View Full Version : Honda CRX / EF Civic (1988 - 1991)
- What in your opinion, is the best motor for a daily driven EF?
- One more question about the mysterious yellow wire?
- CRX Rear defogger Question ???
- IACV HELP!
- HELP!
- what type of connector
- increasing load cap of CRX
- 91 hatch tail lights
- Check it out!
- lightest hatchback model
- i'm moving and can't take my project car CRX
- Need a hondata tuner!!!
- I play video games way too much!!!
- 95 d15b swap question..
- CRX w/ good interior at local junkyard
- 91 crx carbon fiber front bumber
- where are all the 1990 honda civic si hatchbacks?
- timing belt. Need help!!!!
- coolant leak
- how do i take the roof liner out?
- I <3 deer
- I <3 deer
- integra console
- Si seats from 91 hb to a 88 hb?
- are all 89-91 clutches the same ?
- 89 CRX SI FUSE BOX DIAGRAM
- OVNI's STD
- shift linkage question
- pm6 computer problem help
- widened steelies? opinions?
- 205/50/15 crx
- need help
- 90 honda civic please help
- resistor box needed?
- Please help me find out what code(s) are being thrown (vid inside). Im having trouble
- CRX running slow
- HF manifold oem heat shield
- i need another crx
- jdm cluster connectors
- finally got my new wheels mounted...now I need suspension...
- How much tranny fluid in a B16A????
- Surging Idle problems ECU occasionally throwing code 04 (crank angle sensor)
- DPFI To MPFI conversion?
- d16z6 clutch fit on an crx si trans?
- question about b20
- Question about an 81 Civic/Vacuum diaphragm
- i need to get a header 4 my 87 civic si where can i get 1 ??
- sticky pkg brake when cold weather
- crx si clutch wont disengage Please help
- car wont start
- Codes 1, 7, 20 on a 1991 Civic Si w/dohc zc
- MPFI swap runs rich - Isn't this normal?
- Hey guys, i need to remove my front end!
- smoke comin out the ass of my crx
- dx or HF???
- MULTIPORT FUEL INJECTION SWAP
- Whats your favorite?
- steering response
- new to the forums
- loss of power at 5k rpm
- injector cleaning/blueprinting
- Is the shift linkage for my CRX 4 speed the same for a CRX Si 5 speed??
- MY HATCH IS IDLEING CRAZY
- horn doesnt work
- b18c swap complete, now need suggestions for intake, header and exhaust
- 1991 squarebak auto trany to 5 speed swap info please anybody
- My window is stuck
- Smog questions?
- 89 civic dx hatchback
- Hi guys i need help, Front end removal
- Where did you get your MUGEN bodykit from.
- 1987 CRX
- Wire tucking, question about multiground
- gauge question
- Hood Dampers, Hood Shocks for EF, and CRX
- code 9 ??
- i have a code 23. what is that?
- quick question
- Skunk 2 cams!!!!
- Need to know how to adjust Full Race traction bars
- Coolant rushing to my combustion chambers
- Temp Gauge screwed up--sending unit?
- i want opinions on this turbo kit
- clutch pedal pad
- Strut problems
- Car will not start........
- Wiring Help!
- suspension setup: tokico HP's with Eibach springs
- What ecu should I use?
- bleeding brakes
- Whats the best for a rex
- wireing harness question need help!!!!!!!!
- A very not important ED Sedan Question....
- Guage cluster Clip Broken need help.
- VTEC spool solenoid valve
- misfire on cyl 4 need help figuring out.
- timing
- Everyone says a sedan hood won't fit a hatch or crx.
- Push-button climate control to slider control...
- wiring diagram
- New 90 DX! With Questions?
- 89 civic suspension setup question. Reviews would be helpful :)
- d16a6 with d16z6 is it possible??
- ahaha...im guessing the lug patterns on crxs are 114.3x4 right?
- Header????
- Automatic Seatbelt question need help ASAP
- pix of painted steelies?
- help!!!!!!
- Help with wiring
- Getting read to swap in SOHC ZC - searched just few questions
- whats your fav honda rim???
- i cant find these gauges
- hello doing a 1991 autom into 5 speed
- hey i need your help if u can
- obd1 or 2 in crx
- wiring question on ef
- noob question on b-series axels
- MOROSO 11/5/06 pic's
- Whats Wrong with your EF today?
- home made kill switches...
- ST rear sway bar on crx dx
- turbo plugs
- 91 crx, problems starting.
- walbro fuel pump install? & buy a JAZZ FUEL cell and get rid of stocker???
- Quick Question (AC/heater)
- gauge cluster question
- what happend to mmr
- a/f gauge info
- 91 crx dx suspension, LCA/sway bar
- People who've done custom charge pipes. click me!
- Car wont Start
- CRX SI ZC SWAP NEED HELP !!!!!
- Ef with JDM B18C and DC sports front Strut bar?
- Resistor box with OBD-1 injectors... throwing code 16 and won't start.
- AZRaceMachine B-Series EF Mounts...How Close Should The Tranny Be To The Frame?
- spark plugs
- i've got some brake problems that just wont quit
- help me fix my pos crx!!! ++video included++
- cr-x carb setup
- tire/rim size question ...pic inside..
- how to wire for multipoint inectors
- will the SI sway bars bolt....
- b18a with BLOX
- Steering wheel shakes (cant find that post!)
- wat engine to drop in
- 90-91 cluster in 88-89 crx
- Dpfi to Mpfi using the mpfi engine harness?
- CAN THIS BE DONE?? HAS ANYONE DONE THIS
- EF hatch front core support
- DA vs. SI-R Knuckles which one?
- should I get hangers welded on my header?
- corner lights
- Whats Goin On? Problem Question w/ Pics!
- racing seat brackets for 88 civic
- 1990 civic si : Rear drum to disc conversion
- I'm starting the LSVTEC saturday
- HF bumper support for Si ???
- RTA matches, which teg fits? (searched)
- dpfi-mpfi hastle!
- EF8 CV Boot's compatible parts.. and driveshaft help
- Death of One Rebirth Of Another
- Upper timing belt cover?
- What kind of damage does over revving cause
- D16y7 tps/throttle cable/iacv valve
- k series into ef ?'s
- No spark I need help please
- New Motor Won't Start. Need Help ASAP!!!!!!!!!!
- I was told Honda-tech had all the experts
- strut removal
- Good Steel Braided brake lines for 88 CRX?
- Turbo CRX Hondata s200b trouble?
- HOW TO JACK IT UP!
- Why you never leave your REX sitting forever
- Where to buy nippon pistons?
- Eibach sportlines...
- Redline changes?
- Is this my main relay??
- is it possible to converse Carburetor to Fuel Injection
- help! i need torque specs!!
- hasport shift linkage for crx on back order any other kind that's good?
- Need Help... throwing 2 codes... researched
- CRX on a diet??
- Master cylinder/brake lines
- Fuel Pump
- body difrence
- Cluster wiring problem
- weird problem
- Racing coilovers
- code 22
- em stud pulled out with nut(no pun intended)
- Need help agian: Car won't start and makes whinning sound.
- I can't tell how fast I'm going!!
- Can i put in a B16A Gen 2??
- em gasket surface prep..........
- how to get GC coilover sleeve loose??
- 90 civic ex
- Ball Joint Interchangeability
- honda civic with 1995 acura front end
- need help with gsr swap bogging issue
- Will a 91 DX seat frame bolt up to an 91 SI?
- 90 civic std cigarette lighter ?'s
- crx paint
- WIRING HELP NEEDED ASAP!!!
- Question/Advice on radiator size?? Want to put intercooler and radiator side by side.Help
- d16y8 swap into 91 CRX Si?
- EF ATX tranny... where is 3rd gear? Help!
- Searched but found nothing, water puddle in passenger side??
- Help
- Can I use my 88 Civic axle shafts with a 90 Crx Si Tranny?? Are the splines the same?
- Rear hub/wheel bearing
- 2 am boredom questions
- HOw to install GLOW GAUGES in 88 civic lx
- What's your favorite SOHC forum
- calling all ac gurus
- from d16y8 to d16z6 in crx questions
- Free mods?
- HELP!! My car stalled on the freeway pass.
- noob, 91 civic dx hb
- swap or fix?
- Weres the Rear Disk Conversion Thread!
- my car at my job
- how do i get pics of my rex on here through wtdr?
- timing belt and cam gears off about 3 or 4 teeth and turned engine by hand HELP!!
- Removing Manuel Steering Rack in EF?
- problem with buddies EF pulling hard to the right
- injectors??????
- evap help?
- one piece lights
- Bad Idle on 88 Civic ((Pics of Ghetto Rig Inside)) 3 Questions
- Where can I get a DOHC ZC
- Crx HF Question
- for those who use one of those v-tech controllers .....
- car doesn't turn need help
- b18b wiring prob
- Type r pistons in b18a1 block
- Rack end bushing and lock washer
- Are you terrorfied to drive your EF in the rain?
- skunk2 hose diagram
- NEW MAIN RELAY NEEDED PLEASE HELP !
- swap d16z6 on d16a6 block
- SOHC ZC 1.5 or 1.6 pics from japan brochure
- JDM CRX Bumper
- civic Type R N1 Crank Pulley
- Crx swapping info needed.
- never seen before oil cooler? i dont know where the coolant lines go.
- socal ecu chipping
- stiff springs (searched)
- HELP!! Tranny issue
- What kind of spark plug to use?
- obd0 tranny and obd1 tranny
