89 Civic si steering wheel removal
Old Aug 31, 2015 | 12:35 PM
89civichb20b's Avatar
Default 89 Civic si steering wheel removal
I am replacing the steering wheel on my 89 civic and need some help taking the original off. I saw some guys only have to remove the H from the steering wheel but this one is different then the CRX. Has anyone out there come across this replacement?
Old Aug 31, 2015 | 01:20 PM
cjwang2's Avatar
Default Re: 89 Civic si steering wheel removal
It is quite easy. Take the H emblem out from the middle of the steering wheel with a small flat head screw driver. Then get a 19 mm Socket with an extension and remove the nut holding the steering wheel in place. It may take some muscle to remove the nut, but it shouldn't be too hard to remove. Once the nut is out, pull the steering wheel out towards you to remove completely.
I have removed stock steering wheels out of CRX's, Hatchbacks, sedans and wagons, 88-91, and they all come out the same way.
Old Aug 31, 2015 | 01:23 PM
I will try that, i didnt think it was the same because the H on my steering wheel does not seem the same as the CRX, it looks like a simple emblem on it.
Old Aug 31, 2015 | 02:10 PM
whited's Avatar
CRX God
Nop, it should be removable.
Old Aug 31, 2015 | 02:13 PM
whited's Avatar
CRX God
Do not try to remove part #5 from the steering wheel. You will just break it.
Old Aug 31, 2015 | 02:55 PM
Tyson's Avatar
OP is gonna smack himself in the head when he figures it out...
Old Aug 31, 2015 | 10:16 PM
Nice!! thanks a lot peeps!! i will be doing this on my days off!
Old Sep 6, 2015 | 10:18 PM
Holly cow!!! i did wanted to smack myself after how easy it was to replace it!! thanks a lot peeps!!
Old Sep 13, 2015 | 11:11 AM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
One little piece of advice someone gave me. Loosen the nut several turns but don't remove it. Then you can pull as hard as you need to on the steering wheel and it won't hit you in the face. Then when the steering wheel comes loose remove the nut.
cheveoppolis
Jul 29, 2011 07:04 AM
dustin_crxsi
Oct 30, 2006 05:29 PM
b18_crx
Jun 19, 2006 09:19 AM
b16acrxer
10
Dec 2, 2003 06:28 PM
kikkoboyie
Sep 15, 2002 02:55 AM
