View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Getting a jerking feeling while accelerating and constant speed
- How to reset cam gear
- Found a civic hatch need help!!
- Hatch Dying out...
- Replacing Lower Balljoint / Upper Control arm
- gsr console into ef sedan
- 91 ef
- HELP!
- 91 ef hatch d-series
- motor swap from eg to ef
- URGENT leaking behind flywheel
- Burning smell from 1990 STD Hatch
- how to check cel codes
- Distributor locked up?
- 88 CRX Turbo Setup
- 1990 Honda Civiv EF Motor Mount Problem
- 90-91 ef Civic headrest?
- cv axle problem
- ARP wheel stud replacement (searched)
- 91 DPFI EF to 93 B18B MPFI
- 3" exhaust suggestions
- Honda civic EF Vtec Solenoid problem!!! help!!!
- Sunroof closes crooked 91 hatchback
- Catastrophic failure!!!
- Injector Resistance for ZC
- ECU ?
- Fuel Tank Ground, why would someone mess with this?
- *Pics* Deleted A/C, now gutting the indash, got it right?
- B18 axle question eating wheel bearings
- Putting b16a2 into 91 hatch questions
- lost my release bearing bolt....
- need some help in swapping my motor
- b18a1 budget build
- Windshield compatability
- ZC Trans question
- Dynamat?
- Need help on headlight brackets
- Quick ECU question PW0
- Will any model EF/CRX a/c work on my 91 CRX?
- clutch change issue
- Injectors aren't working
- 91 Ef Hatch Good Exhaust???
- civic hatch corner lights and tail lights dont work
- Underneath the passenger side fender..
- 89 Wagovan Clutch Issue
- 88 CRX Parts car
- drive axle seals part number?
- CRX si: Help troublshoot fluid leak with pictures :)
- d16a6 rings? and bearing?
- EG Sidemarkers on CRX?
- Finally Got A CRX!
- Transmission swap
- a few concerns with my engine/ecu
- 88 Fuel Injected Civic - Bad Coil and/or Distributor Cap?
- ef hatch parts
- B17 swap smoggable?
- Will RPF1 16x8" 38mm offset fit a CRX?
- Aftermarket OEM Style CRX Taillight?
- ef with b18b help
- Civic losing ign.
- Bypassing 89 CRX si, Dashboard dimmer.
- Vacuum?
- Stiffer replacement Springs
- Obd0 wiring help
- Problems getting the float for the gas gauge in the tank
- B series mounts for ef
- ls swap problems
- Fuel Tank Suggestions aftermarket set up or OEM opinions please
- Lower Ball joint camber issue?
- What Did YOU Do To Your CRX / EF Today??
- rywire harness
- ef pm6 d15b1 mpfi
- Question ?
- D series cable Si and Hf question
- gauges and clock not working
- OEM or Good Aftermarket Wagon Visors
- 89 CRX si, Stalls when coming to a stop.
- timing belt on ZC DOHC snapped lastnight on highway, what to do ?
- ANYONE GOT PICS OF THE EF WITH 2004-05 CIVIC FAT FIVE RIMS???
- crankshaft wear limit/turning point
- fuel pump is staying on in key on help please
- mini me swap help
- injectors
- intake help
- looping power steering in ef
- Blown Front Shock on 100% stock Si (What would you do?)
- ????Mystery problem with EF?????
- 88 crx h22a4 stalling and no start issue
- First CRX... upper radiator mount bushings?
- 1991 CRX SI brake problems
- swap info? gsr ef
- Lsvtec won't run on Jdm p30. Just fine on p28
- SLamming it
- Injectors won't open.
- Universal o2 Sensor install problem? wiring diagram pls
- Timing/Dizzy/Help
- ef traction bar problems please help
- What RUBBER parts to replace in the strut/spring assembly
- 90 Civic EX sedan Low Idle with AC on
- 1991 CRX Need ideas... Maybe B18 idk?...
- fuel pump wont stop priming in on position
- Half Shaft Hitting LCA Mount
- Can the distributors Igniter be bad and the car still run?
- Easiest way to set adjustable cam gear (SOHC, D15B2, dpfi)?
- Fuel/Gas Leak help
- What are these called?
- Walbro 255 in tank HELP!
- replace gas tank or get fuel cell?
- How is this sooo cheap?
- REFERENCE-USDM BUMPER INTERCHANGEABILITY
- My new CRX project
- Fuel Gauge issue
- How much horsepower does my crx have u think?
- Is this possible?!
- D15b-Vtec non-vtec how much power?
- 88 hb- dc2 cluster swap?
- d16zc sohc 5 gear problems
- [85$]1990 EF Civic Hatch Project [56K BEWARE]
- How much for a crx?
- 1991 civic running rich! help?
- 90 CRX DX Wont Start/Stalls
- 90 Civic Wagon (d15b2, auto, dpfi) Runs a little underpowered
- My CV joints are coming apart during turns! Help!
- 87 civic pedals in a 91 wagon
- I am in need of help with a y7 head on z6 block in my civic wagon
- Trying to diagnose sound...
- 1990 civic T bar question
- B Series Swap Help
- Tranny drain and refill, are these the right bolts?
- EG43 - D15B2 DPFI Injectors. Should I buy new?
- ED6 failed CA smog... any tips to pass?
- does sumone know parts# to 88-89 molding door clips
- b17 has fuel and spark wont start
- need civic wagon trailing arms for 4wd help!!
- Horn doesnt work, Easy fix/test? Upgrade? *meep meep*
- Inner tie rod came out of rack....wtf?
- My CRX Build
- Starter does not turn over
- crx vti with b18c obd2 engine
- Timing issue need advice
- DPFI to MPFI obd1 no spark
- Lets play NAME THAT SOUND aka Help
- 1991 Honda Civic SI with 1992 Motor stalled while driving, won't start
- 89 crx front end problems
- HELP I need a camshaft
- blinkers dont blink, but stay lit, turn signals dont turn on either.
- Little yellow plug ,drivers side under the hood for timing?
- My 91 Civic STD Hatch
- da front brake conversion
- Ugly red braided lines on firewall/ throttle body. Can be deleted?
- Dizzy, How it works breakdown TD-02u HELP!!
- Can I Use ?
- Can This Be Fixed ? )=
- Disc conversin
- Will header from 99 civic fit 90 civic?
- z6 clutch
- d15B8 into 91' STD starting issue
- Code 3 problem
- Starting (fuel) problems
- Pin on m/relay that sends injectors power
- New to H-T and Purchased an 88 Civic Dx
- 1991 civic si lost power ........need advise
- Wheel Hub Diameter
- Can I use a electric CSS with my stock cluster and cable?
- jdm d15b vtec maintenance ?'s
- cylinder head/trans compatibility (DP/MPFI)
- Jerking Feeling
- ef sedan with ls swap code 43
- car dies while driving
- no starting out of ideas help
- 13s on ef with rear disk
- wiring question!
- low 12sec Honda civic WAGON
- Rear crush bar/crash bar
- Impressions B18B vs B16A
- dpfi to mpfi issue HELP!!!
- Ebrake adjustment *PIC* one wheel grabs other doesnt
- Taking a B series engine out of an EF
- ZC to b16 - OBDII
- New 91 dx project help
- Radio code not working
- New car, what upgrades should I invest in?
- 1990 CRX SI main harness disaster
- Is a 91 worth it?
- Cooling fans issue/questions
- ef wagon wiring/ecu/wont rec past 3500 rpms
- Got any solution ideas? SOS
- Wagon RT4wd Suspension Questions
- My 1991 Civic STD
- Help car runs rich and code 14
- Rear Crossmember Removal
- Worried. Tranny issues.
- Ef hatch power steering removal
- 1990 EF Hatchback Bodywork
- mini me not understanding this
- 5 lug conversion from civic si and rear disc conversion
- EF7 shopping list - same as USDM crx??
- EF7 brakes, tie rods, ball joint, vacuum lines. What do I tell the parts desk?
- sohc zc and dohc zc wiring exactly the same?
- 90 EF SI SUNROOF ISSUE
- Cranks, sparks, and breath's but does not live.
- SSR Rims..... what model are these?!?!
- Hackjob oem headlight wiring, are they functioning properly?
- Radiator RUST on the fins?
- B16 swap into B14
- anyone know why my car looks like this??
- header clearance
- New car! need ideas
- How to calibrate your tachometer when its off
- 1991 civic hatchback. Under dash fuse panel doesn't have power.
- picking up another 91, where to start this time?
- gearbox mixing
- crx 1990 headliner
- CRX Jdm b16a Crank Pulley question
- Question about ZC swapped 91 Si
- swapping from peak hold to sat... as simple as unplugging resistor box?
- HELP..driver-side corner turn signal not working
- 91 Civic hatchback SERIOUS PROBLEMS..... NEED HELP
- 89 civic hatchback! fuel pump/relay issues
- Does this side skirt look bowed to you?? WW Rs
- HELP! I need center caps for theses wheels.
- Integer cluster swap problem
- Coilovers
- exhaust advice?
- Alternator wiring question
- help! CRX DX ecu codes
- Do I have to go obd-1???
- What car this steering wheel came off ?
- Flow bench Numbers
- wiring question
- ECU Reprogramming
- Transaxle and valvetrain swap for MPG
- High idle/thottle body??!!!
- What to do with rear garnish? Paint / sticker / tape , etc? Show me yours!
- CLEAN 91 EF HATCH
- remove paint off mouldings
- Check this auction! EF era spoon horn button....$$
- pm6 ecu swap???
- 89 crx hf
- groove in crank snout
- My new sedan. only 38k original miles
- would this work? brake master cylinder and booster combo on an ef?
- 91 Ef Hatch offset JDM RIMS
- 1990 civic si random stalling
- 91 Ef Hatch
- DLAA Fog Lights
- hard to start
- Deleting IACV / TB coolant lines. Success?
- Can an EF be rolled in the shop with no front crossmember?
- Deleting my dead A/C system, just disconnect and remove?
