View Full Version : Honda CRX / EF Civic (1988 - 1991)
- My baby was stolen today........
- Help....Idling Problmes!?!?
- Accord shocks lower the car more with springs or just coilovers?
- HELP with LS/Vtec swap in a 90 STD
- everything needed for b16
- Can you short a starter?
- DX tranny swap into a STD
- WTB: 88-91 DX 5-speed tranny
- Need your stock seats!!!!!!!!
- fs: 6 pc. mugan body kit for 88-91 honda crx asking $500.
- TEINS or Tokico Iluminas/Skunk2 Coils??
- when u got ur b16 in ur 90hb did they say....
- Z# Fenders
- Is it possible?
- A/C Question
- 4.7 4.9 gear ratios....does anybody have either of these?
- rod question
- i know you guys hate these questions but...
- do b16 come with dual valve springs stock?
- CRX wouldnt start-- Looked in gas tank its rusty as hell.. help me
- What kind of oil to use in ZC DOHC?
- How low have you gone with 205-50-15's I would like to see shots perferably a hatch?
- rear disc swap
- brand new to the scene
- Anyone got good pics of a JDM Civic Si-R? Its for a good cause...
- n1 w/no cat
- Shifter Noise
- Reading Computer Codes
- engine question
- how the hell do you remove the oil control yet?
- nut/ball joint problem!!!!!!!!!!!!!
- nitrous bottle mount
- Changing engine mount
- exhaust question
- altinator help, please.
- Supercharger Specifics
- Is this worth doing??
- Does anyone else have this problem with there shifter?
- let see some gauge locations!
- good brake pads?
- No brakes
- HELP... What tranny should I use or what can I use ???
- need help
- need help
- sugar in the tank!!
- 92vx disc brake conversion
- Hondata???
- computer fried??
- parting her out
- with a compresion of 9.6:1 what octane gas should be used??
- Is this CRX worth it?
- 98 Alternator in an 89 Civic?
- D15B JDM? this one's weird
- ecu code 2?
- H22A to heavy for CRX?
- Drum brake help
- Brake Shims? Do you need them?
- Those with MSD ignition please help......
- Sleeves or no sleeves?
- Brake light won't shut OFF?
- redline specs for a 90 crx si motor
- anyone ever put a crx dash in a civic hatch
- grinding 3rd gear....
- radiator hoses for a b18b
- Can i use the 90 HB Si Radiator for a b16a in the EF9
- any crx's with itb? i did a search.. wanted to see some pix if possible
- Need Help!!!!!!!!!!!!!
- wings west front bumper opening size?
- Said Goodbye To A Good Friend Today
- ITR manny on ZC
- WTB: 86-91 civic/crx stock ecu......Dig em out of the closet...
- The truth about bodykits.
- drag radials bf goodri....
- JDM transmission disassembly & reassembly - torque specs
- Gas pedal freeplay
- exedy clutches good, bad let me know
- what can i replace the drum breaks with disc?
- Custom Door Panels
- b-series hood clearance
- PLEASE HELP!! Bogging from takeoff
- I cant pop my hood cause the latch is broken
- Around what rpm's do you guys release the clutch at ?
- headbolts
- opinions (problems?) on B20A5 swap into 89 SI
- How tight should Rocker arm be when adjusting valve???
- doesnt like to cold start ?
- B16-EF Vibration problems, any ideas?
- after the mpfi swap
- b16 crx apex exhaust 2.25 piping and stock cat ...
- EF sedan front on EF hatch?
- looking for 88-91 crx si
- Need help on what motor mounts are good? HELP
- obd1 D15b2?
- Need some help with my axle boots
- technical difficulties tonight
- looking for tranny help !
- URGENT...Need help quickly in price of car
- ecu ?
- for all the turbo homies!!
- b18b is in......waiting for parts......
- sir header wont match up w/ exhaust?
- wtb aftermarket radiator
- Dumb Q: How do you compress the spring when you reattach b-pipe to cat?
- Where does this electrical connector piece go?
- Such a Newb Question....
- Power steering on 89 CRX Si
- crx will start some times, and will not other times, please help!!!
- Pics of my car...
- JDM HONDA CR-X CHORO-Q PENNY RACER
- vtec not engaging
- will the del dol short ram fit a crx with b16?
- about how much would it cost to title an imported car from japan?
- Hi
- hx wheels
- looking for info on 90-91 SiR rims
- How to mount EG seats
- 94gsr and up fuel injectors for a b16a?
- would this turbo manifold fit??
- Help with Neon radiator...
- this poll is to see what a crx can run in the 1/4 mile
- CRX hf with B16A1 wants to get a ref sticker?
- value of my car?? im taking offers btw..
- sell my eg and go back my crx
- PR3 plug ins for b16a crx
- when i turn on my head lights, my cars idle drops at least 300 rpm's
- who we got from pittsburgh area?
- spoon/ vision mirrors
- one year and $2000 later.....
- Hatch VS CRX taillights, diferences?????
- Good High Speed Windshield Wipers?
- which springs for crx?
- Which wires to crank angle sensor after MPFI??
- a few parts fell off and now i need em
- help t25 zc not boosting
- If you don't have a 4wd wagon, you need one!!
- shifter problem
- Anyone live in LONG BEACH, CA i need your help!!!!
- can some one run a vin please.. !
- Can u identify this?? and tell me what is it
- Adjustable cam gears.... degrees..... how much is half a tooth
- Semi-Official: EF 4 Door Carbon Fiber Hood... interested?
- how is shipping calculated??
- Drilling stock rotors
- c/f rear spoiler for the ef anyone interested?
- For all those people that need exhaust!
- JDM D15B VTEC
- 9006 HIDs fitting onto 9005 projectors? Anyone do that?
- 92 civic dx shocks&springs on CRX?
- cd player intall for a 89 civic.... anyone wanna try and help me out?? for a friend
- CRX Si Seats take apart
- swapping a 92 dx motor...can I use that ECU?
- After Adjusting Valves still makes a lot of noise.
- bumper lips for '89 crx si
- jdm ef eye candy... {lots 'o pics}
- 92-95 cai fit a crx with the batt relocated??
- What holds the Door Locks tight to the Handles?
- Is there a CF hood for the 4 door yet?
- 160 compression test is that bad?
- anyone do motor swaps in phoenix?
- Rattle over bumps from front shock
- where could i find a rear hach seal for 91 civic si hb
- Throw out bearing making grinding noise
- 96' civic ex BONE STOCK!!! any ideas??
- SPARK RACING MOUNTS
- difficutly rating: B16A1 into 91 civic hatch
- 95 SOHC Vtec fitment?
- projector headlights for 91 civic?
- what do you think of this DIGITAL display meter?
- Crx rear clunk?
- intake help
- 00 civic si injectors
- ZC Camgears timing help asap
- Mileage & PCV
- CRX B16 Intake Help
- anyone have pics of the JDM ZC DOHC Civic/CRX door graphic(s)?
- Anybody tried or heard of Helix Power Towers?
- If I were to go to Japan.......
- damages caused by driving overheated engine for 20 miles?
- ZC ideas what should i do?
- 1 peice headlight?
- 1991 Civic si hb or a 1992 civic cx ? for a swap street racer.
- what is the width of crx springs?
- dude i hate my car (sometimes, like now)
- WOW~ fuel pump, relay, starting, what is it!
- bad performance below 1/2 tank?
- oil pan fitment??
- 2nd gear pops out..
- 1st 1/4 run with B18A1... 15.524@88.04mph
- bad idle
- inspection question
- 85 Honda Civic DX
- release spring in tranny broke
- place racing cross member?
- gauge painting question
- Shift fork removal (L3)
- B16A Lost motion controls...
- 88 CRX DX wont start - posting for friend
- I need HELP!! PLLLease In need of B16 cable tranny or should i just rebuild 3rd gear synchros
- hmmm
- ODD BALL 88 CRX
- 91 DX won't start HELP
- Once again I am a victim of theft!
- stregthening
- few questions please read ! and thanks if ya help :)
- crx swaping
- Yea, so I'm a n00b...
- Radiator?
- Can I use Eagle LS rods in a D16
- 1984 crx problem...humming at speed above 25mph.
- civic/crx motor difference?
- Changing out oil pump on d16a6?
- Carb Legal Intakes.. for smog in CA
- You know what, because the question is hard...if anyone can at least say it has happened to them...
- transmissons
- CRX back seats
- My website is finally up
- 88-89 CRX's with WW Kit please respond
- bad miss/stutter at 3100rpm?
- quietist exhaust for ef?
- my car
- carburated civic engine?
- Honda slang...
- no intake?
- Invidia / RS*R Exhaust Group Buy
- where'd you get your WW for CRX?
- What is a good 60 ft with a B16......
- susp ques
- crx swap overheating probs
- budget motor comparison...
- who posted the jdm crx/civic sales brochure,
- B16 won't hold idle, keeps stalling
- People with aftermarket oil gauges, please read.
- QUESTION: Turn Signal/Wiper Arm Loose
- Should I get this moter ?????????
- ebay cat's?
- Engine coolant sensor
- Y1 LSD in hydro tranny?
- clicking coming from rear on hard turns
- Rear shocks for 4wd wagon??
- radiator cap
- Need h-t's opinion
- crackshaft pulleys?
- How do I adjust my HCP linkage?
- is there any trick ways to pass the sniffer test?
- Crx hf fan different from dx? (radiator)
- braking noise while backing up?
- D16z6 obd-0 to obd 1 problem into a 1990 crxsi
- 91 civic SI brake upgrades.
- need gauge help
- 88-89 and 90-91 civic corners have the same shape?
