 and the Blue/Yellow runs to ECU pin C2 - also check the camshaft timing - if the exhaust camshaft is off one tooth, you will get CEL with a code 9
Old Sep 24, 2015 | 01:27 PM
cjwang2's Avatar
I had a very similar situation that you are describing, after I did the DPFI to MPFI swap. I got a new distributor, new wires, new plugs, cleaned the injectors, got a new ECU, nothing worked. Via the Honda Service Manual, I checked the voltage on the ECU and the Distributor and they were in the acceptable range. Finally I left my multimeter in the ECU slots and had a friend shake the wire harness in the engine. The multimeter readings went all over the place and after slowly taking the wire harness apart, starting at the distributor, I noticed that the wires from the distributor to the ECU had a break and that the vibrations from the car were causing the code 9 and the rough driving. You may want to try the same method.
Old Sep 24, 2015 | 01:37 PM
jlicrx's Avatar
code 9 on the DOHC ZC has nothing to do with the distributor
Old Sep 24, 2015 | 05:39 PM
I thank you all for the advice i will give it all a shot and get back with you guys and tell you the outcome
Old Oct 2, 2015 | 02:35 PM
Ok update my 90 crx hf with the 89 integra dohc zc 1.6. I have changed the dizzy new tps with it set at .5 closed throttle and 4.5 wot new plugs wires and plugs cleaned the iac no codes showing at all but she still sputters and bucks and jerks at low rpms no matter which gear you are in tried advancing the dizzy and retarding it with the computer by passed still no luck any thoughts
romierome
Feb 24, 2010 12:01 AM
kwizical
12
Mar 10, 2008 08:05 AM
4gnhatch
Dec 18, 2006 03:20 PM
Eresuncabron
Aug 12, 2004 01:01 PM
hybridEj6
Sep 11, 2003 06:41 PM
