View Full Version : Honda CRX / EF Civic (1988 - 1991)
- d16a6 puting a z6 on and want to turbo on
- Springs to get!
- ZC times at the track.......
- Chances of Pressure Plate &/or Flywheel bolts backing out......?
- ...I cant hardly wait....
- Well well aint this a beoch
- Relay Assy, Problem..
- Amber corners for CRX
- fast shizzle
- what spark plugs for b16
- Need help!
- Lexan Replacing Hatch Glass, pics and questions.
- Did an 88-91 Hatch ever come with a rear wiper?
- j1 tranny sucks
- honda hook-ups import tek in upland...........
- Ef front clip and side moldings
- Color code???
- Quality of R1 racing seats?
- DX harness
- For "psikoticrx" Removable Steering Wheel
- Valve Cover? Did Search!
- whats the best way to run a gsr swap in a 90 crx ??
- Would a b18 affect my turning ability at all?
- front lip???
- HI AMP Alternator
- turbo on 88-91 civic
- who can post 90-91 wiring diagram for ECU wiring with B5 and B14 pins
- si or ZC tranny?
- exploded tranny pic needed, please ASAP
- Installin a 93 teg gauge cluster in my CRX
- oem struts for rex's
- might be done with the race car...
- LS in a 88 HF
- e what octane?
- roll call: Phantom Grip users: likes? dislikes?
- roll call: EF hondata users- likes? dislikes?
- 89 Civic Si seats in my 88 HF???
- CRX guys...need some help...
- Looking to upgrade to the Integra console?
- Rate These Vendors ...
- good radiator?
- San Diego I Need Your Help ....
- b17a into a 89 civic dx
- B16 on 91 CRX HF, newbie Installer.
- Help: i made a mistake with my interior.. paint....
- which cat?
- is there any way this will fit???
- What type of LSD in Y1 tranny?
- Clutch Job
- 5 lug on 91 si?
- civic back seats
- another Ls motors question
- couple b16a questions...
- can i get this bolt from local autocarparts?
- Ok? why dosn't my cd player work?
- bilsteins w/ neuspeed race
- Are all EF backseats the same?
- '93 Civic Si gauge cluster swap
- trannies
- Need help w/valve adjustment
- Need help on tuning!
- Wiring Guru's OBD0 to OBD1 conversion alternator woes ?
- D16Z6 swap.
- civic/CRX wiring
- Carlisle Custom Compact Nationals 2002
- silencer ??'s...did a search
- Ls motor question
- Ebay ecm chip for pm6-c00 thoughts, experiences, concerns opinions
- GSR Guage Cluster
- Is it safe?
- More turning tips please.
- whoring out my polished valve cover
- coil over?
- DX or Si Harness??
- weight of engines
- JDM Pr3 B16a injectors?
- have a Q
- Mid-section exhaust?
- Blown headgasket. Which to get?
- got a Q? about a crx dx
- what do ya think its worth
- Pics of 4dr EF's???????
- Myth about DA Brake swap on EF Swap
- F22a swap in Civic 4dr 4thGen
- H22 CRX...
- ZDYNE USERS - Have any of you guys recalibrated for 550's or 720's...
- crx si timeslips...
- budgetted shocks / springs / brakes
- 88-89/90-91 cluster differences
- Bypass the BS and Get a Del-Sol?
- Disc Brake Conversion Mayhem (long but entertaining)
- 88-91 Civic/CRX FD Question
- d series crank, need some answers
- what do white spark plugs mean
- Anyone ever had this problem before?????
- anyone put a crx exhaust on a hatch???
- i need more power in 3rd gear on my ZC
- Help, can't see to figure out what this piece for the shift boot does.
- THE WEIGHT OF AN EF.....1/4 Mile W/ ZC
- 15x6.5 with a 25 offset and 4x114.3 lug pattern....will it fit my CRX?
- anyone rolling on white-wall tires??
- Y8 swap A/C?
- car dead!!! need help!!!
- MORE rear disc swap questions.
- How do I do this???
- disc. conversion-help
- 89 dx automatic axles the same as manual ones?
- CRX, B series, a/c and Someone told me something funny?
- How do you ship a long block?
- Should i get 90-93 Teg Ls, 92-95 Hatch, or 88-91 Crx?
- Remembering the EF7... ( not 56k safe )
- Lets say you unplug your O2 sensor would your ECU run 100% rich?
- quick question...b16a HB vs GSR
- what the diffrence and how?
- what next?
- 91 crx si tranny 93 d16z6 what clutch?
- Looking to by Crx in PA,DE,MD area must run looking to spend around 1,000, show me what you got?
- Rolling fender
- anyone prep their own car for paint?
- Wheight Question
- which do you perfer
- Apexi v-afc question
- Power Door Locks in CRX? Who did it and how?
- Climate control...
- pics of a ef8 anyone?
- skunk 2 exhaust for crx...
- DX CAI!?!?!
- Anyone have some exhaust bolts??
- need help...
- ECUs for sale.....
- what does a d16z6 go for?
- Brakes bogging engine?
- I need some help...
- I know its been asked but, should I go with dc sports or skunk2 short shifter ?
- Sup guys i need some help finding something... inquire within
- b16 - CRX - radiator hose ?
- Hey Got a motor question
- Showing off yesterdays bumper mods!!! Lip pictures inside!!!
- car covers for 4th gen hatches?
- What should i pay??
- Steering Rack Q?...
- Anyone have one of these sitting around ???? "Please Look"
- What do I do? Transmission issues. Pwease help.
- I'm a fool, bounced a curb. Please help
- help need detailed instructions on how to change axels
- Roll cages?
- Power Window Problem
- whats the url for hcp's website???
- Heater/Defroster Problems
- Does HCP's EF-18x come in black?
- throttle body sizes
- what are the differences between dx and si hatchbacks?
- what is the engine code on the 2002 Civic EX m/t coupe?
- N. Cali Peeps!!
- Anyone Running a 88-91 Civic Std in SCCA ITC?
- 50 shot with a greddy turbo
- finally! i'm a crx owner again, check it out, give me suggestions
- Did a search No luck... Can you guys give your expertise or head me into the right directions.
- difference between HF and DX?
- Tach cant keep up
- Which engine?
- B series swap into 88-91 hatch questions (help needed)
- Driver Side - No Dome/Seat belt lights.. pass side works fine
- Technical ECU question
- injector question
- Lots of problems
- P28 ecu question
- )one thing leads to another
- Best Upgrades for SOHC VTEC
- b16a crankshaft in b18a???
- ***My CRX won't start. I could really use your expertise!***
- Anyone else amazed with the quality of the CRX interior.
- would this work???
- 89 Si motor into a 91 CRX Si
- does this work?
- Question about stock SOHC VTEC engine specs
- window off track...won't close properly
- quick questions
- Anyone know Si-R's?
- 88 si tranny, what flywheel..
- ide werid?
- Opinions, OBD1 in a CRX or what..
- What drums can i put on the back of my 91 rex??
- All zc owners!
- Battery Light on again, =*(
- Coilovers. What should I get?
- having trouble shifting..help
- quarter panel has a My civic got rearended today.....How much money Should I expext to get for this?
- Stock CRX motor CODE 1 ECU???... heres the details
- Minime
- keeping bumper up with out bumber support?
- hey hybrid crx guys i gots a question..i tried searching...
- Temporary heated O2 sensor CEL relief ?
- Blew my trans-axle now what?
- Any way to identify rear disc brake swap componets?
- Which pad to choose?
- Oxygen sensor on B16a1
- caliper part number CRX
- what is the most common reason for the cel to pop on in the cold
- People with b16's and hasport linkage please read !!
- b16a questions
- bouncing idle, pulsing brake, suction noise
- Who runs 13in. rims
- How to blow a dx motor...? any suggestions...
- How much would you guys pay for a B16A (please read inside for details)?
- what size head light is the high beem on my 90 civic?
- Changing gears in LS S1 trans
- Can I use eg's front lip on my si-r front bumper
- which oil filter do i use for a first gen b16a1
- USDM valves for a ZC?
- B18A questions
- CRX Wiper Switch is posessed
- EF8 SiR with B18C5 - What ECU to use?
- 91 std 4-speed to 5-speed
- 99-00 Si
- wiring a p28 ecu into a crx
- Axle help
- Will a 89 crx si guage cluster fit a 91?
- Gas tank sensor screwed?
- Testing waters... offers for 89 Si..
- had a blast tonight- went to a 2by2.net pyramid scheme rally....
- ignition jumper thing stuck on car affect performance?
- Fuse #14????? please help
- just got some new seats!
- Where could i tap the ITP sensor?? *pic*
- Crankshaft pulley bolt gone!
- new to the crx
- problems!!!!! axle....
- D15B1 restrictor plate
- Teg vs Crx fuel sending unit...
- Lowered CR-X in 2 1/2 inches of snow, with yoko paradas spec 2
- B & M short shifter
- What Racing Seats should I get?
- home-made light alarm/buzzer
- lower ties bars
- Wait a minute you could get USDM style corners on a JDM crx???
- Why do the back of the CRX si Seats have map pockets
- Can you switch lips
- dark lamp...
- GS Exhaust Sugg's
- to the axles in a B16 swap fit?
- civic EK gauge cluster
- D16 oil turbo lines..........Show them to me
- post ur N/A and FI ZC times
- VTEC crossover
- D series upgrades
- ok i have a problem
- Lowering options
- who did: EF w/ sohc v-tec motor...
- About my Suspension HELP
