View Full Version : Honda CRX / EF Civic (1988 - 1991)
- engine swap, which to choose?
- How Do stock Si front lips bolt up? Screws? Clips? Come inside...
- 1990 ZC CRX!!!! What axles do i use???? Please help
- What are the differencees beween wiring harnesses 88-91 Si?
- code 14 iac, oil in gas, vacuum lines
- SWAPPING B16A1 IN 89 CRX SI
- my sucky brake system...
- fuel pump
- Need Help asap
- Safety Issues
- install sender with no droping tank
- CRX door panels
- FUSE BOX
- Build the LS or buy a b16?
- parting out 88 civic.
- EF cluster pinout ?
- CODE 13... need help please???
- cv axle broke now replaced wont start
- Code #9?
- I need advice on selling a, 88 CRXSi
- help!!!!!!!oil leak
- 88 Koni yellow rears
- will 88-89 HB window regulators fit 90 Si HB?
- Brake adjustment question
- Which transmission should i go with?
- Carbon Fiber sunroof for CRX
- Max Negative camber on Stock Suspension?
- YET ANOTHER MPFI QUESTION
- Fog Lights on
- add a peice of honda history to the family?
- UDKM Taillight Questions
- just some old memories of my first car wrecked by the tow truck
- GOIN LS!!!!!!!!!!!!!!!!!!!!
- is a 91 sedan a good car?
- 87 crx si b16 engine swap can it be done
- All Motor......
- I need an oem CRX armrest..........
- Who know about turbo on D16Z5?
- Best header 4 the B16A1 (need help)
- i was so close to finishing her....please help :(
- need help so i can race this weekend!
- 91 Hatch w/ B16 and AC-what belt for AC-tried a search!!!
- Anyone have a Kaaz LSD
- Fuel Pump, how in the fuck ????
- I'm such a ricer...
- Bought New Drums for the 88, but they wont go on
- Which throttle cable?
- zex wet kit
- eclipse turbo on my rex
- Low Idle? Oxygen Sensor? ECU?
- crx just swapped a b16a haveing some problems need some answers or ideas
- wtb:integra console with arm rest and cup holders and mods for some reason they wont allow me post
- STRANGE homemade turbo question someone HELP
- Civic n00b question
- Rear engine mount bolt went bye bye "again"
- lazy
- Whata i got
- Gas tank hisses
- Location of the ignition switch?
- what do you look for when you see crx's @ a show or on the street?
- engine won't start, please help
- LOOKING- Wiring Harness for CRX
- Question about putting an Si tranny onto d15b2
- engine will not fire just replaced the timeing belt
- help give me some idea to cover this gap..
- obd1 question
- Need help with before and after Tein S-Tech spring drops on a CR-X!!!
- A little help?
- Battery question
- Dropzone Springs?? Help !!
- HF ECU with D16A6
- need picture of stock crx SI rear
- flush mount wing. not edm.
- about engine
- Has anyone else ever heard of this? A6 motor running off a LS ECU???
- exhaust piping under the gas tank
- I NEED HELP!! 3 Cyl., very rough idling,
- crx types
- Oil change
- CRX WIRING
- fuel injector seals
- My Idle Catastrophy Story. Pics. Info. Detailed
- Distributor not firing on z6
- Fuel pressure
- CRX Hatch Help
- JDM Front end?
- What engine swaps can i find at the junkyard?
- Rusty CRX Arches
- JDM integra front end on my CRX?
- how hard is to install rear seta for crx
- H&R race springs and Tokico Illumina adjustable shocks for 88 CRX SO CAL
- Oil Pressure gauge
- axle seal help please????
- Raising the Hood?!?!?!?
- 5 spd swap
- Guage Cluster wiring
- Progress camber kit and omnipower coilovers - what ride height for -1.5 degrees
- crx dx won't star need help , you might have the answer
- knock sensor
- Does/will Tokico make coilovers for our EF's?
- Can i Get Some Tips
- Trying to get this jdm EF9 front end to fit on my 89 STD hatch , HELP PLZ !
- Another question with a wiring harness for a 90 crx hf
- Crx hf swap BEWARE...oOoOOOOooO
- very cheap zc interstate BEAST!
- Front Lip WHoot WHoot...anyone even like this?
- Will a faulty combination switch cause the following things?
- Shifter
- ZC Tranny Q's
- have a FIELDS VTEC CONTROLLER wats the stock settings for a z6 motor
- dx hub question
- Looking for a FRONT LIP..CHECK it OUT
- Removing heater core
- New brakes and now it shakes!
- 90 hb with 95 gsr swap would EFB1 hasport mounts work??
- Think anyone would be interested
- 90 Integra front camber kit work on my 89 Hatch?
- civic with a tail
- b18c5/ b16 comp ratio????
- Sunroof fix
- Need pics of primer flat camo green CRX
- Starting without oxygen sensor?
- Should I buy this CRX?
- b16a1 distributor?
- Main Relay
- GSR TURBO which tranny is better Gsr or Ls
- noise from engine Help please
- B16/ef cai
- Anyone swap a 88-89 EX or LX gauge cluster into a 88-89 4 door DX?
- Smog Cat
- A/C compressor pulley loose??
- SEARCHED Hasport mounts with Hydro tranny coversion
- Most Annoying Problem
- newbie question--- Identify this Honda motor
- Is an electronic VSS possible on 91 civic?
- Airconditioning problem.help please!
- did the d16a6 come in a 4door car as well as in the crx si?
- Shipping motor
- Electrical Guru's. Zc swap done, get car running, turn off, dead. HELP ASAP WORK
- Maintenance schedule
- Y8 manifold - pics/details please!
- I need help with my starter
- want to buy 2nd gen crx or 88 hatchy SoCaL
- anyone with 15x7 20-28 offset?
- my "new" EF *update*
- Where can i buy a right side UCA/ball joint??
- Mini Me OverHeats at high RPM's
- Ahem... Rust Repair. RIPPED OFF!!
- Need A good swap for cheap price!!
- WOW! blasphemy....Civic truck?
- Motor Swaps- stock 1990 Crx to 1995 Civic D15b Vtech
- Si cluster in 4 door dx?
- 88 CRX Exhaust Help
- CRX DF H22A/ TURBO FULL - RACE KIT
- SAFC II Problems on D16a6 with PM6
- Wiring complications
- God i hate working on cars..
- 91 honda civic si w/ blown D16A6 motor
- b18c1 wiring into 90 Si HB
- Gameboy advance becomes a diagnostic tool?
- which harness for swap?
- FAQ B series torque specs
- Hmm go on me with this
- ground control spring rate!!! help!~!!!
- Difference between hf/si and dx?
- Hesitation Problem: 88 CRX Si w/B16
- FAQ My swap parts list for B18C with S2 IM into 91 CRX DX
- What kind of mods would it take for a d16z6 into an EF Civic?
- Cable clutch feel
- D16z6 Throttle body on D16a6 intake manifold?
- Lower control arms
- Question
- Del Sol Coilovers and Shocks Fitment
- mugen mr5 silver los angeles
- ef half size rad
- clutch cable help?!?!?
- Pic reequest Place racing x-member
- shift linkage ?
- xsi swap questions - - - please help
- B18C VTEC engagement question
- anyone have a dynomax exaust parts?
- I need new spark plug wires. What do you recommend?
- 15/16 or 13/16 for rear disc
- can i use an SI engine and dash harness?
- got some questions, just replaced my head gasket
- help me with my motor.
- LOoking for diagrams 85-87 crx
- everythihng back together.....wont fire
- d15 wont start. wiring problem?
- Wiring sub harness, 90 hatch si, swapping jdm d15b
- ONE Wiper Broken '86 Civic
- speedo cable???
- Brake Master Cylinder Rebuild
- running rich, very rich
- Wanted - 1990 Honda Civic Factory Service Manual
- throtle cable
- Help and ?
- Someone Please Read And Reply, Pleasse...
- Starts but dies after replacing throttle body
- Alt problems or?!!
- Full Race crossmember VS Jimfab.
- OMNIPOWER coilovers?
- i have a problem
- Roof Panel
- very strange electrical problems
- Anyone with JDM front end
- Proud new CRX Si owner! Very productive weekend!
- 91 motor swap
- koni yellows, trying to torque the top two bolts
- A-Tech™ "FinalSpeed" or "R-Sport" wheels on a CRX??anybody??
- How can you make the A/C Clutch engage?
- stock (steel) 15" rims?
- Headlight Cleaning
- SOHC head gasket on ZC?
- putting in springs
- Click and view please.
- Linkage troubles...?
- 8500 Rev limit safe on stock b16 head?
- 90-93 Integra steering wheel...how are the ergonomics in an EF?
- Buget Suspension Review
- bolting tranny to motor...
- CRX swapping a XSi
- Estimated Quarter Mile Times for my Car. Any Ideas???????????????
- 91 si clutch with 93-95 single vtec jdm motor 1.5 can i use that flywheel
- Gonna be going with a firewall MAP and B18a TB, question on coolant lines
- Which engine fits in 91 hb
- Can a nooB like me do a B18C swap in 3 days?
- h22 crx > radiator ?
- need help on b16a sirII in crx timing,???????????????
- Passing smog with a motor swap?
- B16A into CRX 91 Si bogging issues
- Engine Stand?
- fuel pump noise
- Ls motor into 89 Civic Hatchback dx
- Not tech related, but i know u wouldnt wanna miss this!
- if you drive crazy as f%$# on the freeway help me out
- MC (Master Cylinder) Swap ?
- ZC 1.6 SOHC vtec or ZC DOHC...which would you choose?
- CRX Parts Needed
- 91 tranny and 89 clutch problem
- can a 89 si clutch work with a 91 tranny or not the same
- head gasket problem........I'm stumped
- ignition problems
- questions about stock deck
- I need help with my radio!!!
- CRX DX+Z6+p28+jumper harness+si harness, help.
- odb 1 conversion the hard way
- quick timing belt question..
- 94+ Integra LS Arm Rest/E-Brake Console Question... I searched!
- new axles... wont turn!
