View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Spoon Style Mirrors
- Better Mini Me swap combo
- LS swap into CRX
- Paint/Bodymen...Please take a look at these pics of my $1K beast.
- obd 1 zc?
- ECU grounding?
- Weight reduction?
- Stripping sound deadning, what to do about seam sealer?
- neuspeed upper front strut bar? any good?
- 91 crx with 89 lip on it PIC?
- tach wiring
- eyelids for 89 hatch
- Quick question about ignitor and coil
- 97 or 98 teg
- quick need help. does 90 rear interior fit an 89
- tell me what u think...
- Going turbo
- My SiR
- dual point intake maniflod using si 1.6 multipoint engine
- difference between D16 IM and B16A1 IM
- tranny questions..
- crap luck when ordering stuff
- Good websites to find tires for cheap?
- B20Z in my 89' cx/Need help!
- where to get ALB fuse?
- junk yard integra
- CRX ?'s
- Engine Huntin'
- Water Pump failure???
- 14" or 15" steelies for 89 hatch
- question about rotas on ef/crx.
- putting 90 si head on y7 block??
- BEST HEADER
- clutch or clutch cable?
- How can i change to 4 x 114.3 bolt pattern?
- replacing brake master cylinder
- clutch cable broke need help
- will this work?
- QUESTION FOR dgonzals..
- Anyone Know...
- My first project
- EK Civic
- Water in Left tail light of 89 CRX
- Russell's Stainless Steel brake lines
- 88-91 Honda Civic climate control on a CRX?
- car sometimes wont start. one flash and then 16 short flashes on 89 hatch
- si and dx bottom end, the same??
- will sedan/wagon fenders/hood/bumper fit onto an 89 hatch?
- y8 manifold and injectors??????
- d15b2 head gasket???
- megan racing h brace or frnt lower tie bar or both?
- B16 DX crx swap info??
- Knocking in front end????
- how much hp would you free up if.....
- obd1 codes
- 94 Integra Dash into a CRX ???
- will hx wheels clear a rexs brakes...?
- timing??s
- 90 teg b18a1 into 91 dx hb
- Is this a stolen CRX or not?
- mpfi swap stuck??
- y1 clunking noise
- Inspections in Illinois?
- APEXi VAFC2 HELP
- HONDA 91 HATCH DX .. NOW CAR WILL NOT SPARK OR START AT ALL.
- phantom grip lsd conversion
- IYO B18c1 or rebuild B16a1
- HELP !! 89 si tranny problems
- Ok one more rear sway bar question
- car died today(electric maybe?)
- 89 crx engine wire harness question..
- how much would you pay for complete rear interior
- Just Got AGX's confiused about ajustment.
- HELP: How do i tell what model civic i Have
- HELP: What distributor for my DOHC ZC
- p30 or p28
- Electrical problem?
- My car's weird as shit(won't start in the rain)
- Apex'i WS coilover
- wierd cel???
- which plug wires for a b16a?
- used turbo kit
- Blowing 60A battery fuse.....
- D16A6 & D16Z6 INTERCHANGEABLE?
- EF1, EF2, EF3, and EF9 Part Book recieved.....
- Where to buy complete b18swap for 90crx? Anyplace to order full swap?
- b17a in a 88 civic hb
- 88 Si trans questions
- Are all b-series dizzys the same? b18a vs b20b
- multi port hb
- what should i do to a 89 crx
- help changing tbi
- Igniton Timing Stumped...
- Where to find a part online??
- anybody in the delaware area have and crx si trans
- 89 civic automatic dpfi to mpfi help please???
- any difference in fuse boxes between the years??
- Question.......About seats and parts......
- CRX D16Y7 (1997) Mini me swap info....HELP:)
- EF9 axle dilema!!!! passenger side to long???
- VIS vs Fiberimages
- civic ef lip
- Which harness should I use??
- Best shop to get B16A1 for swap, need your opinion
- Need a new engine! HELP
- FS or FT: Ls/Vtec block
- My car value
- help with swap
- b18a in 88si exhaust ?
- post CRX PICS here
- Removing 88 Crx upper ball joint
- all 87 civic or d series motor owners please help
- 1st gen b16a Dizzy Cap?? (I searched)
- 1/4 mile time
- OBD1----yay or nay?
- Which Helms manual do I get?
- What all i need for turbo?
- GSR swaps with OBD1 conversion...exhaust cam solenoid...
- problems with b16a
- Code 15?
- ecu throwing code 6 on a b16a
- 91 hatch cranks and wont start, but wait 5 minutes and it fires right up. wtf?
- Best Car Paint?Macco lol haha
- anyone know anything about the new aem "hybrid intake systems"
- Are 7/8 in. diameter sway bars overkill?
- Crx axle problem* need help ASAP
- wiring problems
- 91 rex problems need help please
- fuel filter bolt......
- Differences between 88 and 89-91 CRX Fog Lights?
- Rear sway bar 91 dx
- looking for a 89-91 hatch
- wiper switch
- too agressive?
- Size of IACV coolant hoses?
- d15b2 camshafts?
- d15b2 engine
- rim size on 88 CRX
- 88 crx si?? << wat obd is it?? any one knows just let me kno please!
- AEM CAI Bypass valve broke!
- replace tape or radio?
- engine missing at 3400-4200 rpm????
- need help with my 91 CRX DX
- 1992-1995 Honda Prelude Manual Transmission???
- My timing looks perfect. Why do I need a cam gear on a mini-me?
- Timing belt wont tighten, what the hell is going on? NEW BELT!!
- Interesting Dash conversion *pic*
- interior or no interior?
- lowering springs
- oil pressure/coolant problem
- 90 dx axels?
- need help with crx 88 si
- need help with 88crx dx i am trying to figure out the wireing to put in a xsi into it
- Post you rim/tire combos.
- 88 zc swap clutch
- Good set up for SCCA
- 91 crx dx sensors
- Anyone have info on the J's racing time attack CRX?
- Clutch is super stiff
- exhaust question
- B16a1, what ignition coil? HELP
- 88-91 CRX fenders???
- Fender Question!
- timing belt off a tooth?
- Whats better boosted ls or ls vtec?
- connecting rods
- Auto/Man Conversion
- question about seats
- Is my battery really dead???
- B18a wiring
- SOHC VTEC swap in a Civic Dx converted to obd1
- HELP: B!6 into 91 crx hf
- Adj. Lower Rear controll arms--->
- GSR springs on my 1990 Wagon
- WTB:90 or 91 si or clean dx crx...Oregon and Cali only
- super bike exhaust....searched
- Power Window Install
- Clutch Not engaging (SEARCHED)
- "ebay" camber kits, have somone tried them?
- Fly Wheel
- rear brake conversion CRX
- HELP MEEE
- Oil in distributor cap, where would it come from?
- ZC for me CRX Help!! Questions.
- whats the darker blue honda color?
- anyone who can paint cars in socali?
- HELP! Swap Gone Bad
- strut bars that clear DPFI manifold?
- ZC tranny, splines and clutch ?
- which header to buy for b16a1
- 2 Questions
- thinking of painting my car Celestial Blue
- need to find this thread
- motor questions
- 1986 CRX questions.
- Trying To Find Out How to Do the Electricals On A Electric Oil Pressure Gauge
- ----->striping<-------
- 1991 Civic Wheel offset ????
- Whats best motor set-up for 91 civic????
- how can i tell if its an si Tranny??
- Hesitation
- Crx vs. Miata Slalom and Skidpad calcs.
- 1.25 inch drop on illuminas...camber kit??
- elmalouno, elmalocrx, or waylon. where are you?
- Venom performance chip
- NEED HELP!!!!! Whats the real deal with a DPFI to MPFI swap???
- which throttle cable bracket?
- Anyone from Massachusetts?
- 91 crx dx
- Car pulling at like 90 mph.
- invidia exhaust
- vtec not working on my b16
- What timing are you guys using on your ZCs?
- HELP! Code 9
- b16 with 1.7 crank and rods
- The new guy
- Another short shifter vs. exhaust question, but this one's legit
- OZ Rally wheels 15" on a 90 EF hatch
- How does a racing clutch effect driveability?
- Nissan-tech
- EF forum into sentra forum?? what
- Drag Turbo Kit
- Clutch for a 99 EX engine in a 89 CRX?
- Bright Lights On B16 Crx
- Fuel cells and Lovefab Manifolds!
- Coolant temp sensors
- question
- AC removal
- help with coolant temp switch
- Soon to be the Sentra forum??
- b16a cranks slow now
- motor mount question
- Need help installing Cam Gear on 90 CRX SI
- Hf / Si Injectors
- Hood release idea, to deter cops from opening your hood?
- YS1 tranny owners...
- Who's got the best deals on ACT HD pressure plates?
- i needa hood
- TURBO
- WTB 91 CRX Front Passenger Side Fender
- Brake Pads??
- removing oil breather on back of block?
- SLOPPY steering!
- B16A1
- the correct axles for a b18 swap into ur civic/crx....check it out
- Those running PR3 with two o2 Sensors question.
- HELP!! My bodykit is falling off!!!
- Exhaust Knocking
- Waddya think my car's worth?
- need help with a part ID
