View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Heater blower isnt blowing
- Anyone here have rota track R's on their ride????
- DodgeSRT4 vs. Honda Civic Vtec (which is better performance wise?)
- distributor
- JDM D15B - How far can you push it?
- sound clip request: TURBO DYNOMAX MUFFLER
- would i need to sleeve my block if pistons were .020 overbore???
- header fitment question.
- D16y8 In 91 ef How hard?
- Manual ecu in a auto car
- 88 crx dx rear sway bar
- how good is a b16a1 for turbo?
- wilma what a bitch!!!!!!!!!!!!!!!!!!!!!!
- Any B16B Swaps?
- my vtec isnt working
- B18A (plug and play?) 90si?
- trouble wiring up power window switch
- Need help (head studs) D16A6
- NGK Wideband AFR ????
- low end power loss
- glasstop install
- folding mirror install on the crx
- new carpet
- Start Up Trouble
- a/c problems
- Will a GSR head work ?
- Crx sohc 1/4 time..what do u think?
- 89-91 rear suspension a major step down from 88? Also, does it bolt on?
- Irish Meet
- ACT street disc with Stock Pressure plate possible???
- Ls Vtec Leaking Oil with coolant??
- *Do u think???*
- crx center console
- LS swap quick questions
- 94 cx motor fit in an EF
- calling all b series turbo crx
- Not quite sure where should i post this but an yellow ef hatchback
- Did search Cant find B18 vac diagram
- 93 injectors with pr3
- Looking for a REAL Mugen kit...
- where can i find a 5in exhaust muffler?
- I bought an STD! LoL. No really, check out the new WIP! (work in progress)
- any one tried PST's polygraphite front end kit
- !!!NEED HELP, Seat mounts broke, WTF. NEED HELP!!!
- MPFI with a d16y7, ODB questions (searched)
- 13:4:1 compreesion for d16z6
- Hit coyote saturday night
- help strange starting problem!!
- Yellow Headlights?
- B Series
- 88-89 moldings crx
- D16Z6 or D15b
- LS 5th gear or S1 USDM Teggy tranyy?
- SOHC lovers... check out my friends setup
- Polished IM?
- 90 Prelude Seats in 89 Civic HB??
- Need help from anyone with a megan adjustable cam gear.
- what fuel pressure should i set my b16 swap to
- my first swap!!
- GAH! I LOVE my EX!
- driveshaft shop axles. vibration?
- Need help on Si transmission!!!
- odd brake issues on my crx
- Side Moldings Compatibility Question
- boosted ls or boosted b16
- jdm ef 4 door grill
- Crx window regulator compatability
- My friend beats his poor EF
- best throttle body w/ skunk2 manifold
- 87 CRX swaps and body
- Tx Rex and the setup
- Built B20 Question???????
- timing belt on 88 honda civic
- what motor is this?
- Looking for TDC on #1
- which distributor to use for obd1 connversion
- ENGINE FRAUD
- short throw: straight stick or factory bend?
- 5K and tach is jumpy
- stock with bolt ons.5K and tach is jumpy?
- Is there a conversion for EF front brakes?
- tps? codes crx w/b16
- need help on swap wiring
- Mileage
- help!! clutch very stiff!!
- how much is a 00 b16a2 worth with only 25k?
- stock crx EF won't start?????
- spedo cable j spec b16a
- rough idle problem, just started tonight, here's what i did, someone pls tell me what else i can try
- Strange problem with my b18 swap
- mysterious clutch problem
- Few questions on motor swap (ls/Vtec)
- Rotora
- Make a 86 Crx fast on dirt???
- What parts are interchangeable for 89 Civic HB?
- quick suspension question.
- what year civic throttle body gasket can i use with my obd0 b16 swap
- AutoX/Street Setup for CRX
- failed emissions in az, NOX a bit high
- Damn vtec!
- Look at what I got from the junkyard. And how much should I sell a PS9 for?
- Front lower control arm question: are DAs the same length/size as 90 CRX Si???
- 89 Civic- New distributor, check engine light on, car idles weird
- Whats Wrong!!!!!
- Anyone have the pin outs for ODB0 to ODB1 harness or DPI to PGMFI
- 88 hf question(d16y7)
- License plate location with FMI
- Approx cost of a D15A3
- crx vs civic hb front bumper cover.
- Civic Taillights on CRX
- intake for 91 civic hatch
- engine noises
- LS DIZZY ON B16? ............BUT NO VTEC?
- new to the efs help answer some ? for me
- tightened timing belt, power loss
- shocks
- Bad inner tie-rods?
- Clutch Q? Exced+Si tranny+D15B related
- any bad sides of naval jelly
- dynomax muffler
- fender/wheel rub
- ecu help 27c256, 28c256, 29c256
- ACT 6 Puck Sprung...With what Pressure Plate?
- Keys and Alarm clicker......STOLEN!! PLZ HELP
- CRX 1.6 DOHC Airbox??
- axle nut
- disc brake conversion
- Is there big difference between standart engine and b16a (civic 89-91 hatch back)
- longer studs?
- d16z6 swap O2 sensor
- Project: Homecoming
- ZC ecu
- Need a question answered ....For my 88HF....bout the hubs or ?
- Is it time for a fuel pump & pfr?
- problems with rear diff thump sound.
- b18a swap won't start
- Has ANyone Ever Heard Of Tranny Grinding cuz clutch sucks?
- trans problems
- Control Arm Bushing
- its it possible to put 88crx front on 87crx?and yes i serched
- Is my idling a problem....
- stock crx dx tranny work with a d15b vtec
- muffler
- 3500 rpm rev limiter????
- need help asap, valve problems and autocross tomorrow
- turbo question
- Fuel and Spark but not start
- Rattling noise from engine bay..throw out bearing????
- bolts size
- vtec in wagon
- driveability problem
- 89 si springs
- problem when starting
- rattling after header install
- how much would u pay?
- Figure THIS one out people!!!!!!!
- can i use this throttle body?
- try this
- hey everybody this is a good one . . . 7:27:32 pm
- Searched- PM7 pistons and rods in a d16y7?
- master cylinder Q's for a 88 rex si
- temporarily....
- Line-X
- My 88 EF. 4dr. 5pd. Picked up for 300.
- compression test
- D series polyurethane mounts and cat back systems?
- TE04H turbo!?!?
- Electrical problem...
- Rough Idle
- Disc brake kit
- Plug Gap
- how bout an easy way out???
- header fitment
- Wheel installed incorrectly
- can someone help me make this an easy job??
- Idle problem
- im lost
- can't unscrew crankshaft bolt
- HEADERS
- Black Vaccuum Box in 86 Si (D15A3)
- ZC tranny need a new final drive
- Ebay Intakes...
- BAD Vibration
- obd0 harness for ef
- Tune-Up for a D16A6
- E-brake
- Spark
- IM Question? Smoke, no good!
- belt squeaking???
- S1 tranny slips in 5th gear
- p30. vs. p28
- MiniMe or LSVTEC
- antifreeze dissappearing?
- Heater Core Replacement?
- Quick Question...
- What do i need to make DECENT power from d15b7
- My little Bros 88 HF project.
- What is this part for?
- exhaust question?
- HMO: Complete Change Over VS. Motor, Tranny, Computer package
- D series Intake Manifold: Edelbrock...skunk2? Will they fit?
- car starts up fine/ then boggs down
- ecu is being faggish/ iat problem
- SOHC ZC ECU?
- b16 rex vs rsx-s
- 88 CRX seats in a 89 Civic HB, will it work?
- Can I swap in a vtec-e into an '88-'91 Civic?
- Anybody have any pics of a CRX in torino red?
- help wit contact
- Anyone know who makes this?
- Exhaust Manifold '91 CRX to '91 EF hatch ??
- crx camber kits...
- Tell me how to build turbo b20 vtec
- 88 crx LSVTEC project.....from B20 to LSVTEC!
- clutch difference from 88&89 to 90&91
- Alternator for DOHC ZC CRX, stock?
- no CEL when timing plug is jumped, wtf? (already did a search)
- probably a dumb question
- Need a few parts... need part #'s or applications PLEASE!
- D16 Project!! Post your setups
- Problem whistling from throtle body
- Anyone know anything about Clifford?
- Is this bad?
- a air fuel code.. help..
- Solution to crx water leak at hatch struts.
- d16z6 (vtec) head on d15b7 block question?
- Boost Help!
- MPFI running lean
- Where is my FITV?!?!? 1990 DX 4-door
- Installed crx console in HATCH **PICSSSSSS!!
- OBD0 B16A swap into 91
- what bumper is this guys
- Hydro to Cable speedometer cable problem
- front ends
- did search... would 89 crx si motor/harness work w/ 91 civic si?
- quick question, timing belt
- Axle problem
- vacuum hose diagram?
- hf ?
- big drop
- PLEASE HELP!! ?Water pump / Timing Belt? ( stock 1989 hatch )
- wierd feeling when accelerating
- 92-95 ex in 89 dx hatch auto
- 2002-2004 Si Gauge Cluster in crx
- no vtec
- Need a radiator for ls-t civic
- 718 Hp
- Help plz----A/T trouble
- Stronger hatch shocks/lift supports for CRX hatch?
- ls swap, exhuast????
