View Full Version : Honda CRX / EF Civic (1988 - 1991)
- crank oil seal - how are in does it seat?
- Compression question
- Turn the lights on, and the Car cuts off!!! HELP!!
- Anyone have a Door glass for a CRX DX?!???
- Wiring reverse lights
- About the tranny
- more F'n cars stolen WTF
- a few clutch Q's
- got a newbie question
- 1994 Integra seats...problems???
- whats better?
- throwin codes
- what would be better?
- need to stop spinning
- why does my car start at 2500 rpm on cold start?
- CRX Interior Mod Sugestions....
- Question about auto trans and turbo "need EF guys help!"
- if i change my head gasket and mark exactly the position of ea screw on my distributor will the timi
- after hours of reading thru the search still wonder can you use DX distro for MPFI?
- Is this the middle section of a cat-back exhaust???
- rear disk brakes in 4thgen civic
- BEST Performance Exhaust?
- OBD0 to OBD1 Harness
- electrical problem
- Project car possibilities?
- 7/8 or 22mm
- Eg Seats in 89 hatch
- Starting a car thats been sitting?
- Quick question-MAP or MAF?
- Help:Retarding Dizzy cap
- B16 Part #'s
- mpfi coversion gurus
- injector help!!!!ASAP
- What do I redline to with a B18a in a CRX?
- need help,where to get hasport shift linkake?
- Ummm...91 EF rear wiper?
- JDM ZC tranny/ USDM Si Final gear ???
- Will a 92 integra dash fit in the 89 crx??
- D16Y8 camshafts
- Ahhhhhhhhh.....The Tranny Is F**KED!!!
- 90-91 JDM SIR cluster in a 90-91 hatch how to
- SHould i trade?
- CAR MIGHT be toasted?!?!?!?
- Make your own dust boots for coilovers !!..... pics inside..!
- Looking for broken CRX cluster
- civic EX radiator in a crx
- speed o cable?
- Front brake upgrade, new struts???
- What's an LS Cable tranny worth?
- Hondata Tuner
- Rattling from under my CRX, Rack and pinion?
- High Flow cat question
- SIR Cluster dimmer switch........
- Putting B16 rods in a D16 engine
- b17 CTR pistons ARP rod bolts?
- People that do new swaps
- where is my VSS (speed sensor)?
- ls turbo? b16?
- b20 video...
- what kind of supercharger
- building trannys how to?
- Timing on ZC, Car wont Start
- Car was fine. Now won't start. Ideas?
- What are the reasons for converting from OBD0 to OBD1 and is the cost worth it?
- Tuning d-series
- LSD in B16a tranny?
- How can you tell if it's a B16a tranny?
- People with B-series: vacuum Question.
- leak at block
- taillight ground?
- Finding Current Selected Gear (Is The An ECU Input)?
- EG seats in an EF
- To those who like 18" 's + on a CRX ...
- Steering question?
- I don't know why, but it seems like CRX drivers are the worst!
- Nopi has anyone dealed with them
- quick a/c question!
- Do I need to use phosphate fee coolant?
- Any of you B16a guys looking for a J1 trans?
- d16y8 mani using 90' Si ECU & V-AFC unit..???
- Windows only roll halfway down, how to fix?
- 90 hatch fit 89?
- noob question
- L3 Transmission
- Anyone use Velcro?
- Rear disc brakes worth it performance wise?
- Backseat removal, help!
- 94-97 Accord Conversion into 91 CRX
- Integra Center Console
- need a website that shows the gearing of y1,s1, and j1
- Front plate on the side..how to?
- distributor, easy fix
- crx dx vs si seats
- JDM acution!
- anyone selling a 88-89 crx climate control?
- FPR vs AFC??
- axle wont fit
- Suspension Techniques sway bars
- Good idea or no to use pr3 ecu with sohc vtec?
- Anyone have a driver door glass for a 91 CRX?
- will a b16 throttle body fit a type r intake manifold?
- who can tell me more about this obd0 to obdI conversion harness i keep hearing about?
- they got me again!!!!
- i got beat by a 92 civic si hatch today
- Anyone needs a PW0 ecu?
- How to Pass CA Emissions??????
- LSD in stock si tranny?
- what do you guys think of this?
- d16a6 with d16a1 pistons- CR?
- D16a6 intake mani Vs D16y8 mani?
- code 1 on d16z6???
- obd1 or obd 0
- fuel cut off at 3300 rpm
- Someone revise my list?
- pm8??
- hybrid ZC tranny questions
- Prelude seats.
- Recaro SRD Bracket for 90-91 Civic
- Check It Out All!! Im Back After Only 5 Months Of Basic Training And Tech School!
- Different, smaller radiator for my crx.
- 96 Civic bolt pattern = CRX's?
- DPFI to MPFI which ECU's can i use?
- Tranny Question
- how can i tell if my distributor cap and rotor is going bad?
- how can you tell what year..
- seats in crx..did search, please read...
- springs w/ a 1" - 1.5" drop
- about eibach road race spring kit...
- About a race
- anyone in here run a d16z6 with obdo?
- ZC tranny questions
- ZC pistons in a DX motor?
- ls vtec cleacance?
- Need a DIN slot gauge holder? Click here?
- What kinda shocks you got?
- Radiator/Fan for B16 CRX
- Small video clip
- New Clutch or New Tranny?
- body panels
- quick question on using civic ex front brakes
- apc ignition wires
- max hp
- can someone show me the reverse light butt connectors
- syncros for 1st gen b16a tranny?
- Carbon Fiber fenders
- JDM Parts
- Any of you who converted to PS have a spare non-PS speed sensor?
- ebay chips
- Civic leaking or burning oil?
- CHEAPTURBO.COM Has anyone purchased a turbo from this website.
- zc piston question.
- Civic dash to CRX dash
- what kind of swap?
- si to std civic swap HELP!
- Thermal Classic vs. HKS Sport
- Need help on this VIN#
- Brake pads?
- Running lean
- wiring question
- OBDI needed to Run B18c in 88 CRX? Pre OBD is key!!
- odd rev on b16 swap
- Confused... b18a or b16a??
- Need Help!!!!!This is urgent....question on VIN numbers!
- carbs exsist for b-series?
- 84 civic wagon
- New B16 Swap revs funny and lopes HELP!!!
- looking for a crx
- Looking to buy a CRX, which is the best investment?
- My First Honda ..... 0wn3d
- What tranny for the LS Swap????
- guage cluster.
- type r intake manifold vs. stock b16 intake manifold
- CV joints / axels / shafts / whatever
- real quick ?
- headlight removal & install
- awd wagons
- Thermal Exhaust with dual tips like stock Si muffler?
- please help,exhaust question...
- another intake question
- CRX prices
- 91 civic si rear speaker mounts??
- d16y8 swap->Apexi VAFC to activate Vtec with PM6 ECU??? HOW?
- pm6 w/ v-afc or p28 on d16z6
- d16 help needed
- Drop In Engine for 1988 CRX DX
- ZC head installation
- How fast can you make a crx go w/ a b16??
- 89dx guages to 89si
- Major problem with A/C!
- 93 corrado VR6 SLC vs 15.5 sec Stock CRX
- possible bent LCA or more?
- may need a new tranny in my 90 SI hatch<what to get??
- anyone got a door panel????
- 87 Si highbeams don't work...
- Does anyone has prelude Sh wheels on there CRX or Hatch
- WHAT kind of springs are these?
- leaking above hatch?
- Wiring 5g ecu to 4g harness
- Rear Disc brake change over?
- fpr or ecu upgrade? which is better?
- Old school CRX's and Civs
- no reverse lights?
- Mudflaps and scraping (with a pic)
- HID Kits for CRXs?
- do zc's have egr valves?
- looking for tail light topic(poll), help
- CRX Si Motor
- Spoon knob fit stock CRX shifter?
- Passing tech
- emissions problems - have the diagnostic report - what do i do?
- swapping a B18C1 into a crx
- Quick Question?
- found a site with rotas and free shipping
- Crank Pulley
- Shocks and Suspension for Auto X?
- US-ZC vs JDM-ZC mounting differences???
- Changing headers!
- B16 Tach question
- gutted my wagon
- question on b16a in a non si crx
- Whats the best catback exhaust for my CRX?
- Tired of denting your 4-1 header
- I can get an extra set of 88-89 CRX Si seats for 100 cdn worth it?
- URGENT!!!Need help on Stolen or clean CRX SI shell!!
- New to the Boards
- For those who have done this
- intake, header, exhaust
- Painting Door Handles, side mirrors..
- x-member
- anyone know where to get headlights?
- ECU Chipping & O2 sensors
- ECU Pin Layout
- Finally, got my new exhaust on!
- question for mini me guys
- Place Racing Crossmember...
- ZC manual???
- Getting New Bolts and Screws for Parts
- Does anyone's Hatchback show up as an LX on Carfax?
- Black Molding on the Roof of the Hatchback
- Mini Me Questions Pls!!!
- New Site, Needs Members
- front bumper removal..
- How much si the 88si lca go for?
- check it out...
- hasport, place racing or hcp???
- throttle sticking
- um ...just curious
- squeaking noise when i turn...embarassing!
- curb weight on a 88 HF CRX,, no Ac or PS?
