View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Custom Rear Seats
- jdm obd-0 distributor, which cap & rotor?
- Can a stock crx (obd0) map sensor with with an obd1 b16 swap?
- [FAQ] How-To: Installing Password:JDM front lip onto USDM 90-91 CRX
- Trailing Arm Bushing Replacement
- ls crx throttle body question
- Surging Idle problem
- spoiler?
- 96 z6 swap
- mini me build ?
- 90 std. civic hatch
- Grinding/Scraping Noise when Driving/Turning/ Low RPMs WTF IS WRONG WITH THIS CAR!!
- Evap Delete
- B16 Users: What header are you using?
- dizzy question
- dumb question
- zc question
- obd0 to obd1 conversion questions?
- skunk 2
- will 90-91 crx glass fit in a 89?
- Soft Gring/ Pulsing Noise from front end - WTF could it be?
- speed sensor
- Honda CRX/Civic online manual.......
- tranny question
- 91 si / 91 ls
- Is it suppose to be like this? b16 to dx rex
- integra console install in 91 hatch
- 91 crx si
- another turbo question
- Main relay question... possible problems?
- Bad tranny bearing?
- taillight problem!! please help cant drive at night..
- broken engine mounts = new si
- oil pan bolt sequence
- signs of having bent valves?
- BUYING ENGINE,NEED HELP ON DECISION!!!!!!!!!!!
- phantom grip lsd question
- # of splines on dx tranny
- Anyone ever use a traction bar kit and not use the front mount?
- Electrical problem, please help
- Si tranny and hubs?
- rear main seal removal
- Lighting problem!! Need light to work for inspection
- 88 Fender Trim (is there another civic that matches?)
- insuring the bucket
- D15 SOHC Block with D16 SOHC Head? Does it work?
- skunk2 cam gear problem
- Camber issues.
- Weight of bare block
- 90-91 CRX SiR seats into 89 CRX Si?
- My 3 day CRX buildup (quickie)
- B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@
- 89 headlights fit 90 crx???
- Harness Question???
- does there sound something wrong about this ??????
- DOHC ZC knocking???????
- gauge cluster stoped working
- radiator fan won't work, what could be the problem?
- Name these parts.
- need to smoothen idle
- 84 crx
- CRX Radiator Support
- MPFI conversion help
- My CRX build... kinda
- CRX engine swap
- seat pan question
- Brakes 91 CRX SI
- hydro tranny in ef?
- all ef consoles the same?
- HOW FAST ARE THESE THINGS?
- give opinions
- EF9 gauge cluster plugs
- Making a 92+ fuel pump fit a 90?
- question
- Yes or no?
- b series ITB'S
- d16z6 rebuild and trans questions
- who would win? b18A1 or B16a1
- Problem with brake and reverse wiring after swap...
- can I use my dx to obd1 vtec d16 rywire harness later on if I go obd1 b-series?
- Omni power coilovers (sleeve type) Weird vibration?
- why does my y1 not have a lsd stamp on it
- where can i get NEW windshield molding at???
- I need help quick, in middle of swap
- 91 CRX Si with ZC swap, what A/C compressor do I use?
- will 89 crx rear bumper fit 90 crx rear bumper
- which pin is the a/c clutch relay for a pm6 ecu?
- More MPFi swap problems woohoo
- To turbo or not to turbo that is the question!!!!
- battery tie down
- Help Crx problem with TPS!!!!!!!!!!!!
- 86 crx si help
- dx dizzy in an Si
- crx jdm side markers template needed
- angled exhaust. why? reason?
- PCV Valve - OEM or Pep Boys?
- need help with a engine swap!!!!
- e-brake handle removing
- burning oil and emissions test
- turbo questions
- whistling noise
- the weight of ZC DOHC
- Should I?
- where to mount poppers for shaved door handle???
- Popping coming from intake??
- RHD EF8, rear Xmember ok for sohc???
- Homer is alive!! ALIVE I TELL YOU!
- are taillights 88/89 or 90/91..?
- head gasket install..
- p28 or p72 on turbo b16
- EF biography-learn about my car
- catch 22
- more power
- What should I replace
- Throttle problems
- si cluster in DX
- need help with interior
- ef horn, how does it complete the circuit?
- what rear seats will fit
- heater question
- da struts work on ef hatch?
- lights problem
- i hate rear drums
- b18 vs b20
- DRAG Tire size? What size should I get?
- coolant hoses feel empty
- timing belt tension
- Fuel pump related to the battery light?
- low fuel light in a sir cluster
- What clutch to use for my setup?
- bumper
- what kind of tranny is the l3 tranny si,dx,ex etc.
- motor clearance
- Just got a Moroso oil pan, now questions about clearance!!!
- carbon fiber lip?
- Suspension suggestions...help me out
- coilover installation problem
- NEED HELP FAST!!!!!!!!!!!!!!
- weight of a stock CRX hatch, not the car the hatch itself
- B18c1 in my EF hatch...Honest Opinions
- Found my oil leak, pictures inside.
- How far can you safely hsave a head on a D16A6, head is in shop, NEED TO KNOW!!!!!!!!!!!!!!!!
- b16a2 Question ?
- any1 know where the switch/relay for cooling fan is?
- Fuel Pump
- Fmu
- water temp guage
- Are a/c condensors interchangeable from other yeah civics or hondas for that matter?
- WHICH PART DO I GET FROM DIAGRAM LINK
- O2 sensor issue
- CRX fenders new...where?
- 87 civic hood on 89? Will it fit
- HELP!!
- cant find thread
- H22 into a Ef9 hatch
- How much do i remove on the 90-93 shifter?
- Supercharger??
- crx trim door handle cups
- questions.... ls into 90 crx si
- short shifter
- P&P
- b18 into 1987 CRX
- Crank Pulley for B16a?!?!?!?
- Bad alternator causing a loss of brakes?
- Will a eg tranny fit my 91 si?
- Which ACTUAL T-BAR WORKS FOR SIR FRONT END?
- crx headlight collar removal
- 2 crx's..help please
- d16a6 vtec head swap
- CRX Gas mileage options?
- Why your car is blowing blue/black/white smoke
- CRX buying advice...input and thoughts are appreciated.
- plug for the back window
- D16A6 carnage (not for the weak stomach)
- I HATE THIEVES!!!!
- cable to hydro
- ebay coilovers with stock shocks
- new motor...HELP
- 1st gen b16a smoking need help
- JGE valvetrain? Any good for the money.
- WHat could cause blue smoke???
- CRX Headlights Interchangability?
- New car, ideas, opinions.
- what would my car be worth???
- B16 preswap checklist
- does anyone have bight corner light
- manual rear bracket from tranny to rear mount different than auto?
- please help!!! b16 studders!!! anybody??
- bumper lenses on at all time
- e-bay coil over. any good?
- CRX b18c1...head assembly help please, easy one!
- NSX brakes on Crx
- Red Line oils...
- temp guage sensoor wires
- i think i have a wiring problem
- xenocron USB Datalogging Kit?????
- engine xsi or sir-2
- B16 A2/ Help Wanted
- my 87 project PART 2 since my other one was locked
- need help
- good buy or bad buy???
- 2nd gear grinds but other gear is fine
- Firewall plug pinout for OBD0->OBD1
- HF 5th gear
- Gsr Knuckles
- how to install a odb 1 dizzy on a b16 odbo motor
- CRX carpet weight?
- wiring-88 crx si d16 into 89 crx HELP
- how to install oil temp gauge..
- difference in piping between 88-91 crx and 88-91 hatch? whatsi s the difference?
- help on picking a swap
- After car sits for a few hours engine won't start right up
- Just got my first EF Hatchback!!!!!!!
- mini me vtec wiring i need help
- b18a mounts
- My engine is broken :(
- Getting the Hf past 5500/6000rpm
- Wheel bearings
- CRX armrest price?
- Pr4 ecu codes.....7, 16, 43....please Help??
- crx trunk hatch broke
- b18b motor sawp
- pm6 ecu code 9?
- yup, another tire size question
- header blue print
- carbon fiber lip on 4 door sedan
- runnig 4 door for 200...what a steal
- yes fould another hatch
- help
- expletive my front LCA
- would a 91 civic windshiled fit an 89 crx?
- ? about rear drums on a '90 crx
- Need help w/ front end, Sedan or Hatch??
- fiberglass frontend? lexan windows?
- lowered civics...
- Trust muffler, opinions?
- want more power
- help
- Ef and crx bumbers
- CRX HF brake upgrade?
- Anybody know where I can get a Qualfie close ratio rack?
- odd sound from steering rack?
- APEXi world sport exhaust
- power doors
- HELP TPS sensor for 1989 Civic DX Hatchback
- crx bogging below 2k rpms
- clock went out?
- advice for changing 1st gen b16a ditributor/rotor/cap
- DIZZY HELP PLZZZ
- auto to manual swap done - low redline? ecu??
