View Full Version : Honda CRX / EF Civic (1988 - 1991)
- how to tell if it's a real PR3 ECU
- HELP! My car won't start!
- CEL 14
- Horsepower gain on a d16z6 from d16a6 -->(Stock crx 90)
- Have 90 CRX DX...is the 90-91 SI bumper different??
- What to do?
- So im looking at a 90 CRX........
- Zdyne question + 89 Teg ECU
- What is a good spring rate combo for a overall race CRX....
- 84-87 crx b series swap questions.
- can't remove the clutch release shaft from the throwout bearing
- Warming up car neccessary??
- 3g integra console in an EF
- Chipped!
- Just cleaned off the DRAG CRX!
- B16 noises in head?
- Civic instrument cluster swap VX/SI ?
- Alternator Belt for B-series?
- Fuel cut?
- running open header
- Need vac diagram for MPFI
- Need opinions on a CRAZY engine swap
- 195/60/14 falken azenis on discount tire direct.com with free shipping. good deal?
- Best way to clean engine bay? searched already...
- zc problems?
- how much does a crx weigh?
- how many people are running without a front mount??
- pic request: CRX seats rewrapped
- Do you have to take off the crank pully to replace a timing belt?
- question about d-series mounts
- Civic weight Vs Crx
- my car wont start HELP
- CRX won't start. Please Help.
- who has pr3 ecu with sohc vtec swap?????
- axle problem stumped
- lowering springs????
- car wont rev up
- what's the best OEM Final Drive?
- summer d16 project
- wagon running!
- Finished my Battery In The Trunk install...
- Where were all the CRXs?
- b18a distributor
- 90 - 93 integra hubs on 90 crx what camber kit
- place racing mounts with b16a and dc headers to low
- 1990 civic question
- last real nice car you saw!
- Intercooler piping for a 91 Hatch w/ a b16 and front mount intercooler
- just did my b16 timing........car backfires
- need some help on gsr complete swap into 93 delsol
- 02 sensor qustion
- boost on ef
- If you had $3500...
- Need help wit 88 crx with zc no start
- Fixed code 4!! Now code 14, need help
- ecu help
- anyone on here have problems with their crx's fuel gauge???
- are these linkages the same?
- Apex WS, Tanabe Hyper Medallion, Feel's EF hatch muffler pics? Anyone have em?
- Will a Type R LSD fit my JDM YS1 cable tranny?
- 92-95 hood on crx?
- People with b16's, and aftermarket headers
- Will a GSR stock shifter fit in a crx?
- 14x5 rims, street tires, decent handling- your opinion wanted.
- help me with compression test
- headlight switch problems
- Help VSS wiring!!!!!!!!!!!!!!!
- how do u get rid of 12 cel code??
- can i get a carfax please!!! *hella urgent*
- Split Second AIC?
- Steering rack shot...Should I get another Si rack or a HF??
- crx dx to sir wiring help
- S-afc blue wire.....throttle sensor....which color wire is it and do i need it?????
- REALLY big problem!!!
- Big Problem!!!!!!!!
- Si head question ? 56k warning !
- clean home depot lip on my crx, need help to not look so ghetto.
- what size are axle nuts?
- pitch alloys
- HELP!!! Speed Sensor VSS on B16a swap HELP!!!
- 90-91 crx dash in to a 88 dx hatchback?
- anybody in az???
- b16 swap in 88ef
- Center Force Dual Friction clutches good?
- ZC motor question??
- doing swap tomorrow. any suggestions??
- fuel pressure?
- recaro's stock in CRX?
- Great pics with honda appreciation
- Has anyone ever put in a 89 Teg center console?
- LS ECU O2 setup?
- is there such thing as factory black side skirts?
- idles at 2500?help
- b series rod bearing size's
- Places to buy motors in NY
- Camber kit adjustment probs??????
- Lx tranny ?
- thermostat replacement
- *will 99-00 rear disc brakes bolt up to a 88 crx si?*
- just to make shure before buying, are Si and DX trany mount the same ??
- I need someone who knows!
- What is the size of the stock 90 CRX Si injector?
- No Start problem on my zc today please help!!!!!!!!!!!!!!!!!
- What do you guys think about header wrap ?
- Using the Sparco seat base in CRX.
- Removed my cross member today, quick question.
- want to use 88 crx si engien harness on 91 crx si......
- ECU Upgrade? PR3
- need help with swap...RIGHT NOW!!!
- lots of problems, need opinion
- LS owners a quick question
- 90-93 integra sway bar in 91 hatch?
- replacing b series rear mount w engine in?? help
- do EF sedan rear seats fold down ?
- Crank angle sensor problem
- Any reason to upgrade clutch?
- B16a axles
- B20A5
- just did swap for buddy and no plug fire and code 9 ?
- HOw are the cylinders numbered?
- b16 race head
- Cylinder not firing- have spark, any help?
- What size gas tank does an 89 Civic LX 1.5L hold?
- Dose the zc have a power steering pump????
- T-belt noise...
- Difference between Crx And Civic
- Will the stock crx hood still close with a zc?
- Help im gettin a code arter mini me swap!!!!!!!!!
- Experts--> misshifted, hit ~11,000rpms, now getting code 1, any opinions?? 90 crx si
- b16a in a HF?
- where to find this?
- compression questions ???
- B20 block and B16 head?
- How much and where for Alternator and Starter??? (best price)
- Axis...
- engine coolant temp sensor code please help!!!
- Real time to full time AWD (CRV)
- DPFI to MPFI = quicker car??
- Possible to put ef jdm hb fenders on a Crx?
- Help, engine goes in tomarrow and......
- ATTN: breaka_1_9
- Confirmation question: rear disc swap
- Spring Rate On Coilovers (Eibachs)
- European center console in my 1991 Si!
- DX to 16A wiring info
- Tranny help...help buy the correct parts. Lets get it right the first time.
- Cut & Weld Shift Linkage For B series swap.
- Mfg date of ZC engines?
- CEL on 90 CRX si
- civic engine swap
- is my car too heavy?
- Anybody need stuff from the junkyard??
- my rear and dash lights
- few pics of the hatch and 1 of the eclipse...
- just bought a crx
- anyone here runing a d16a6 turbo setup
- I need help on this Set Up question!
- crx inspection
- Check engine light????
- AWD Civic?
- Dyno tuning in Md/Va/DC?
- 89 crx exhaust
- will it work?
- might buy a crx?
- VTEC mini me swap is it worth it 300.00?
- Cleaning Engine Bay
- Replacing catback with aftermarket...can I use jackstands?
- Bisimoto header
- All motor d series?
- Compression good???
- Installing DC header soon...what will I need???
- Sad news about our crx....
- FS:91 civic seats
- I got a 87 Civic DX for free!!!!
- 1991 CRX and Civic Si trannys interchangable ?
- anybody happen to have a radiator and support for a 91 hatch?..sorry for...
- how much hp/tq can be gained from a dpfi to mpfi swap.
- Front Corner Lights Stolen! Need Help Finding Replacements
- Will 90 Civic DX airbox (intake) fit on my 89 CRX DX?
- clutch is barking at me??
- help with a shimmy and clunk
- 91 standard gas tank leak!?
- squeeling
- Anyone interested in aftermarket D series axles?
- need confirmation ..... climate control differences
- d16a1 and b18a valve specs?
- Checked compression: results okay, can valve seals still be bad??
- sohc vtec swap questions.
- weird problems
- Have you ever heard of a motor having more power in a different car?
- Need some advice
- New to the CRX B16a swaped honda!!! A few questions!!
- FAQ: How To: EF Canards
- 88 interior into 91
- B16A1 tranny question
- 88' DX hatch with LS-Vtec only beats VW Passat turbo by about 1 1/2 cars?????
- Suspension trouble!?!?!?!
- Is there a conversion between wire GAUGE and AWG?
- ABL sensor
- b16a2 into a 89-91 crx
- B16 axles in a 91 Civ HB SI?
- Universal muffler question
- doch zc wanted LA area
- Question... Anyone ever puta d16y7/8 in a 89 rexSi.....Comments welcome!!
- wheels ?
- How can you tell you have a Vtec? I mean its just a vavle cover? more info please
- sohc vtec ?
- zc sohc vtec questions
- a do it yourself thread.
- SteeringWheel Swap
- ECU throwing codes (help)
- 95 ls gauge cluster into 91 hb si help.
- CRX armrest
- need a pic for my swap...ASAP!!!
- wiring diagram qeustion
- popping noise?
- HASport mounts = viberation..... how bad is it?
- mini me swap, 4-1 header, intake, exhaust, how much Wheel HP&TQ?
- Need help with my swap...ONCE AGAIN!!!
- Are Koni 2 way adjustables as good as KYB AGX??????
- What are your 0-60 MPh and 1/4 mile results on D16A6???
- question about idle on crx
- 92-95 civic ex CAI in 89 civic
- Is a 2" drop on Tokico blues too much? Also, trim bumpstop or not?
- 3rd Annual 88-91 Civic/CRX Meet in PA
- I think i'm throwing a cell * HELP*
- which of these 2 crx's would you choose
- Ignition Thoughts...Please read
- D17 crank in a D16.... Possible?
- d16a1 pistons
- to vtec or not to vtec, that is the question
- dh-racing d16 160 wheel hp worth it or not?
- building up my ZC head
- si door panel
- '89 Civic Transaxle Question
- zc in a crx si??
- my new battery. lots of pix
- help z6 in a ef
- h22 swap...relocating the side mounts?
- Got a new engine (B18A), opinions on what to do?
- b16a1 head and ITR block, does tranny slap on?
- '88 crx hf and dx weight differences
- 91 DX auto-manual?
- People with D16y8 intake mani swap.
- side bottom molding??
- Converting a 4th gen hb into awd/4wd?!
- D16A6 rebuild overheating... *was* overheating b/c i am a MORON! :)
- how do i take my rear bumper off??
- How do these come off?
- where can i get a header for an 89 accord
