View Full Version : Honda CRX / EF Civic (1988 - 1991)
- n00b/Old-Schooler checking back in! Also a question?
- Crank specs?
- crx ed9 B16a1->B18c6 by Ziombel
- sir gauge cluster
- B18b1 Crx Wont Start..
- Prelude Fogs question....
- E-Brake handle removal help
- B16 engine build
- wd-40 on outside of rear main seal?
- crx and civic door striker catcher
- D Series LSD Transmissions
- tie rod problem
- d16a6
- 1989 Honda Accord
- Cluster out
- what do you guys think about koni vs. kyb shocks?
- Car doesn't start, not main relay or battery issue
- Can someone please tell me who makes these rims?
- REAL hydro conversion ??
- dash conversion on an 89 EF3
- CRX Windshield washer pump question
- Crx Armrest haahh
- E85
- B18 into CRX
- B16A EF Axles/intermediate shaft
- SOHC ZC Questions
- skunk 2 LCA on 88 ef hatch
- 91 ef hatch
- Poly shift linkage installed - shifting is now a workout.
- itr integra type r booster and m/c will it fit with a skunk2 intake manifold?
- 89-91 gauge swap
- Trans done?
- my 91 ef hatch
- Question re OBDO fault code
- 90-91 CLUSTER QUESTION?
- Coolant temp switch wiring?
- will 90-91hb interior rear side pannels fit on my 89 hb
- New to the forums but i need help swapping my ls into my crx
- has anyone seen this crx before?
- jdm climate control?
- Survivor
- oil leak?
- My EF Build Thread...
- crx starter
- Center Locks on a EF Hatch? (Instead of Lugs)
- Fuse box wiring
- Window help!
- Water In My 91 CRX
- revs jumping up and down before downshift?
- Easiest way to remove alternator from CRX???
- 1 wire o2 sensor @ the collector?
- Civic Wagon Temperature Sending Unit
- b16a1 (need help)
- Code 8 (dizzy) ?s
- coolant sensor / o2 sensor
- 1990 CRX Si Cranks But Wont Start
- New member with a promising start.
- fuel pressure issue
- installed ground control kit so why is this my car so low?
- Green/Whitish Liquid from transmission?
- b18a1 swap into 91 civic hatch
- integra cluster in crx trouble shooting
- wont start after drive
- 91 civic not cranking over need help
- Intro: 90 CRX
- 90 crx si. Thumping from rear tire/tires
- rear crossmember replacement??
- 1991 Civic Auomatic Seat Belt Malfunction
- Bearing messurment HELP !!!'
- FITV delete on d16z6
- Rack & pinion carsteering.com
- How do I wire this distributor?
- weird eletrical problem
- D15b2 Help
- Spring rates front to rear
- How to bend Skunk shifter?
- Everything on my cluster stoped working!
- 1990 civic D15bB2 to B18A1 slow, slow swap need help.
- 1990 crx mpfi swap
- d16z6 build on ef hatch question about my new camshaft
- roof rack..need help please.
- A few b series questions for ya.
- Is this a good deal? 1991 crx intake
- Emulating with Ostrich 2.0 and TurbEdit 3.2.2
- What should I ask for my 91Si hatch?
- G/C Koni Setup EF9, Rear sitting uneven, what to do.
- crx si under dash harness
- speed cable question
- Anyone know why the speedometer can be off???
- DA IN EF CLUSTER SWAP
- constaint beeping while car is started
- d16y8 into ef std hatch... questions
- New Mini Me Build:)
- EF STD B swap question
- Starting problems after zc swap
- DOHC ZC / D15B2 MPFI Swap
- dohc zc ecu
- does EW3 = DB15A3?
- 89 crx dx, cranks but weird noise when trying to start!
- Suspension part replacement brands?
- Question re 5th gear ratio in J1 gearbox
- 88 CRX LCA or 89 CRX LCA
- d16a6 mini me question
- What tools do I need for Starter change?
- 89 CRX hf No power to ecu, no fire, no fuel pump prime.
- new 89 sedan!
- OBD0 to OBD1 question.
- bucket seat recommendation?
- disc brake convserion hangup
- Car jerking at low RPM why???
- Electrical Gremlins - My Brake is an "On" switch
- radiator issues/questions
- 88 Honda Civic error 20
- Tach is Pinned all the way up SPRING?
- 91' SI Fuel Problems
- Jack Stand Placement
- 90 CRX starting problem
- pic request: Konig DTD Zeige's on EF Hatch
- crx gas pressure problem
- Ef honda civic problem, need some help,
- Swapping clusters on 1991 ef
- 4 lug conversion -- 4x114.3 ?
- b18c to ef7 crx
- Crx 1st gen b16 clutch issues
- Tokico illumina
- EF Sedan Cluster fit in EF Hatch? (Sedan as Tacmeter or whatever)
- Ef lighter problem
- Custom gauge advice?
- What mods to fit a function 7 subframe brace to a civic/crx chassie?
- Back from the Dead Tahitian Green Crx built thread
- ground control complete spring and shock kit
- Axles help
- My dad has an STD!!
- 90-Honda Crx si intake manifold?
- sunroof problem...please help
- what to replace when...
- DOHC ZC Sputter problem
- '90 cx white smoke fuel smell in exhaust, not HG, help?
- oil question PROBLEM
- metal piece behing crankshaft pully
- d16y7 timing
- D16a8/ZC DOHC ARP stud kit - head & mains
- regrind camshaft question
- K20 Rex buildd
- 89 CRX died while driving... Fuel pump issue
- got my buddy club spec II exhaust...confused...
- How do I know if I have a CRX SI
- need info on d series.
- Short shifter
- Crx an ef parts??
- D15B2 swaping to D15B question.
- DOHC ZC Issue
- Difference in CRX seats
- CA smog question...will a 90-91 zc pass smog in a 91 civic dx???
- DOHC ZC Hood Clearance
- Drive Shaft for K20 into EF9
- 89 CRX Si dash to 90 CRX Si, mounting only
- MPFI CONVERSION HELP
- where do my high beams go? A or B ?
- replacing shocks, need help from suspension gurus
- 1991 EF 1.5
- PLEASE HELP. thanks
- b16 IM (smog) help needed
- replacing previous owners kill switch, what do I use
- B16 Throttle issue.
- b20 crx plans
- what should i do?
- CRX driveshaft problem
- need some suggestions!
- Upper ball joint 89 CRX
- 90 CRX Si lighting issues. ICU?
- Traction Bars
- Why do the front wheels get knocked out of alignement?
- clutch pedal
- brake conversion question?
- OBD0-OBD1
- Need advice on swap
- d16a6 driver's side motor mount
- Ideas for a 1990 civic hatch? top ten upgrades?
- CRX disc brake conversion trailing arm bushing issue
- Code 9 and 10 car jerks
- 4 wire o2 obd0?
- ef9 b16 for bar
- Thermostat problem?
- quick question about smog and car battery!!!
- Where can I get another one of these?
- steering conversion!
- Code 43
- how much does the crx hatch door weigh?
- 89-91 civic hatchback starting problems
- bumper fitment
- Occasional Bogging/Loss of Power B16a
- IACV, IAT, & KS plugs, Check Engine Light
- B18b1 In ef Out of time maybe??
- How do I remove the front bumper of my 91 crx?
- jdm D15B tuning ideas
- Crx rear brakes question
- Ef B16A Build
- 90 si crx seats
- Feedback for battery HAMP
- Integra obd1 distributor internals into obd0 distributor
- timing belt broke in idle, what's the damage ? -- d15b2 , CRX DX
- Thrust Washer Question
- Is there a way to replace the side lens on an EF tail light?
- diy gauges
- Crxb16a2's offical 1991 honda Crx build!!!
- Removing the Distributor
- Charging system issues
- EF IACV
- shift linkage pin is stuck?
- Master Cylinder Fittings
- Wire Harness Issues, NEED HELP.!!!
- PR3 Vtec wiring questions!?
- my boosted ef build
- universal flywheel holder?
- D16z6 with a d16a6 dizzy need help timing it
- a6 block vs. zc block
- 88-91 Crx/Civic Accessory Part Number Database
- 88 CRX - Climate control lights
- d16a6 power
- CRX rear wheel bearings?
- battery light came on :(
- Cousins CRX having Rev Issues
- Tach Problems 91 Si
- Ef fuel problems??
- Need to set the idle
- B18A1 Swap into an 87 Hatchie. HELP!
- d16a6 stall isue when around 1/4 tank
- dx brake light wiring
- Car won't crank
- rhd crx front lower control arm bushing question.
- ef b20b help!!!! please!!
- 91 wago wont start
- F.Y.I. 88-91 OEM CRX Labels part numbers
- factory ride height
- Its all about the HP to Weight ratio
- 88 crx engine problem
- Check Engine Light Only On Start-Ups
- Brake issue doing rear conversion....
- ef sedan
- What would you do differently on you build if you could do it again?
- No Speedometer
- ef8 sir hydro trany mount ?
- Problems replacing a lug nut stud 91 Honda Crx
- No compression in one cylinder.... What are the chances its valves? rings?
- How much is d16a6 head worth?
- 1990 hatch overflow issue
- Pulling d15b2 as we speak, for jdm zc
- Obd0 codes/whats wrong?
