91 CRX OBD-0 OBD-1 Swap. Starts Runs 30 Seconds Shuts Off
Old Sep 21, 2015 | 01:29 PM
boxerdogguy's Avatar
Icon5 91 CRX OBD-0 OBD-1 Swap. Starts Runs 30 Seconds Shuts Off
Hello to all in Honda Tech.
My buddy has a 91 CRX Si, the D16A6 had a wore out bearing on the bottom end. So he swapped in a D15B8 (I think) from a 95 Civic DX. (Obd-0 to Obd-1 Swap)
He bought the conversion harnesses off of Ebay for the computer and distributor. (Not sure on the Seller)
Done the swap, Engine is in, everything is hooked up. BRAND NEW MAIN RELAY AND BATTERY. Turn the key and Go to start it and you can hear the fuel pump prime. Start the car and it'll start and run. Only for about 30 seconds then shuts off. Go to turn the key to try and start it again. You don't hear the fuel pump prime and it won't start.
It has the Intake Manifold off of the D16A6 on the D15B8.
Any help is appreciated.
Old Sep 21, 2015 | 02:42 PM
tamboo's Avatar
10 Year Member
Default Re: 91 CRX OBD-0 OBD-1 Swap. Starts Runs 30 Seconds Shuts Off
Starting Problems
MervTeck
Feb 23, 2017 03:57 PM
TehTaylor
26
Jan 30, 2012 11:49 AM
slickrickauto
10
Aug 17, 2008 03:57 PM
crxlex
Jan 24, 2008 07:22 AM
SRCivic97
Oct 22, 2004 05:27 PM
