View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Vtec issues! plz help
- OBD0 code #1 heated 02 sensor ?
- Help! CRX electrical issues..
- 1989 crx parts needed!!!!
- *just bought*89 hf body & 89 si motor
- Reuse Head bolts
- H22 SWAP MOUNTSS CHEAPPP
- need sum help with my fuel pump
- b18 bad gas milage
- 90 civic si new relay solid cel no ecu codes no fuel
- can someone identify this rear t-bracket???
- new p/wire fusebox to batt. and stater
- lower ball joint fits lca too loose ?
- new car only throwing code 10 obd1 gsr on chipped p72
- Need help figuring out a couple things on my 91 ef
- Balljoint assemblys being replaced soon
- which brake lines to get? choose by caliper or by car?
- ED3 code 20
- Suggestions and info on shocks
- 1991 Crx Dx for sale 500$
- my ef bomb!!
- Hatchback headlight question.
- HF with a ZC sohc
- Help with switching heads
- Looking for EF Parts!
- rsx cluster in ef hatch!
- ef/da front subframe interchangeable?
- Front brake upgrade
- springs
- zc with y8 head
- part number request
- Ignition switch installation help
- B18 swap questions, help please
- Temp gauge dead after head gasket changed
- Obd0-obd1 harness help!!
- Quick turbo ?
- Is my track time ok?
- 1990 honda civic lx swap
- B Series Motor Mounts for EF Hatch?
- 91 dx hatch missfiring after a fixing a blown headgasket
- Help finding a car club
- HondaTech Newbie
- Tire/wheel help
- z6 swap in ef
- OH MY!
- Headlight - Hood gap JDM Front end
- high hp ef clutch line question
- Heat Broke!
- need some help asap its getting cold out!
- Ls trans B16 clutch?
- help with my 90 crx ef please!!
- QUICK QUESTION ABOUT MY CARS IDOLING!!!!
- crx b swap idle problem
- USDM vs JDM crx doors
- O2 sensor problem with dc headers
- Honda CRX heater wont blow hot air
- Burning Rich$$??
- How to change a rad in civic 90 h dx
- Long time CRX owner. Thining of selling. Link with pics.
- 91 ef help
- Tenzo Miester V2 16x7,EF-Bumpers...
- troubleshooting fan
- mpfi n obd1 converted sedan hessitation and rough idle once warm.
- 88-89 Si OEM Seat Covers
- td 20u dizzy?
- obd0 or obd1?
- Crx B18 turbo project from accross the pond
- 91 CRX RPM Problems
- Turbo issues need some advice
- '88 CRX DX DPFI to MPFI nightmare!
- New guy!
- ignition problems
- Rear Engine Rear Wheel Drive EF/EG/SI/DelSol
- Cleaned out my rear sunroof drain tubes
- Tahitian Green Pearl - BG28P - Work in progress
- Can't find exact parts, what's interchangeable?
- Now I'm down to 22 MPG out of my HF...
- The Mutilation of my 89 CRX
- Time for new dizzy?
- Crx idles perfect, warms up, then idles at 2k
- please help soon freezing my ass off
- Rear Lip?
- I have a question
- 1990 honda civic si hb tail light gasket
- turbo civic vs bike
- h4h bulbs
- swapped to obd1.... not starting
- coolant flush procedure
- Need best solution to torn timing belt, bent exhaust valve in no. 1 cylinder
- good replacement for D15B2?
- water in tranny....
- Chargespeed EF Wing for Hatches
- Installed a Convex mirror in the Drivers side mirror
- obd2 dizzy on a6???
- 1990 CRX Si
- ef shocks
- Cupholders in Civic?
- Finally scored myself an RT4WD today
- TPS troubles after mpfi swap and maybe more...
- both oil light & check engine light up when decelerating ?
- 88 crx 97 gsr CEL help!
- Power Issue on 89 EF civic
- MexiChriS 1988 CRX Si 'KMF' Build
- my car just diedd.
- Cooling fan not working (90 crx b16a)
- auto door locks. key locked in car. need help....
- Replace crossmember?
- relay issue, possibly....
- side marker dementions????
- Tuning Options
- Wiring Diagram
- 1990 Civic DX: Wont Start, cranks but doesnt well... start HELP!
- Help!!!! need lots of different parts 91 civic
- 91 civic question???
- glass beading
- Dash harness question!
- CRX has trouble going into reverse sometimes.
- help a noob make a good decision.
- Ignition troubles. Lil bit of help?
- Strange intermittent hesitation
- Off Idle, cuts out.
- d16z6 swap info 90 ef si needed...
- vibration on accleration
- no spark from ignition coil, can someone help!
- motor for sale!!
- 91 civic hb, d16z6 motor/L3 tranny, needs throw out bearing, help?
- 91 dx color cordinate issue
- b18a1 crx bad injector timing?
- No full throttle or vtec
- 91 realtime auto wagovan shift position switch issues?
- Gauge Lights Broke?
- Ls turbo motor .. kid has it for sale, $575? worth it?
- Easy way to lower seatbelt mount for short people - what PN is this?
- Is RHD worth it/anything? From a driving experience, in the USA
- Tachometer Install Question
- Rough Idle when warmed up
- Idling perfect Shutting down under load...
- EF sedan radiator
- 1991 honda civic lx needs your help
- header question
- tanabe front subframe brace
- 90 Hatch...Starts quick then Dies. Need opinions
- HELP D16z6 Wont Crank
- JDM D15B
- Usdm front end.!!!!!
- JDM CARROZZERIA PIONEER 3WAY SPEAKERS
- D16z6 cel problem
- Help, what will it take to turbo my engine and not blow it up?
- 88 trans upgrade disc?
- negative caster on pass side need help
- 91 CRX Sputters under 3000rpm
- stumped 91 std hatch ilde problem
- crx climate control and heater core vs hatch?
- RHD EF8 conversion
- 1990 Honda Civic Low Beams fuse location?,,
- FS: EF9 siR parts
- 89 EF Project : Rusty
- a little confused need some help
- Tie rod removal???
- 88 rex si for sale
- b20, b16 head, y1 tranny, air research turbo
- Which would be better?
- Would this fit on the hatchbacks?
- Dash switches
- Temp. Gauge Issue
- Wiring up rear edm/jdm fogs?
- best place to buy 2.5 mandrel bend piping!
- mpfi injector wiring help
- bar d16z6
- new build coming up
- 1991 crx, need input on engine and suspension
- d16y8 wire harness question
- 90 crx struts diff then 88
- Some pics of my CRX and my Hatch
- My hatch is finally the way i want it! tell nme what you think
- Tired of high idle. Solutions?
- this doenst sound good
- OEM CRX Equalizer...
- Engine Management
- vacum and map question
- pinion bearing
- ECU wiring help
- 15a ecu fuse blows when i turn the key. Really need help
- Tranny Question.
- Looking for 1st gen crx tail lights
- Axle seal?
- ef9/ee9 SiR/1.6i-VT taillights how to make em stay on & blink
- Suggested price for CRX w/14b turbo fully built
- from brakes to no brakes
- ef hatch loss power and sounds like puttering
- Brake Fluid Leak
- how to get type r rep seats in ef?
- FYI Y-49 EF's
- Those of you with a y-49 EF (or wish to paint your y-49)
- DX and Si cluter interchangability
- 1990 honda civic si hb legal mods
- losing electrical power/bogging
- Running lights help?
- 91 crx si not starting, possible fuel issue
- Up up up
- 1988 EF DX door panel upholstery change.
- ECU question
- rywire harness problem
- Point out that plug
- tuneref9 ed6 winter build
- Tail light teouble
- lose power every 4 mins on highway
- 1991 honda crx backfireing
- 1988 CRX DX Engine/Tranny swap
- 88 si trans problems
- chronicles of my d16a6 build
- STD vs. SI Axles
- Fun in the snow
- Another Vtec Issue, OBD-1 GSR
- 91 si timing problem? help...clueless....
- Best motor route?
- civic ef rev problem
- interchangeable injectors for mpfi crx
- stock d rear mount
- Function Form type 1 coilovers question...
- just pulled my head
- Sparco Pro2000: what non-custom seat rail will give the most headroom?
- Toed in issue
- My Extra Slow ED7 Build Thread
- Rusted hood.
- crx catalyic converter spring?
- EK Side Skrts?
- help me fix my tach plz!
- ef civic sedan interchangability with ef wagon???
- [pic]high comp all motor
- Please help
- WTB awd civic wagon
- Flimsy Top!
- carbonator gods?
- cluster pin out
- d16z6 bottom y8 top
- b16 1st gen or 2nd gen?
- 90 civic parts
- 91 civic temp gauge doesnt work & cd player will not turn off with car!
- mini me question
- What gauge wire for battery relocation.
- Gsr powered crx with b16 tranny quick question about "shaving" stock crx clutch cable
- My JDM EF7 build so far - Loads of pictures!!!
- Is it just me or.. FAQ problem?
- Jdm front end conversion pirces?
- hood wont open!!
- F/S:Honda "non-smoker" personal box
- Using a traction bar with stock crossmember?
- newb
- CRX hood latch problem...
