View Full Version : Honda CRX / EF Civic (1988 - 1991)
- HF and SI injectors interchange?
- 88 civic dies on the road
- Cupholders??
- What Application? B16 head gasket, waterpump, tranny gasket
- CRX/Civic cargo covers
- what Honda center caps for GT3?
- Is there a plug on the hatch harness for easy hatch removal? CRX
- Nevin Norstrom! Show Respect! Let him be Remembered!
- heater/defroster question
- JDM B16A3???
- b16 stock headers
- zc questions
- new to the board
- what to no what u guys think i should run in the 1/4
- hatch windshield in CRX?
- Stereo
- hasport shift linkage problems
- how to fix carbon fiber hood/fender gap
- integra console not working out
- B16A1 Alternator Help
- Question about 1500civic, way back when
- a good OEM radiator ?
- ef air duct
- shift linkage!!!
- ITB's On d16 advice on install.
- Electrical issues, no crank, no start, no power, battery fine, help
- Need help- accessories and headlights stopped working.
- D15 Head On D16y8 Block??
- honda crx for sale
- ::happy new years::Apexi V-AFC wiring for mini-me swap(just the vtec wiring)?? Search down on my com
- ruff idle on zc
- lost idle screw..Help!
- trans for sale
- what gas do you use?
- distributor question
- need wiring diagrma please help
- Brake lines
- Rear 88 Civic strut mount/suspension
- car dies...alot...pleaz i need help fast
- DPFI to MPFI no spark but priming of fuel pump
- ground wires question
- GSR cluster in CRX
- imola orange CRX 88-91?
- Need Help With EF9 Front Seats
- CF hatch???
- 89 Civic leaking Coolant
- drain plugs in the passenger/driver side compartment?
- HAPPY NEW YEAR!!
- Perfectly Lowered civic !
- GC Spring Rates?
- engine cooling problems
- DOES ANYONE HAVE PICS OF CF REAR HATCH ON CRX'S??
- ls vtec swap info plz
- questions about wiring
- HELP CRX EXPERTS !!! WHY DOESNT CAR DRIVE ???
- what is this hose
- Ef headlight adjustment
- will crx parts fit on zc?
- question on what can i use from swap
- Delay when turning lights on?
- i need help
- 88 DX HB Master Cylinder Upgrade
- plz plz plz plz plz help me engine wont start
- D16a6 with d16a1 piston????
- car stops in the middle of an intersection
- si distributor problems!
- I need someone from Japan
- bad bearing, cv joint, ball joint or ??????
- Electric oil pressure guage
- gsr seats in a crx????
- need help bad with my axels
- need help bad on axels
- qucik tranny to motor question
- white smoke
- ef/da swap vs. eg/dc swap
- Main relay confusion
- Z6 Head / / / A6 Block - Is it Easy?
- Pulling axels
- shift linkage question
- How have we missed
- CR-X H22 Forbidden S.S. ?
- Can someone please help me out?
- Track car only - strip my 90 Si, or wait for an 88hf
- can someone show me a pic??!!! (where the 8-pin plug goes, by resistor box)
- motor mount help
- Where to set full throttle shifts?
- Mini-Me with ZC block... has it been done?
- obd0 to obd1 conv.
- My new project
- Battery Relocation Question
- crx throttle position sensor?
- light switch arm and wiper switch arm install dificulty
- how do you adjust the clutch release point???
- gsr swap help
- Dash wiring conversion?
- Hey check this out......VERY IMPORTANT
- Anyway to lower seating position?
- does anybody kno da best way to reinforce da dash???
- CRX B Pillar Fix
- pedistal bolt torque specs on a d15b2?
- ZC trans 2 piece axle?
- weird axle problem
- EF Civic armrest ?
- B16A1 into EE wagon
- need some help on bearing fitment
- B series block heater
- will it fit??
- throw out bearing
- really slow obd 0 b16 1990 civic
- speedo question?
- Suspention Techniques Rear Sway Bar - mounting...
- Romulater
- Distributor question
- dashlights?? Write up...
- greddy high flow cats? opinions
- need help from wiring experts (dx to obd-1)
- Mini me question searched-
- manual swap: pictures of welding necessary for shifter?
- Car wont start
- idiot question: which distributor
- 1988 CRX SI SPEEDO PROBLEM
- ZC tranny problems
- Compensator arm bolt not threading in
- ZC 1st gen!
- CRX Alternator
- WILL AN EF HATCH CF LIP FIT A CRX??
- Car Troubles.
- what are the 2 wires for (below map sensor)
- B16A 88-91 SiR 1 Question
- starter trouble
- Yet another Name those Plugs Game!! Pics included. AC related?
- JDM ZC Clutch out...what clutch to buy?
- Fuel pump need help asap
- ngk spark plugs
- new exhaust, runs like crap
- wheels specs for people that want to know
- FS:91 CRX HF
- turbo help
- B18B into '90 CRX HF
- map sensor question for 89 crx hf with b16 swap
- ZC head removal
- help!!!! need help with OBD0-OBD1 conversion plz!!!!
- ball joint woes
- crx with integra dash
- 89 HB Body Kit Opinions
- problems with ZC swap..
- Cheap DIY Mods
- new tb or bore out the stock one
- request: open up F/S thread
- Si engine harness plugging into DX ecu harness?>
- Help! Brake Problem!
- Double DIN acoord 6 cd in a CAR?
- NEED SUGGESTION ON MY PROJECT ~~MILD UPGRADE (not going to go turbo ,affect handling )
- Guage cluster lightbulb color??
- guage face swap???
- Seattle, HT's (Timing Belt)
- would a stock si tranny fit onto a b series engine
- Changing my civic's heater from cable to electrical
- GSR IAB Wiring
- b16 codes
- anybody make an aftermarket LSD for JDM S1 cable tranny?
- b18 swap
- lsvtec in a crx wiring question
- cant find wiring diagram for 87 crx si
- ECU fuse keeps blowing
- TEIN SS Coilovers ?
- CTR pistons part #'s?
- WHEN TO SEE SOME CLEAN EF'S
- Valve seal question
- Thinking of getting a 1990 Wagon for Daily...
- mini-me???
- Pulling engine
- Move a wire on the ecu and the car dies???? need help. *searched*
- New Ride
- Intermediate shaft and axle fitment (EF)
- rywire obd0 vtec sub harness
- what short throw shifter do you have
- where can i get zc parts?
- steering rack or inner tie rod ends?
- starter
- does anybody kno if 93 integra gsr trannys came lsd???
- zc swap, and si harness Q's
- this ecu worth it?
- Does anyone have these amber corners???
- Need help tonight....
- Dohc ZC Swap Underway, have some questions...
- eg wire harness swap into ef
- What is my b16a cable trans and my b series hasport mount kit worth????
- D16y8 Head onto a D16z6 block. What does it take to make it work??
- Cel 17 Stupid speedo cable broke. Need some info
- HELP COVERTING DRUMS TO ROTORS ON CRX
- Strange clanging sound coming from the lower driver’s side part of the engine
- Help!! driver side axle keeps popping out
- 1989 4speed vtec motor???
- firing order
- EF6 same as EF8?
- Whats the difference between these, and what one is this?
- NEED HELP WITH NOx
- Integra/CRV cluster into 89' Civic HB
- Best SoCal shop for D15B 3 stage VTEC swap?
- i have a dx crx that might be mpfi...and i bought a dpfi 2 mpfi harness help!!!
- engine compatibility
- ef project plans to include eg/ls...
- SSAC shorty Radiator
- Axles for my 2.0l Engine, already searched.
- What to use to 'fix/paint' trim around windows ?
- how much money in your cars?
- C`s part short shifter? does it even exist?
- emissions removal PROBLEM BAD :*(
- hybrid b series CAI any help?
- Parts needed for a B20B swap into 88 Si
- Do I need this?
- stock suspension problem
- Si IM and ECU off wagon??
- pics for P08/P28 wireing needed
- will this work ???????
- does anyone have some crx door panels for sale?
- A little bit of help here would be wonderful
- *** Head Lights****
- inner or outer tie rod gone bad?
- JDM ZC headlight qustion [searchedd]
- DA visor onto a EF hatch???
- will these axles and gage cluster fit my car
- Cooling Sytem Question
- Part number energy suspension
- im sure its been done before, but home made short ram intake
- HELP CRX TECHS !!!!!!
- Stupid CRX Compatibility Question
- where can i get a alternator belt for my Zc
- LOWER BALLJOINT HELP PLZ
- vafc installation guide needed
- Front End or Crx Mugen bumper?
- lower ball joint
- color
- EF '88-'91 Civic/CRX Cusco License Plate Re-Locator
- are civic/crx radiators the same size?
- I need a quick answer fast plz
- what are these cut ecu wires for??
- car jerking
- Which of these part numbers (master cylinders) should I buy?
- what tranny do i have
- noise when gearing down
- can someone help me
- real r fake b16b camshafts
- so I found a parts car...
- JDM ITR 5 LUG on a crx
- HONDA CRX WANTED
- 87 crx si, what wheels?
- need help
- my brakes smoke after a spirited drive around the block!
