Door Panel question
Old Jul 14, 2015 | 02:33 PM
Linville33's Avatar
Default Door Panel question
Hi, I have a 91 Si and the door panels are not in the greatest shape, found a set of SiR panels. Would they fit on my door properly?
Old Jul 14, 2015 | 07:57 PM
jhmed's Avatar
Default Re: Door Panel question
If you're in the USA and have seatbelts in your doors, then I don't think they'll work.
If you're in Canada or Europe and don't have seatbelts in yours doors they will work. If you don't have power windows, the cut out for the door handles will be too large.
If you do have OEM power window switches meant for RHD CRXs and your master switch is on the right side it will fit fine.
If you have OEM power window switches meant for LHD CRXs (or for RHD CRXs and you moved the master switch to the left side) the cut out for the door handles on the right side will still be too large, and the left side too small.
Hope this helps.
Old Jul 15, 2015 | 06:29 AM
Linville33's Avatar
Why wouldn't it fit on a USDM door? From my knowledge the difference between JDM doors and USDM doors was a reinforcement bar and maybe an inch difference in measurements? Not worried about looking my seat belts going harness.
Old Jul 15, 2015 | 01:38 PM
boibuddha's Avatar
1990-91, Americans were not wearing their seat belts. So, the government forced automakers to put automated seat belts in all cars.
The result in the civic was this huge bulge (contains the belt retracting motor) on the end of the door panel seen here.
If you're not using the factory seat belt, then you should be able to use the SiR panel if you remove the belt. But you will have to deal with the minor details jhmed mentioned.
Old Jul 15, 2015 | 01:46 PM
whited's Avatar
CRX God
I have 88 (non seatbelt) doors panels on my 89 with a 4 point harness.
Do you know with SiR is it JDM or EUDM?
I can measure my JDM SiR panels if that is what you are looking at.
Old Jul 15, 2015 | 01:52 PM
whited's Avatar
CRX God
https://honda-tech.com/honda-crx-ef-.../#post49794953
The door stills are different as well.
https://honda-tech.com/honda-crx-ef-.../#post50343708
Old Jul 15, 2015 | 06:10 PM
sstupid's Avatar
10 Year Member
For the record, our government isn't really trying to be paternalistic, it is just trying to save us money on insurance premiums. Yeah..........that's it for sure.
Old Jul 16, 2015 | 06:04 AM
94eg!'s Avatar
#1 Super Guy
Loved
I thought everything was different. The shape of the B pillar was different as is the trim parts on the rear quarter window. Even the interior trim panels are different. Not worth the hassle.
Old Jul 16, 2015 | 06:11 AM
whited's Avatar
CRX God
The biggest hassle I had was the on the clips that hold the carpet to the door still. Other than that you just have to notch the corner as seen in my second picture. There maybe a bracket you have to move over as well. I did it having the entire door and door panel from an actual 88 CRX that I had as a parts car. The door still isn't actually needed in the swap, it is just a nice to have.
I love the pocket though. All of my CRXs currently have the pocket. The SiR has pockets on both sides.
Old Jul 16, 2015 | 11:26 AM
Linville33's Avatar
As far as I was told its a JDM SiR panel. If you could get me the measurements that would be great
ndccpf1
Oct 19, 2018 01:17 AM
fali
Honda Fit
Apr 7, 2017 08:51 AM
hmonkey86
Mar 4, 2012 06:07 AM
mtber
Nov 9, 2003 10:45 PM
V-Grip! Teknic73
Jun 22, 2003 01:17 PM
