View Full Version : Honda CRX / EF Civic (1988 - 1991)
- overheating, high idle, 1989 Civic
- help identifying missing plugs
- Radio stopped working
- obd0 to obd2a
- Coolant Temperature Gauge
- can bad Distributor tune cause idle fluctuating ? (video inside)
- ELD problems
- dash wiring, rear brakes, and body help needed for 91 civic
- backfiring on my d16a6.
- anyone ever try using rubberized spray coating on outer trim around door window ?
- any hub center caps from other models fit on crx ?
- What do you vin plate / sticker / dash look like? Canada?
- light under carpet
- Paint Removal??
- D.I.Y. Repair & Preventative maintenance for ICU module
- no start issue
- rear seat question
- 88 civic won't start
- AC low pressure side inquiry
- Easy problem just don't know how to fix EF.
- stalling on start up when warm
- What happened to our picture thread?
- Drop Springs??
- EF wont let me adjust ignition properly
- Turbo Wagon build!!!
- HKS exhaust
- 93 Transmission Into 88 CRX Mount Problem
- front end rattle @deceleration
- wiring help
- Need help with motor swap
- cable S1 transmission... Need help with inspection!!!
- Huge delay of power after switching gears.
- New Here! NEED HELP B16b swap in my 91 honda civic hatch dx
- Oem radio question
- dealer graphics and decals
- HELP! NO START CEL BUT ECU NOT FLASHING
- having issues with b20/b16 swapped crx helpppppppp
- Check Engine Light - ECU Codes 7 and 13 Simultaneously
- d16a6 block plz help
- is this TPS working good ? on idle ? video inside
- 1990 CIVIC HATCH-15X8 (+12 offset) fit? 195/45
- Simple color question
- B16 building questions
- ek side skirts
- b16 CRX swapping Hasport for Innovative mount?
- Rattle from front end @ idle
- 91 civic clock
- Source for replacement Coolant Hoses?
- I have a little miss
- Simple engine swap on 89 crx
- where are good grounding points
- overheats when idling in traffic, need help troubleshoot cause?
- 91 civic hatchback restore
- Fuel filter fuel line busted please help
- B18C5 TB will fit on a b16a1 IM ?
- Stuck accelerator 1990 Civic maual
- need help with front fenders! QUESTION
- does anyone know what i should do? plz help
- 91 crx stereo wiring problems
- Need Help On Timing (again)
- IDriveHonda's 89 CRX Revival Project
- Need help with Gauge Cluster
- Whiteline rear trailing arm bushing RTA
- 90 honda hb dx headliner questions
- Fuel tank pressure
- 89 civic dx tranny leaking
- 89 Civic - Cluster compatibility
- Ef b series mpfi conversion help
- Crx d16y7 with d16y8 wiring harness
- RTA Bushing Tool Rental
- need help from the wire gurus
- For the people who have changed oil pan on RT4WD models
- Question Regarding Suspension 88-91
- A few questions about Carbon Fiber hoods
- Gas gauge no working.
- question about oil pan gasket
- Car wont start, Something clicking
- 1988 civic sedan side moldings USDM vs UKDM ?
- Radio wiring diagram for 88 ef sedan?
- D15B7 onto Civic Ef Hatch engine swap
- Clunking noise when braking/accelerating hard or hitting bumps
- backfire A LOT lately -.-
- Upgrading injectors...
- crx wiring harness
- Rear brake upgrade, ep3 brackets/rotors but stock calipers
- buying an old CRZ.. what to look out for?
- Civic Si 5th Gear Swap
- whats the stuff used to jamb over idle adjust screw to keep from moving?
- testing the temp sending unit?
- Wiring the blinker lights jdm?
- HELP! IDENTIFYING 89 SI EF HATCH ENGINE HARNESS CONNECTORS!
- CRX Roll cage
- Fluctuating idle after 48s, HELP
- MPFI swap question
- Dash swap in 91 dx hatch
- Auto tranny crx shifter cable removal help!!!
- Main Relay Keeps Clicking Constantly
- Crystal clear JDM SIR ef8 headlight lenses
- Icu Replaced Corner Lights/Blinkers Still Wont Work Only Bumper Lights Work
- 1990 CRX Si witha k24a2 mounted
- Brake conversion
- D15B2 WITH D15Z7 3 STAGE VTEC HEAD
- 1991 Civic DX Sparkplug wrench?
- 1989 crx Bypassing the dimmer switch?
- Current Project
- JDM s1 tranny problem
- who has done mini swap and Not had ignition problems?
- stiffening the 4wd civic wagon 91 fitment questions?
- bearing clearances
- Bumpstop Size!
- zc(d16a6) re ring questions
- d16a6 to b16a
- Someone's Parting a CRX Si. What should I grab?
- Cooling fans
- Electrical Gremlins
- EX Brake and Caliper Swap
- diagnosis help
- blackwork rear toe kit
- question about a b16 swap
- Car won't start please help
- how to check Fuel Pump / pressure ?
- crx rear spoiler for track
- 91 civic dx stalling
- Koni yellow h&r race/neuspeed race
- my new old car needs help
- What is my CRX worth????
- need bolts to mount motor to stand help
- Any clues or ideas
- Hatch 88-89 vs 90-91 Seat Brackets.. -_-***********
- my TPS is reading is 0.13 Volts closed throttle
- Brake Booster advice needed
- how important is a PCV hose?
- Aftermarket Coilover Suggestion
- Change Pistons/Rods Questions
- CRX sunroof plug/delete
- 89 si hatchback rear side windows are longer then my 91 hatchbacks rear side windows?
- oil feed line
- MY ef's idle is really low
- 1990 civic stalling
- civic sedan will not run, main relay issue maybe?
- well my mini swap died on me.
- whats the best shift points for a d16y7 in a ef sedan?
- 1990 crx si rear defrost switch problems
- Wilwood Big Brake Kit - Front - Bleeding
- Tail Lights stuck on
- 87 1.6 into 87 std
- 91 civic bogging out when i rev it
- b16 ecu help
- ZC does not idle at all
- Please review my alarm diagram
- 90 si build thread
- Engine Oil dipstick
- Help! Really bad mpg!
- 1991 STD Civic Hatch Build?
- where to mount hoist
- Motor Mount Questions
- 90 Hf/Si B16A2 swap running SUPER rich!
- GSR/CRX B18C1
- '86-'89 Accord springs on EF???
- Dc Integra cluster in 90 civic si
- My 91 CRX build
- any1 with a rhd crx ef8 sir in olympia washington or near by
- 90 Civic/B20Z swap - no start troubles, HELP!!!
- OBD2 -> OBD1 -> OBD0 Distributor Wire Mapping
- 91 dx major issues help please!!!
- Rev hang..?
- Need help with intake manifold
- 89 civic no start
- Looking for a definitive answer on something. Please help.
- Finding rear window locks
- D16Y8 Head from 2000 Civic Si -> D16Y7 Dizzy
- just bought 1987 CRX Si - have a few noob questions
- brand new clutch kit no engaging
- trunk gasket
- Will civic hatchback seats fit in crx?
- 89 Civic Hatch bumper cover clarification
- Looking for a list of bushings needed for front end.
- 90-91 dx shock tower pinout, searched, can't find
- Crx 1990 died while driving
- traction bar question
- Click/Clank noise in reverse?
- Power Locks / Keyless Entry. How hard? Quality kits?
- 91 Civic Si Stalling and Running Issue
- 88 hatchback dies suddenly
- 89 1.5 ECU blinks continuously
- what is that air intake vent thing they have on CRX's in the UK ?
- how come all the clear corners look weird?, can't find good ones?
- what maintenance do you need to do for the clutch & transmission?
- D16a6 has no power when warm
- Sputtering, give it gas and it just sputters and the tach bounces rapidly. HELP!
- crx custom rearseats ?
- Running rich and getting nowhere.
- DC2 springs on an EF8/9???
- Cel code 5 help?... please
- Whats the best cable trans for a crx d-series
- What is this called?
- 89 civic DX hatch ECU
- diagnosing oil
- Hasport b18a1 wiring harness?
- Cleaning the FITV messed my idle up
- rpm dependant metal rubbing sound
- Can you swap in motor with axle shafts in hubs??
- D15B2 Rebuild Question..
- oil in spark plugs?
- Transmission issues
- Crx ls vtec dyno
- Shuttle D13b Cam
- 89 Dx-Ef hatch climate control removal
- 89 Dx-Ef hatch cluster removal
- Ignition Switch Trouble
- Idling issues
- Interior lighting questions..
- b18a1 No Start Issue
- Wagon specific repair metal?
- T bracket noobie help
- Driver's side seatbelt won't retract
- Weird electrical behavior
- 90 Crx 1.5 to 1.6 fuel pressure problems!
- 91 crx si with gsr swap turbo manifold issues
- D16 SOHC to VTEC?
- 89 Civic HB, Replaced almost everything, still having idle problems.
- Honda crx wanted for trade
- NEED HELP D16Z6 into 91 CRX Si WONT START
- 1990 civic lx timing
- Got a itch 90 Civic build
- 90" crx build with pix!
- B18b1 89 Si CEL 43 huge loss in performance
- ECT/TW sensor wiring.
- almost mpfi ready
- b18ls manifold problems
- why does my speedometer moves slow on the gauge while accelerating?
- what is this thing on the window for ?
- TPS voltage issue.
- 89 wagon b18 swap questions
- How to change auto transmission fluid
- Transmission/CEL problem. HELP.
- 90 Civic/D16Z6 swap - Cylinder 4 problem
- Transmission Question/Opinion
- 91 crx hf driver side shock tower
- Need Help/Advice on fixing this!
- My DOHC ZC woes :(
- 90 CRX swap !!!
- coolant leak along top of radiator, how do i find out if i need new radiator or not?
- Alarm and power lock input needed
- left rear brake will not bleed. Air no matter what I do!
- Help with CRX (Y1 trans, SH3 intermediate shaft, B18A1)
- Does obd0 dizzy work with obd1 ecu??
- Is it a fuse?!
- How To: Stop gauge cluster/shroud rattles
- HB with b18 bogging/backfire problem while cruising *VIDEO*
