View Full Version : Honda CRX / EF Civic (1988 - 1991)
- d15 vtec
- heater core
- EE Wagon Trailing Arm ???
- abs axle
- is it pssible to remove the solenoid element from the starter housing?
- ef9 seats question
- sluggish??
- Should I Drop my Car or Not?
- Where can i find seat brackets?
- b swap
- HeadLight Bulb Problems.
- Need some help with gauges for my car........
- Roof Wing Help
- Help code 8 and code 9.
- GSR swapped crx wont rev past ~2500 in gear but revs fine in idle!
- transmission forks
- HELP! car wont start!!
- 89 ef9 b18a1 civic typeR
- what ecu does the 90 ex sedan have?
- Teg Center console
- fuel/idle problems - help me :(
- Wiring Harness question: 8 pin connector
- STD d15b2 Dyno Graph
- Guage cluster stupidness...
- Odd behavior from auto trans
- Cluster lights won't stay on
- Turbo kit
- std 91 hatch - no int wiper
- d15b2 block d16y8 head
- Need a Source for...
- lowering springs
- air conditioning
- weird headlight adjustment prob.
- Water temp guage not working? searched
- Car wont start sometimes
- cranks, but no fuel...any insight?
- Need Help with EF Rear Disc Brake Swap
- need so help with my crx
- Engine Help Please
- To keep or not to keep? (garaged crx)
- aem fic anyone use it?
- hub centric rings for my EF? what size?
- h22 crx ??
- quick question. need info
- another high idle problem
- 99 axles on 91 hf
- Dohc ZC transmission gear not enaging?
- need help here please
- newb question =[
- HELP!! Is it wise to trade my Audi for a CRX???
- is there any diff in hasport B series tranny mounts ?
- Hf brakes question????
- SUPER NOOB to the EF's
- i need help taken out my ac !!!!!
- simple question regarding ignition
- 89 hatch b16 no spark
- 88 civic lx 99 jdm b16a swap
- alignment off after rear discs
- *Intake manifold interchangeability* D16a8 DOHC ZC
- code 1 issue
- my new unmolested crx
- know anything about the ELD???
- fuel but no spark. URGENT
- handheld tach testing rpm
- JDM B16A LSD Axel problem
- Wiper switch compatibility with CRX '91
- help with codes
- my 1990 civic DX what ya'll think
- Wheel movement
- hatchback stolen (626)
- my project as of now
- Keeping A/c in Ef with a B series swap.
- puzzling axle problem plz help
- I turbo'd my car but...
- built b16 head, gsr block with all type r parts
- Are these good coilovers?
- 1990 Civic Si - D16A6 Wrong Clutch issue
- fuse wont pop on my crx
- obd1 o2 wiring question
- will eg harness plug into the ef cabin?
- D16A
- Engine/Tranny
- Headlight
- New Engine
- Axel fell out of cv joint nned help
- 91 integra DA fuel pump and housing in a 90 civic ef hatch
- need help badly
- vtec solenoid question
- Civic Sedan Help
- Ignition signal output
- electrical problems with ecu... help !!!
- How do you take the rolling door handle off?
- Rear wiper removal question
- need help!!!
- no spark n no fuel
- 90 CRX Climate Control
- tranmission problems!
- changed fuel filter now car wont work HELP
- went to KC yeterday for some toys!
- air conditioning help
- what do i need for a zc ????
- fuel pump hassling problem!
- EF civic Slim Radiator
- what clutch cable do i use?
- starting problem
- wiring issue, inside part of engine harness...need help!!!
- wierd help request
- car dies
- tranny help fast
- b16a2 timing belt
- master bushing kit
- Help needed ,, from Sweden
- HELP! running super rich! low end sputtering! terrible MPG's WONT PASS SMOG
- Civic 1998 starting problems, start-lock/ignition lock?
- in need of wires!!!
- CRX si Axles
- Need engine management for a B20B turbo (non vtec)
- which brand makes the low priced camber kits?
- crx electrical problem???
- Intake box question
- gas
- LS OBD1 Swap, bogging problem, and rev limiter Please help
- running to rich
- Cant find where the fan wire goes
- info requested
- Dohc ZC Code 8 Crx
- 1988 Civic DX upgrades? (first time owner)
- Battery Drain Problem
- crx front end conversion and taillight conversion
- Need some zc/d series help!
- HP
- cheap cat converter?
- ::: PLEASE Help I need to know what I can use for Hood Spacers!!??
- need HELP with b20 swap in a 91 si hatch.....any gurus help.
- CEL, code 43, Anybody?
- 89 Civic DX 4dr 1.5l A/C Relay Location?
- Axle Fitment
- cable zc transmission....
- 91 civic tranny swap from automatic to manual
- obd 0 ecu vs. obd 1 ecu?? why should i switch?
- i need parts 2 to be exact
- HVAC issues.
- ZC head gasket,, What kind to go with while boosting??
- CRX OEM Sway Question - 1988 box style LCA vs later 1989-1991 LCA - bolt up?
- Wat to do about oil?
- how aerodynamic is the 88-91 civic si?
- 1989 crx si fuel tank question
- crx fuel capacity & mpg
- Euro D16Y8 Manifold
- What do you make of this D16A?
- i want to sell my crx
- ssr caps and locks for super fins
- SOHC Vtec
- Obd0 b16 LMA?
- Check engine light
- EF exhaust question.
- skunk2 full coilovers VS. function form on an ef???
- NEED HELP ASAP
- Motor swap
- B series swap cooling fan prob
- What Intake for LS
- Rear Brake Light Won't Go Off Please Help
- Crx DX DPFI Throttle cable too long
- 91 civic sedan EX ZC engine...couple of questions...
- msd external coil question
- Dohc ZC IM vaccum?
- No Light on my ECU!!
- dim e brake light on all the time
- Skunk2 Intake Manifold Help
- help me please
- Uk guy coming to Daytona, any good Honda shops?
- help!! my brakes suck
- Need help!!! 88 crx Wont start
- HELP. Rear disc 88 Si question.
- wire harness for b16a obd0
- mpfi conversion
- CRX SunRoof problem
- over heating problem
- Leave the CRX stock or swap?!?
- bought b18a1 dont know what year
- random misfire cylinder 3
- B16 alternator choises...highest amps
- ECU Plug Wiring Help
- 91 civic DX auto trans shifts hard
- Hf bumper supports on a civic hatch.
- What exhaust?
- sunroof installation
- vtec solenoid question!!!!!
- I NEED HELP! smog referee!
- da shocks
- b16 has no power when given gas.
- Car leaking water and overheating SOme HELP !!!!
- d16z6 radiator hose?????????? need help quick!!!!!!!!!!!!!!
- CRX exterior locks question
- ::HELP::engine wont start and back firing
- Help: Will 90-91 civic hatch front bumper fit my 88 sedan?
- which timing belt?
- code 73
- 5 lug conversion
- clutch pedal too high
- breather chamber Q
- 4dr performance exhaust help
- 91 SI burning oil
- clack noise after swap?
- loud banging coming from rear
- Building another rex, need opionons.
- question about the 1988-1991 civic wagon???
- b series timing belt HELP!!!!
- 88 CRX DX engine and trans into 89 CRX HF shell - drop in fit?
- Fuel Issue?
- My Brand New Project.
- Question about boosted d16
- Water Leak
- b16 exhaust mainfold
- Brake problems after changing pads
- Hey Guys Just a Couple Questions
- Engine balancing
- Tires...
- Has anyone dealt with this company??
- Exhaust on mini-me?
- speed cable not working
- coverting cable setup to full hydro!
- Rear Disc Swap Done
- IB/Blueprintmfg lowering Springs
- Ls vtec into 91 crx HELP!
- Obd1 Interior Harness in a EF chassis
- battery relocate
- Quick Question
- bumper filler!?
- Beeping on start up
- Please help DA Master Cly on a CRX?
- rear mud guards for civic hatch
- Wont Rev Out
- Help.
- Tranny question
- Need help with mount kit.
- Clutch Cable Too Short.. Causing Clutch Not to Work at All ?!?!?
- 1991 crx si idle problem, and map sensor
- crx lip on civic ?
- cam gear
- Yet another question on the HAsport EFB2 kit..
- ???? dpfl to mpfi ???
- where is the prop. valve on a 90' dx????
- Looking for help with a part number - 90 CRX rear divider shelf plastic piece
- No Power - 89 HF - Need Help
- help with steering issue
- EG flywheel w/EF PP, clutch disk, starter?
- Looping Idle
- i need info on putting a vr6 lip on my car
- someone has to know
