View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Any DIY crx cargo cover fix up??
- Quick seat question.....
- Whos heard of it and/or tried it? SLR Gas saving chip
- Were can I get x-bar for crx? *searched*
- INJECTOR ERROR CEL
- alternator clearance(b16a)
- cel 7
- NEED HELP ASAP
- Put in NEW Cap & Rotor, Now Code 9?
- New guy with a project. What do you think?
- Alternator diagram
- z1 head on jdm d15b
- 4dr questions.....
- CRX AC wire harness routing?
- Simple Ventshade question.....on a Wagon!
- Front Camber Kit
- Removed driver fender, Put it back on and now the SIDE MOLDING wont sit flush?
- NEED HELP ON DAMPERS
- Innovative Motor Mounts - picture of the oil pan ground clearance
- Head Torque Down Specs
- Dohc zc nitrous or hmt??
- Which Sensor???
- crx wing?
- Civic DX HB Improvements
- Noob need help DA dis conversion in to EF
- jdm taillights
- 12 sec. Ls/vtec vs BMW M3?
- D16y8 obd0 with PR3 ecu???
- looking for 90-91 lower crx transmission case ASAP
- dash swap
- CLUTCH & FLYWHEEL HELP.
- Hatch Si owners rejoice! leakin sunroof info
- clutch question torque spec need asap
- Changing a main shaft bearing?
- primeing the oil pump
- gsr and h22 pistons 4s
- seat question
- Where can I get pins for the ecu clip?
- B20b temp problems...
- Throttle Position Sensor?
- what swap do you suggest n why??
- Sedan door handles
- CRX Rear Window Visor?
- what is the d16y7 single cam vtec moter from, wut year and wut type of car its from?
- pistons....
- vacuum lines
- egr valve missing wires
- looking for side moldings
- short throw shifters
- engine wining
- Civic/CRX rear subframe brace
- #43 fuel delivery code?????
- Bumper Lights
- CRX startermotor compatibility (years)
- ef/dc2 parts swap
- crx dash in a hatch
- EF SEDAN REAR DISC BRAKE CONVERSION FROM DC INTEGRA
- new to honda and working on my first swap
- Gas pedal help after auto to manual swap!
- Anyone installed Ingalls front and rear camber kit?
- motor swaping
- turbo or n/a
- Help
- No fire on obdo b16 sir
- b18a1 map sensor in ef cant figure out
- Lsv fuel problem
- simple parts for 91 ef si
- Looking for Black interior
- might seem stupid but i wanna kno, antenna swap?
- Starting issue
- car keeps going lean..
- 90 Crx DX Hood Problems
- crx hood release cable
- Need info on RHD convertion........
- 89 crx idle problems/alternator?
- JUST SWAPED OBD1 LS INTO 90 CIVIC CKP PROBLEM
- EF fender swap for my Crx
- HALP, what could it be?
- Idle Screw??
- GSR cluster in CRX!! NEED HELP!!
- problem getting b18 exhaust manifold out of the car
- 88 CRX Si Check battery light comes on! Is it the Alternator Or???????????????????????
- calipers
- hood lift support
- plug that has to be bridged for timing (91 dx dpfi)
- traction bar question
- minime swap help.
- Code 16 : fuel injectors
- Tranny Question
- Black soot on my bumper
- EF 88-91 JDM LCA's
- Car is slow taking off
- Where?
- Crx Si gas mileage project
- turn signal auto off
- CRX Rear Interior Question - Center Divider, what do the sides connect to?
- Touch up paint for stock rims?
- Need a new Civic ingition module.
- boomslang harness and iacv?
- zc question
- wrie tuck and vacuum line relocation need just a little help
- crx stalling, Electrical problems? Bad distributor?
- B series Tranny Problem Please Help!
- Rear seat removal??
- Hesitation/stumble at constant speed
- anyone tried modifying crx side skirts to fit the hatchback?
- Difference between 88 and 89-91 harness
- 89 CRX Si burning oil
- Power Door Locks
- Cleaning 5 year old oil
- axle greese
- I HAVE A REAL SEATBELT PROBLEM
- Steering wheel shakes under accelleration
- What slim radiator fan?
- 5 lug conversion
- cleaning head after blown headgasket
- da 4040 prop valve with a abs system
- 89 si
- Y-1 Trans grinding after it warms up
- pics
- dpfi to mpfi swap ?
- code reading
- problem with automatic
- CRX Front lip and Crx Lowering
- new to hondas
- Vtec and gsr not working in B18, possible vtec rebuild kit? drilling of ls head?
- Going from LS to B20b
- '91 Civic sedan with two CELs.
- How to go about fixing sloppy Shifter?
- ZC NOT STARTING!
- yet another very annoying dpfi to mpfi thread
- accord climate control into a crx
- 90 crx running rich Help PLZ
- are there different throttle postion sensors for hondas??
- 91 civic 4dr ????
- no power to fuel pump
- throotle postion sensor questions!
- 15x6.5 +17 fit on a EF hatch?
- Is This a Good Deal?
- i cant pass emmissions for the life of me guys....
- Dumb question re: springs for 1990 DX HB
- keeps going lean???
- What is a good brand for a fuel pump?
- jdm d15b non vtec
- Starting Problems... on 89 CRX DX....Starting Problems...Help w/ TIMING?
- transmission fluid??
- Need a good tuner
- Noob ?
- What aftermarket sunroof is this - and where can I get parts?
- quick question
- 91 CRX HF - CEL Code 12 - EGR (But it's 12 short blinks?)
- Right side Turn Signals dont signal & blows fuse?
- People around Longview,Wa
- brake light help ASAP!!!
- cruise control wiring
- Trade System for work
- 89 ef civic dx qs. about z6
- I need some help picking out an NEW catback exhaust.....
- 1991 Honda crx b16 Swap Help
- 1990 crx turn signal problems
- Car will not start
- weird sound..
- New Climate Control-No A/C
- d15b hf crx noob help plz
- my gas gauge
- 90 rex big brake upgrade question.
- Can someone give me the link to the big boosted ef thread?
- 89 civic si
- After rear disc swap, crappy brakes
- Air conditioning Help
- Front door map pocket
- momo steering wheel into a crx
- how do i take off the front bumper on my ef?
- Will a D16A1 head work on a SOHC ZC?
- vacume leak troubles!!!
- Crx with jdm D15b
- How to swap?
- back firing???
- CRX GSR Swap - Fuel pump change(Walbro) & Gas tank(possibly)
- will an Auto GSR cluster work in a Manual 91 CRX?
- PM8 and PM9 Ecu help
- obd0 to obd1 distributor help
- Torque Spec for rocker assembly D16A6.
- Has anyone had this elect. problem??
- best oil + additive choices
- ef5(wagovan) help
- having problems with 2 codes and running
- obd0 to obd1
- Head Help
- Help With Front Mudguards
- LS/VTEC HELP NEEDED!!!!
- Code 43???
- my ee2 wagon tread
- Popping sound under hard braking
- hatch back / CRX sunroof
- My 1989 crx Si
- My DX with ZC runnin!
- crx wont start??!?!?!?!?!?!?
- oil leak in airbox
- trans. problem???
- How to identify exhaust? I already took if off the car
- Torque spec - axle assembly
- TO SRAY OR NOT TO SPRAY !!!!
- Are these axles strong enough?
- IDK what brand camber kit I should get for my car????
- HELP NEEEEDED FAST
- Non abs hatch and abs da rta's... any problems?
- CV Shaft problem, won't come out of tranny!!!!!!
- Bottom Fuel Injector help
- HkS sport exhaust
- My ZC swap
- New swap info?
- Trouble
- just bought a crx with dohc zc
- NEED HELP WITH FUEL PUMP!!!!! 90 std hatch
- climate control
- CEL Code 4
- name this sensor
- Removing bushing material
- oil pressure? need lil help
- Cutting hood supports for B18c1
- Help! Civic won't turn over!
- 88 wagovan clutch, knock sensor, ecu pr3 problems? problems...
- My new 91 Civic Si project
- Exhaust Gas Recirculation Help???
- my crx..new to the forum.
- looking for jdm front strut bar and rear strut bar any suggestions??
- help wit my tensioner pulley
- Power window info
- No Power
- Do I HAVE to use a ring gear hoilder when reinstalling the flywheel?
- Rear disk conversion
- How do you put on the FRONT & REAR TOW HOOK????
- two nipples.... on b series trans
- how can i check my ignition switch
- [HELP] DOHC ZC engine code identification
- Crank Pulley Hitting Radius Rod???
- differences of JDM and USDM front ends on an EF?
- Car won't pass smog because of low compression. Swap Heads?
- NEED to know Torque settings ASAP! plzzzzz
- Da dual core radiator in a crx with a/c?
- passwordjdm power chamber intakes???
- difference wit jdm front?
- OBD2 Joys. Quick questions I'm having problems finding answers to.
- ls vtec in crx
- b16a1 block ( the sleves are all rusted) fix
- Supercharger vs. ITBs
- GSR swap into CRX, fuel lines in the way of intake.
- crx electrical problem
- Site Moving on Monday (Down Time)
