View Full Version : Honda CRX / EF Civic (1988 - 1991)
- can anyone help with mpfi swap.....
- fuel presser on my ef ls swap
- D16A8 valve cover???
- Distributor Hell!!!!!!
- will b18c swap work on 87 crxsi??
- Will Wings West door cap for hatch fit the crx??
- CAR WONT START NEED HELP NOW PLEASE PLEASE
- WTB Axles
- question about psi
- Are my compression test readings sky high?
- CRX SI sway bar on HF??
- L3
- 88 crx
- skunk2 intake mantifold
- GAS SAVER!!!! USING SYNTHETIC
- jdm d15b swap & No spark.
- Can You Use any TPS On Any TB?
- How did you make it fit?? full-race traction bar w/ eg radiator
- Converting front end . . .
- Weird starting problem
- head gasket question...?
- KYB's GR2 shocks for crx. opinions please
- Battery light and Oil light ON!
- lost motion
- It's Coming Together... slowly
- why does my car keep bogging out??
- Headlights
- 89 CRX RPM Problem
- PLEASE READ !
- DX to ZC Wiring Instructions: Same as an Std.?
- how can i tell if im buying a real SI
- h22 powered crx
- 00Si Cluster in 89DX, Anyone??
- EGR code on pm6 ecu?
- Posting of pictures
- Rebuilding ZC intermediate shaft, parts question
- b18 block girldle on ebay?
- dizzy o ring on b16a
- obd0-obd1 help
- ZC
- Intake manifold question
- Best tranny for my minime swap??? Is it an Si tranny???
- The how long will my motor last, thread.
- What is this sensor?
- obd1 cinversion
- Bucket seat mounting question
- Apex-i World Sport 2 Exhaust FS Near Chicago
- Help. What caused me to overheat!!
- Differance between left and right side axles.
- WHAT TO DO W/ VACUUM LINES AFTER HEAD SWAP
- sunrisejdmmotors.com? anyone ever buy from them?
- Can I change the headlights on my 85 Honda CRX DX?
- zc in 91 sadan?
- Doing a minime swap Z6 head and D15b2 block should I change the head studs???
- Dash Swapping question.
- dpfi into mpfi
- can you use an OBD0 LS dizzy for an MPFI swap?
- carb to fuel injected?
- Hood won't pop
- How to install a new clutch. Please help. need walkthrough.
- B-16A1 ALTERNATOR
- orang crx
- !HELP What are these PLUGS!
- What ECU to run on my B18a1/vtec swap in crx.
- code 8 tdc need help asap!!!!!!
- no start, swap
- please help to get my b20 CRX off the ground!!!!
- [SAN JOSE , CA] Lookout plase..gf 91 civic 4dr white look out please :(
- Guage cluster swap
- my first crx.... let me know what you think
- noob help first car blown motor..
- obd2 injectors with obd0 ecu?
- Code 15, i have searched and tried everything. PROFESSIONAL HELP ASAP!
- i just got a ls to put in my 89 civic si?
- OBD 0 to OBD 1 conversion harness****homemade for under $20.00!!!
- b18C block with B20 head.
- new 2 h-t can some 1 help
- B18a1 crx swap axles
- Have anyCRX b18 swap tips?
- want CRX front lip and other parts
- Ek front into a crx
- battery SIZE, CCA, and types are needed?
- will 92-95 civic hatch radiator fit in a 91 crx?
- Grinding Reverse Gear
- 88 CRX DX MINIME ELECTRICALS HELP
- need help on a swap b16 in a crx
- 90 93 brakes on hf crx
- si swap
- 91 crx hf need wiring help
- MPFI conversion??
- Integra front end on an Ef?
- shift linkage
- Can I do a minime swap using a p28 ecu and 4 speed manual transmission???
- timing or not?
- reliability of b16 turbo
- Just put B&M Fule Pressure Regulator and guage...
- Rear Disc Break Conversion on EF9
- 90 civic hatch block and head question
- Compresion after rebuild
- CRX
- what radiator to use
- any1 else have this problem
- COMPRESSION CRX HELP!
- Code 16 but only after long driving
- DOT 3 Vs. DOT 4 Brake Fluid
- noone likes wheel hop ...
- Taking apart Si headrest
- when a car burns oil ...
- replacement quarter panel
- Virginia crx's
- i cant get my timing lower than 21* why??(dohc zc)
- obd o b16a in 91 Crx hf
- need help what is this part called??? (dohc zc)
- input shaft bearing install qustions
- My Setup---looking for a base program OBD0
- Will Greddy turbo kit fit in an EF while retaining A/C ?
- 1982 civic, good beater?
- best ecu for zc
- Who makes this?
- couple of axle questions
- I HAVE NO HEAT!!!!!!!!
- Help: shift linkage?
- b18a1 ecu obd1 or not
- steering problem
- converting ecu
- ebay parts
- Damn code 8 tdc
- will a hydro clutch work for a cable
- brakes
- Need some help...
- starter problemo
- b18c1 in crx i have no fuel pressure
- What did you guys pay for motor shipping?
- B18C1/4 OBD-0 to OBD-1. What plugs with OBD-2a engine?
- Real or fake ? mugen
- Fast Idle Adjustment on carbureted '87 Civic
- Will not start.......91 CRX.
- Stereo won't turn on
- Rattle cannin it
- ef, eg, hf, si definitions
- suspension, quick answer?
- rodz n pistons for zc
- clutch cable
- gas pump problem
- 90 crx install dilemma
- tuned b16a? what kind of power are you guys making
- da cluster in 88?'s
- need help with idle on 89 Civic Si
- #1 Cylinder Spark Plugs wet with raw fuel/Hard Start
- The "Boot" that OWNED hatch STOLEN!
- What to do next?b16 internals
- ef stickers
- dizzy coild keeps blowing up. electrical gurus needed!!!
- what is better the zc dohc or zc vtech d15 vtec or the d16 vtec?
- crx and ef engines?
- which is the heater?
- S1 and Y1 transmissions
- IS this a GOOD SWAP FOR MY EF?? ( 89 civic DX )
- SiR Cluster -- Door wiring question
- Raising compression on a b16.
- Wiring for Sohc Vtec
- crx suspension question
- whats better the the vtec zc or the d16?
- MPFI problems, did search...bogging and a CEL 14
- CRX BRAKE FRONT BRAKE UPGRADE?
- CRX Traction Bars help
- Need quick response to EDM EE9 question
- ek springs on ef???
- s2000 seats in a 91 ef
- Distributor
- Look what's for sale on ebay JDM Mugen/HKS exhaust. Fits 88-91 civic,crx!!!
- hf mpg
- why are my axles binding?
- will it fit?
- my car is a moving bomb
- Turbo Manifold - Will This Design Clear My Hood?
- I'm getting this 1989 honda crx si off from my buddy of mines.....pics included too!
- Help on my CRX swap? plez
- My swap progress. B18A1 in 89 Civic DX.
- car wont start after mini me swap
- JUST INSTALLED BATTERY RELOCATOR, NOW BATTERY DEAD, HELP!
- Intake
- new manifold option...maybe?
- B+G coilovers
- WTF is wrong with my car
- cut and weld or bolt on 91 ef
- fuse box diagram
- Funny AIM conversation - discuss
- Starting the Mini-Me Project this week. 3 Quick OBD questions.
- need help on my car.. alot of smoke.. anyone got an idea... ?????
- ECU Fault code 15!!!! Ignition Output Signal missing or defective ignition output signal
- JDM fogs for 88-89 hatch?
- D15b6 (HF) head onto D15b2 (DX) block??? can it be done??
- ebay turbo kits....
- Where did you get your thermoswitch?
- nice ef for sale
- 88-91 crx body kit /door panels/audio parts
- 13.1 Crx With Zc Motor???
- another of my cars stolen.....
- Whats A better dash option??
- Problems with ABS
- Rain broke me!
- Raditor fluid Resivior Discoloration
- civic hb dash in a 88 crx
- having issues buying d15b vtec with tranny/computer and such
- LS swap in ef !!!!!!!!
- 88 crx
- 89/89 crx sunroof - same?
- EXTERIOR: major investment help
- scraping noise help
- Will stock exhaust fit over ST rear swaybar?
- What wheels are these?
- Shell ?
- breaking axels
- GSR and B16 have different intake bolt patterns right?
- Car was broken into- thank God they didnt know what they were doing
- 88-91 crx
- CRX dilemma :(
- OBD0 to OBD1 ECU HARNESS THEN A MPFI CONVERSION HELP
- clips
- Yet ANOTHER MPFI (possibly OBD1 also) Topic! Yay! Seriously Please Help Me, Thanks.
- code #6,#9,#10
- Cold start woes
- Code 17(VSS)
- head gasket on dohc zc leak?.....searched
- Clear Tailights
- Toe out on CRX rear wheels
- clutch help please
- clicking around turns
- Center Console Swap
- it smells like UP-DAWG in here!!!!!!
- Wings West Kit Removal Help!
- 91 CRX scrap help plz
- for the experts only!!!!!!!!!!!!!!!!!!
- Integra Shift Boot Question
- 88-91 crx
- D16y8 VS D16a6 not stock.
- radio wiring
- Fan switch on d16y7 from d16a6
- 8 pin dizzy, 6 wires from harness...hrmmm
- LSD 4 ME?????
- zc obd1
- obd0--->obd1 question
- free hp for your crx?
- *EF hatch - C-pillar?*
- What should i do to this crx i bought 2/04/06
- Will a 88-91 CF Hood Fit A 91 Civic 4dr ?
- HF gauge cluster in STD
- 91 hatch question about throttle body
- Burned through 2 distrbutors in 2 months - Stock D16A6
