View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 1991 civic si hatch b16a1 problem.
- Where to buy a b16 from?
- 5 lug conversion to 5x120
- Dpfi & Mpfi Question
- AC delete, here is a rare find, the AC Condensor delete block up front of the radiato
- 1991 Honda civic Si hatchback dilemma
- Help a newb get his sedan back on the road.
- 91Dx Hatch Wont turn over
- 89 CRX Si CEL codes 6 and 15
- Mounting bumper without support
- Seat options
- Main relay doesn't click all of a sudden
- Need to identify a part.
- Obd0 pr3 - KS code
- Is this a legit B16A swap?
- Marker lights
- 91 Civic EF wiper linkage bushing
- CRX ZC race car no spark
- Headlight Reflective coating
- 1990 Honda Civic running issue
- headlight adjustment
- 1991 Honda crx DX obd1 ecu swap.
- brake fluid replacement.
- 1990 CRX SI ECU Flashes With No Jumper
- 1990 CRX SI
- 91 sedan dpfi>mpfi and obd0>obd1 question
- 15x5.5 45mm?
- timing. retard vs advance
- I need help with my sedan
- ef resistor box compatibility
- bad main fuel relay symptom..or something else?
- Compression test
- Ef Civic Wiring Havok
- Electrical issue
- B16a civic ee9 error code 6 ect/coolant temp sensor
- 91 dx hatch mpfi no injector pulse
- MPFI D16A6 , Is it possible to make it accelerate quicker ?
- CEL and shudder
- Suspension specs for 89 civic hatch image included please
- Bride racing seat for CRX Si
- 1991 RT4WD Wago - Died, but lives?
- life sized hot wheels ef9 project
- battery light above 2000 rpm
- Air conditioner issues
- 97 Integra MAP sensor wire matching
- Crx undercooling
- 90 EF - Crank No Start
- Vss sensor install in 90 crx si
- need help elimintating an oil leak
- Use a 4th Gen prelude hubs for a b18a1 swap?
- How to install door tumblers on 1990 crx si
- Idle problems
- Help with 90 CRX hazards and turn signals.
- Ef2 civic sedan: HELP ! Need to ID these Clear corners
- Will speedometer work in this set up?
- Vibration
- will bad oxygen sensor cause sputtering when giving gas?
- Obdo to obd1 probs
- Swapping speedometer/odometer into another cluster?
- Failed emissions.
- Car is tilting to the left.
- Wtf is this bumper
- which axles for hydro transmission
- Are all b series valves the same
- Jdm b16a first Gen help!!
- Swapping a Jdm gsr b18c into my crx
- Wipers move on there own?
- 4 speed to 5spd swap
- Transmission Bracket HELPPP
- D15B VTEC Turbo in 1991 CRX HF
- 91 civic hatch w/1.5L brake issues. help plz.
- I am a little confused...... Any suggestions??
- D16y8 Ef swap !!
- Bosh fog light mounting bracket
- Hoosier s7
- Car doesnt start(no spark)
- Skunk 2 rear control arm not lining up.
- 1991 DX Hatch, lights dim under electrical load
- Not starting.
- dpfi to mpfi but with other questions
- Direct wire TPS to ecu?
- Help to lower and camber.
- Is it harmful to relocate my battery to hatch?
- incorrect exhaust rocker arm installation
- Camber Kit?
- Coolant problem
- Crx won't run :(
- Broke off temp sensor in engine
- 91 civic hatch b16 swap ?
- Crank but no start , fuel at rail, compression, and spark
- CRX keeps dying in traffic after 10 minutes of driving
- Having trouble with my ZC engine over heating
- Starting and driving issues on 89 civic DX
- Cant find 89 ef Amber lights
- AC Thermostat Alternative
- Rear Tail light leaks
- EF9 Over heating
- Crx rims
- Camber kit I bought on ebay 15 years ago
- HAS ANYONE BOUGHT & INSTALLED SKUNK2 ALPHA HEADERS FOR THE D SERIES MOTOR?
- How would you deal with this?
- bumper supports
- 1989 Wago wont start. Need HELP
- JDM SiR blower motor resistor
- Core suoport questions
- mystery plug w/mystery jump
- Honda Fit Wheels
- EF rear seat belts
- Ef hatch bucket seat going in a crx help
- 16-i16 Conrod dimensions
- 90 Civic HB sputtering
- 89 parts for 91
- drivers door won't lock w/key
- EF sedan rear eye LCA - rear fork compatility?
- B16 swap wiring issues
- Crx w b18c lsd need help with upgrades please read and help!!!
- What size Radiator hose to use.??
- no fuel '89 dx
- A/C coming thru defrost vents?
- thescr33nn4m3's 90 SiR EF9 build
- 90 EF ZC swap fried the ecu got new want run!
- CAI Question
- Street tires!
- Replace rods or entire rack..
- Kanjo build
- Clutch cable help
- Brake lights WTF!!!
- Impossible to calibrate new tps, no 5V signal
- What do you think looks better on a Civic Wagon?
- Help with an olé D16a6
- Sedan garnish sticker
- How long to charge a battery at idle?
- 91 civic hatch isn't getting spark
- Stereo/Headlights cutting out
- 91 CRX Tacho issues
- civic ef hatch b16 cranking noise
- 91 EF hatch chronic smoker
- CA BAR for DOHC ZC engine
- Under dash fusebox help!!! Starter not turning over, and radio getting no power.
- Turn signal causes gauges/lights to flicker
- d16a6 Not warming up to operating temp
- d15b2 with zc cam
- 1986 crx black smoke
- dylspil's SiR EF8 CRX build thread
- Flywheel cutting into oil pan! HELP
- fuel bubbling out of tank
- B-series swap need some info
- Why is the 89 Civic Si coveted over the 90-91?
- Driver side engine plug help
- 1986 crx header
- Here we go again with the AC compressor
- 1988 Civic transmisson throttle cable??
- Crx power steering question
- 1988 Wagovan wheels
- HOTTUNING coilovers?
- Need help on Dpfi-Mpfi for 91 DX
- More help identifying butchered wires please
- Door rattle
- Crx f20b swap.....NOOB!!!
- Idles fine/drives poorly
- A/T dpfi to obd1 A/T mpfi wagon swap,
- #lolhonda Build Thread/Greeting Post
- EF9 vs ED9 rear suspension
- Need Help with a Surging Brake Pedal
- 1990 CRX si rev limiter adjustment help
- SOMEONE HELP d16z6 swap....
- How to remove this box?
- Obd0-obd1 WIRING HELP! swap help!!!
- D-Series cable trans: ZC, LX, DX, Si, anything
- Check engine light turn on in 5th gear?
- innovative hydro
- Wilwood Rear Combination brake kit
- 91 HF CRX ECU pinout questions
- Has anyone ran -8 an feed line in there ef from the stock fuel pump hanger
- Codes 3 and 5
- Please help me identify these parts and what their for.
- Another dpfi-mpfi problem
- Steering rack where to purchase?
- Help identifying wires on butchered harness?
- Speedometer not accurate.
- Is this a bad idea?
- Lexian with sliding
- 1991 Honda civic dx turn signals/hazards inop
- Injectors Not Firing
- 90 Ef sir rhd help!
- 91 Honda Civic Si Not Starting
- wiring up a dx please help
- 91 HF CRX wiring diagram?
- OBD0 to OBD1 jumper
- Timing belt cover
- Injector Question
- Can You Bypass the Crank Angle Sensor?
- Omni power replacement tach
- Baby steps build
- Ys1 crx.
- Fuse number 12 burns trouble shoot
- Tucked Harness
- Found a 4 door gem
- Quaife rack and pinion
- CRX from HELL
- 91 HF CRX ZC Swap Questions
- whats best place to buy OEM shocks & springs ?
- 1988 honda crx HF no CEL, replaced TPS... CEL code 7? HELP!
- seat belt question, a problem Ive never had before
- heating and idle problem
- Intermittent No Start - Finally Solved!
- Fuel cut prob
- 91 sedan
- Where to get bushings for the aftermarket shifter and linkage?
- Readings on crankshaft with b16a1 + itr camshaft + stock cam gear
- 91 hatch over heating problem, I'm stumped..
- d series engine build
- Civic Beater Bomb Build
- Honda Access Big Room Light
- Help me with engine swap!
- Hatch roof rack questions
- 88-91's Civic si motor in golf cart
- need help identify what car these plug wires are for ?
- D15B7 swap, no spark.
- Seriously Is It Worth Fixing
- Obd2 LS in ef
- Need help: Ontario etest
- Diagnosis:Aux Fuel Injector
- WTF!!! 😐I think the wiring diagrams are wrong
- Best headers for b16a CRX Si
- 1990 EF Sedan NO START NO SPARK
- Hasport mounts question
- Fuel pump doesnt prime.
- CRX Si side mirrors LHD
- civic sounds like a subbie
- Back from the dead: another all-motor EF build - 90 civic DX
- Tilt Steering Wheel Column
- PSA: EF clutch pedal failure imminent!
- 1986 Honda CRX Build.
- da9 with leaking tranny
- PS noise
- 88 EF Jdm obdo B16a swap
- What EF should I get?
- D16A9 cylinder sensor leaking
- Random Misfire and Code 9
- Hello with o2 sensor wiring
- Power seat belt not working continuous beeping
- OBD1 ZC distributor wiring
- msd 6 installation
- 89 crx 94 b18 swap
- b16 axles in std
- rotting rear bumper support
- Dpfi to mpfi swap problem
- Car won't start
- cam gear setting with ITR b18c5/6 cams in B16a
