View Full Version : Honda CRX / EF Civic (1988 - 1991)
- si moonroof visor
- ef b series shift linkage
- ef9 radiator cap
- 88-89 DOOR FIT 90-91 HATCH?
- Running Z6 with P05
- 91' civic Sir EE9
- What are the differences between 88 and 89-91
- no vtec no check engine light
- 1989 crx wont start
- need opion and tech input on exhaust
- converting to MPFI..anyone have the wiring pin out?
- EF Gas Mileage
- crx water leak
- help!! tried everything
- obd0 - obd1 rywire conversion harness question
- passing bar obd1 in a obd0 car ?
- VTEC MPG
- 1982 civic...where do i go??
- No heat, help!
- mini me and nitrous
- crx si b20 not starting
- HELP
- B20 non-vtec | ECU choice
- ecu question
- BR0KENB20'S EF9 BUILD THREAD
- Vibration while Decelerating and in Reverse
- H22 Swap: Help Please !
- Subframe
- fuel pump or fuel pressure regulator?
- will 1992-2000 rear trailing arm bushings work on a 1990 civic si?
- Cluster question...
- Oh NOOOOs
- Ok i have to know
- mini me B2? or A6? Nitrous?
- civic accord prelude ecus n parts for sale
- Clueless! trying to finish my new 90 si hatch project. please help!
- anyone know what kind of MPG i would get with a OBD-0 B16 and LS cable tranny??
- can you use a pm6 in a dx?
- smash your EF with a hammer? no thanks
- d16a6 with LX chassis axle question
- advice on my si ef with salvage title
- 1990 CRX DX Wont Start No Spark Died While Driving HELP
- obd0 to obd1 dash loom conversion in 89 crx sir
- hyxrolocked lsvtec, reccomendations?
- sohc zc wiring/swap help
- 89 crx si mini me swap questions
- LS Internals????
- o2 problem d16a6 4-2-1 header
- b16a tranny problems
- altanator issue
- HEY WAQTS UP U GUYS IAM NEW TO HONDATECH
- EF8 B18c Conversion Problem.. Clutch.
- yes i searched.
- 90-91 Prelude OEM fog lights on 90-91 Crx or Wagon?
- OBD0 - OBD1 GSTR swap not starting
- Fuel filter
- need help asap!! how to get alternator out?? i already got it off
- p30 pistons....
- water leak
- Just got a 91 lx 4door today
- any try vitara pistons with civic rods
- AEM hybrid intake with D16?
- half shaft trouble
- Master Cyl VS Victor X
- Add on and performance parts
- D15B in a 88 honda civic dx Questions
- 91 EF B20 SWAP HELP!
- ef civic window visors 1989
- ef with ls motor alot of vibration
- CRX swap- B18C1/5, H22A1, K20A2 ???
- o2 sensor CEL problems
- auto 2 manual
- EF jdm Lach
- NEED HELP WITH WIRING ISSUES
- still need help getting my rex running
- CR-Z... What do you think of it.
- B18A1 internals
- checking codes
- What can it be?
- alternator question
- Color code NH605
- weird noise from passenger side?
- Temp gauge problem please help!
- Help please.. need good parts
- B16a to Type R?
- EF8 EF9 EK RHD CONVERSIONS
- crx turbo questions
- what could be wrong with my gauge cluster??
- NO HEAT: ITS GETTING COLD
- Piece-0-Crap..
- Pre Swap Help
- obd0 engine harness
- Need help 89 EF DX Tricky Problem?
- Need help deciding what i want to do with my B18A1
- broken clutch cable
- rear disc swap ??
- !HELP! ef with a gsr vtec makin wierd noise !HELP!
- 90 si loud clicking noise
- 15x6 tire question
- how to take off cig lighter
- Idle issues, video included
- remove seats
- Ef9 Bumper Filler Question...HELP
- Putting ac back in my crx
- Sedan broke down with a cloud of smoke...
- Timing wire jump odb0-odb1 conv.
- I need help with my JDM 88 CRX Wont start
- 90-91 CRX SI cluster- 5 speed manual.
- 91 civic door handle removal?
- fuel pressure regulator
- bleeding coolant
- EF SOHC dc 4-1 header
- obd1 conversion problem
- Need help, doing a civic 4wd swap
- B18A1 blowing smoke out the valve cover breather what causes this????
- HELP with Steering Lock!
- Converting from manual to auto
- My LS head
- my sloooow build thread! 91 Si.!
- cluster
- 89-91
- how to: 4x114.3 conversion on ef chassis
- 89 crx motor swap need help
- rear camber kit and rear toe control arms
- 91 Civic hatchback parts?
- Civic EF shifter console?
- could this be a bad tune?
- 1988 civic sedan question
- Need help with my exhaust?!?!
- rear disc swap ????????
- First B16 CRX swap. Need help Troubleshooting startup.
- Trouble Starting
- k20rex's crx build
- MINI ME CRX- Fuel cutout problem HELP????
- is my clutch going bad
- installing question - jdm ef9 sir wing.
- 1990 Ef hatch Circuit Overload
- 91 crx mud flaps
- removing altnator dohc zc
- obd1 b16 fuel rail with dpfi banjo nut
- rear tranny bracket
- Clutch Safety Switch - Anyway to Bypass w/o mods?
- Sprint Lowering Springs (Front:3-1/4 inch/ Rear:3.0 inch)
- CRx89si axle and half shaft problem and belt
- Help! Door light/seatbelt alarm won't go off
- JRSC DOHC ZC downunder
- B16a civic hatch code 4
- Apexi AFCneo
- rear disc brakes
- Question on removing ac compressor
- 1990 crx help
- FENDER FLARES....take 2....finally SUCCESS!
- Need some help... crx bogging thins bad o2 but not sure.
- mpfi help
- is my timing belt screwed? (video)
- 90 ef brake lights causes radio to turn off!!
- 1990 civic b20 swap coolant lines??????
- Starter gone?
- just got a crx!!!
- It just keeps doing it!
- need help with part
- obd0 b16 header.. can i use 90-91 integra ls header?
- Please help '91 Civic DX cluster
- head studs
- a6 swap
- newbie question bout headlights.
- brake pad recommendations HAWK,EBC, OR AXIS ultimate?
- Gsr Motor Or B20Vtec???
- Iphone car dyno my CRX?
- Mini me oil jet issue...
- ground knock sensor b16??
- Yet Another No Start Problem =(
- What radiator for H22A CRX
- Head gasket help
- quick header question
- 91 ef hatch dohc zc swap, need help!!
- help. lsvtec not revving pass 5000rpm
- What Size Do I drill my Fuel Rail???
- locken my keys in my car...now what?
- mini me swap. a6 block with z6 head
- 92+ d-series into my EF...questions...
- b16 ex manifold. no o2 bunge??
- ecu flash
- How to remove cigarette lighter assembly ? 91 civic
- Turbo B16 Crx NO START
- EF2 xt 35 sedan cluster question..
- flywheel bolt thread pattern
- B16a Repair Manual
- Can’t adjust timing past 6* btdc?
- need help with distributor
- d16zc info needed
- CRX swap questions! i have alot please HELP
- H22A idols then dies when it's given gas
- my ef was hit last night
- 1991 Civic hatch ECU wiring schematic
- invidia catback??
- ACT clutch part number....
- Honda CR-V Car DVD Player with GPS Bluetooth TV
- no fuel
- what crx front bumpers are interchangable?
- I hate my life...damn crx
- signal light and water temp. sensor problem?HELP!
- auto seat belt experts?
- front camber kit noise?
- tach and temp needles jump up and down
- main relay test?
- b16a *BLOWN HEAD GASKET* Question
- Swapping ZC/D16 Injectors, advice needed!
- Off road CRX B20
- D15b vtec-e or d16z6?
- CRX clip on a hatch?
- 90-91 si seats
- 90 sedan electrical problem?
- b16 swap, bad starter?
- Ghetto Paint Job: Roller or Spray Can?
- Starting Problems On a 91 Civic Sedan
- Question on headlight mod?
- lifting a 90 hatch?
- Anyone know where I can find this part
- CRX SiR vs Si Front Brake Assembly
- CRX suspension on a RT4WD (wagon)???
- b16 SiR II Into a 91 Hatch
- Starting
- Oil feed line for turbo...on Dohc zc.
- RPM
- MPFI Swap code 4 problem
- Just got a ticket for my four point harness!
- Crank pully fell of while driving
- O2 sensor wiring B16 obd0
- EM1 Engine Harness on EF!?
- B-Series mounts?
- safe to jump a starter relay?? 89 CRX
- Car shut down on neutral drive
- D.I.Y. lexan windows on hatch
- Video of problem (Private Lee)
- 270cc injectors in stock b16
- Exhaust suggestions
- My New CRX, A Engine Pic ( Cont.)
- No Vtec on my type-r motor thats in my CRX!!!!Help!!!!
- 3rd Axle in 2 weeks... WTF?!?!
- what kind of ecu is this
- D16Z6 Swap
- Where is ecu connector
- d15b7 into ef hatch
- hood cable disconected!
- vtec block = non-vtec head?
- eww crap
- EK coilovers on EF
- need some help ht
- new parts please
