View Full Version : Honda CRX / EF Civic (1988 - 1991)
- b16 ef start up problem
- del sol seats in 88 hatch
- A few Last Wires to finish the GSR
- 15/16 master cylinder
- MY 91 CRX Si project.
- Squeeky A/C pulley
- Tonio's 1988 Civic LX
- Vibration - 1988 CRX
- 92 d16z6 in 91 crx si, skunk 2 pro series intake headaches
- b18 starting problem
- i just got robbed
- exhaust donut for aftermarket cat
- dpfi & mpfi ignitors?
- Force Automatic Transmission into first gear?
- code 67 cat converter
- d series cam can share??
- Spark plug tube seals
- Automatic Transmission shifts early at WOT
- Sad story..
- Headlights Dash Lights Dim and Brighten
- CRX dead, best options?
- b16a2 into ef9
- My Crx has been sitting for 4 years... and I want it back !!!
- The Elusive Sunroof Plastic closing mech.
- Slow crx build
- clutch switch
- super noob question
- Battery charging/draining issues
- 91 dx mini me obd0-obd1/ 3500rpm limp mode HELP
- Need some help here guys
- My 91 Ef hatch DX project
- D15b intake into D16a6 intake manifold...
- block off plugs, link please.
- Headliner Removal
- I get to keep my swapped 89 si what mods should I do next
- a6 spun then b2 a6
- Died on Highway, bogs, finally threw code 8... EASY FIX
- zc cam vs. stock si cam
- 1991 CRX D15B / ECU Code 10 and 14
- Piston question for a D15b2
- question about cluster
- B16a1 in 1991 Si hatch needs alternator and alternator belt!!
- Temp Guage Fail
- do or die
- EG radiator in EF and Fan switch
- stuck cv spline on si trans
- whats interchangeable
- d15b2 spark plug gap size and socket size
- can i spline wires from a 91integra harness to my 89hatchSI harnes
- Civic wago rt4wd question
- drilling the manifold
- b16 hydro conversion...
- loop d pipe (heater hose)
- Black Interior in the CrX?
- My new toy. 89 Hf
- I gots a CRX :)
- unibody damage question HELP
- Need info...
- Help me out here... potential EF owner!
- are CRX rear drum and rear disk trailing arms different
- EF suspenshion question
- Friends d16z6 swapped 90 crxsi is missing a trans mount. Something else maybe?
- Will ef9 sideskirts fit on ef sedan?
- Test Harness
- 91 crx si wireing problem
- New guy
- Fuel System Wiring...B16a vs Dohc Zc
- Blox Shifter issue
- fuel pump probs/electrical
- Where can I find stock fiberglass hoods
- Another half dead CRX gets a Second Chance at Life Thread
- need help with my control arms!
- b16 alternator relocation?
- 91 CRX Si Wiring help
- EXPERT crx help needed. should be simple fix. 90 si will almost start but not fire!
- CAR SHAKES WHEN TAKING OFF.. HARD TO SHIFT GEARS ALSO! NEED HELP!
- D17A2 Swapped EF Sedan
- a1 trans
- K20 Turbo in EF...is it just me?
- need help with upper control for my crX??
- B18 swap question
- crx si dash harness
- Crx Si Fix ups
- bit help with crx del sol
- ZC Motor identification solved
- Power steering help
- Help with identifying problem
- Help identify engine in crx
- Steering wheel splines
- bad cluster
- Key stuck in IGN 90 civ hatch auto tran
- lowering spring or coilovers what eles do I need to change?...
- Half Braked...
- tachometer not working
- 90 EF Sedan wheel fitment
- in need of one pin
- stock d15 turbo setup help
- 90 ee wagon code 12 egr problems
- DIY: How to remove REAR EF hatch bumper???
- Urgent
- My 91 CRX build thread... Everyone is doing it...
- will a bmw 3 series wagon rear wiper arm fit on the civic hatch rear stud?
- pins b2 and b11
- yel/blk dpfi wires question
- finally a picture
- quick question about an engine swap
- New to Honda. CEL!!
- how to install the ef9 rounded rubbers of the fog lights?
- PR4 OBD-0 Code 43
- B Series Exhaust Manifold Interchangability
- Crx knock of death?
- crx 1st gen tail light to 2nd gen
- Car jumps from start
- some advice please
- Can't Figure Out Why My 88 CR-X Si won't Start
- FS: CRX Complete Set 90-91 Mudflaps
- gas problem???
- need help wire crx
- heat not working need help fast
- possible idling problem
- Speedometer Q
- i'm new here
- 89 Hatchbak CIVIC overheating
- body parts
- ZC serial number question
- Hmmm, I need some help.
- high idle 2000rpm
- 88-91 CRX Parts for sale
- B16a into ef wiring issues
- Video: CRX + B18C1 + BOLT-ONS
- Ignitor and fuel pump issue
- Problem starting
- swap question
- what other dizzy will wrk
- double post please delete sorry
- 88 dx to 90 dx dash harness
- Skunk2 Camber kit?
- Code 15 help... Just a quick question.
- cluster question
- ATTN:honda wiring gods need help
- need help
- What parts can I use off a 90 Si for my 88 CRX?
- New clutch not engaging
- motor mounts
- need some help guys
- Just bought '91 EF with tons of mods...
- new rookie!
- d16 sensor help
- 88 hf bogs bad
- need help turboing my 88-91 civic
- DIFFRENCES IN 89 SI AND 90 SI HARNESS??
- b18a1 ef Code 9 and code 7?
- Body and trans questions
- 3 jdm p73 and 1 usdm p73 piston on a gsr
- How to: Bleed the clutch fluid?
- 1993 Honda Civic VX
- AWD EF sedan??!
- what can i do with these extra plugs? (d16z6 in a crx wiring)
- B series liftIng points HELP!
- 1990 JDM EF9 Hesitation/Missfire When Warm
- td-28u distributor, which cap and rotor to use?
- 91 dx to 92 and up cluster!!!
- d16y7 with a 16a6 head?
- New guy and his CRX
- Pic request: Ef hatch, low offset, and fender flares
- dpfi-mpfi question
- '91 DX died on freeway >_<
- CRX cluster died, newer replacement options?
- 91 dx 4wd possible?
- Started clicks but wont turn over
- zc pistons in a jdm d15b vtec block
- cruise control- help!
- oxygen sensor wiring
- wire tuck
- Y49 Curse...
- cluster help=(!!!!
- Fuel pump replacement/gas tank draining
- ****HONDA CRX SI PROFESSIONALS*****
- crx.parts wanted. need HELP
- Top 10 Common (and somewhat unique) Issues for 88-91 Civic/CRX's
- should i retq my head studs?
- Fuel tank swap. Help!
- Anyone running power steering with b series?
- mini me coolant problems
- Holy Motor Mounts!
- 90-91 88-89 interior differenfes?
- Problems after timing belt swap.
- New Dash ?
- ls motor question
- Problems with AEM Fuel Pressure Regulator
- need help with my sterring
- 91 Civic SAFC questions
- CHECK ENGINE LIGHT COMES AND GOES?
- ECU or??
- B16A SiR 1 into 1991 Civic DX
- my honda crx 1991 si model problems need help
- plug? do i need it?
- d15b1 mini me swap/ who has done it?
- Fuel issue?? Possibly
- 90-91 civic harness bar
- 90 civic si no spark
- DOHC ZC bouncing idle.. help me please
- Buddy club seat rails
- SOHC ZC Gas milage
- Avid Racing Traction bar question
- help 90 si with 1990 b18a1 cooling problems
- just got it to run, help!
- Ef9 back fire?
- crx console
- OBD conversion questions
- obd1 vs obd2 distributor?
- $11 EF Front Lip -- Yep, $11
- 91 CRX SI Seats in 89 Civic SI
- 88 HF engine part out
- d16a6? 150 worth it or not
- 90 SI Hatch (Low Budget Build)
- IN NEED OF K PARTS FOR EF SWAP!!!!
- Correct me If i am wrong.D16 into a ef. Help!
- 1989 sedan interior swap questions
- 1991 awd pore mans type r motor swap help
- New Ef sedan Project "Help"
- Problems With Fuel System In My CRX
- what parts from 91crx-si for 91 civic dx sedan
- Swap question
- Tranny mounts
- battery light comes on and off.
- 89 civic lx sedan
- Wagon Accessories Thread.
- EF service manual
- question about installing steering wheel in CRX
- Question about using DC Integra brake booster
- its shaky
- Codes 1, 8, and 16. Need help.
- distributor help
- smokes when revved not that high
- fuse box problem....
- need FAST HELP!thanks
- new 89 4dr member
- 89 ef si Sunroof Leak!!! HELP!
- Y8 quick questions
- spedo issues
- MY EF BUILD
- acceleration problems...boosted d16a6
- D16a6 problem
- trunk will not lock, any suggestions?
- 91 hatch not moving.. ?
- Using a New Cluster
- Chipped ecu obd0-obd1
- how to check obd1 ecu codes?
