View Full Version : Honda CRX / EF Civic (1988 - 1991)
- d16y7 installation need help
- cooling question
- Installing A/C into a Crx that... didn't come with A/C...
- bumper lip...???
- b18a1 torque specs
- DOHC ZC Help...Engine Bogs When I press On The Throttle
- b16 headgasket kit
- seatbelt problem for 90-91 civic
- 89 crx si Clutch Safety Switch
- Stalling Question. Please HELP
- New SiR track project.
- t-belt cover
- HELP!!!! dash lights come on when brake pedal is pressed
- rod bearing interchangeability?
- UK D15B Dual carbs
- Decal Stickers...
- Need some input. 90 Civic Ex convert to 5spd HF?
- ~*~Targa Top CRX project build
- ?? what motor??
- Spoilers
- B16A1, compression question.
- Whining sound from engine bay
- depin plugs for ecu at b and c. Please look!
- cleaned the b18 block today...bored?
- No spark, help asap
- Found an EF, need your thoughts...
- military green ef
- ep3 seats
- 90 teg PASS. Axle wont fit in hub. Correct splines!
- ed/ef rear bumper lips??
- OBD-1 dizzy wont fit???
- b16a running ritch..
- Distributor question
- good price for a catalyic converter?
- DA brakes on an EF questions
- Picure request: 90-91 Civic w/ Color Matched EF9 Side Skirts
- axle swap question
- My CRX 89 HF with 94 LS B18B1
- Kevin's General Maintenance on the almost 20 year Grease Monkey Crx
- hks sport exhaust
- any Honda meets in IL?
- OBD1 - OBD0 Gauge Cluster Pinout
- hello everybody!
- b18a swap throttle cable
- no fuel pressure
- Will a integra Fluidyne Radiator fit??
- b series question
- Intermediate shaft replacement seals?
- Sluggish low end power...
- Obd0-obd1
- obd?
- 4wire 02 in crx im stumped
- b20 swap to civic
- how do i make a d15 any faster, maybe 100hp?!?
- da integra seats in a ef
- Thinking of buying a EF got some questions...
- obd0 to obd1 but keeping d16a6
- 1990 Civic Dx D15 Vtec Alot of Issues
- What did you do to your CRX today?......if they [EFers] can do it, then we can too!
- DX rack and pinion in Si?
- ef sidemarker question (searched)
- will an 91 si intake manny fit a y8 block?
- is anyone running a f1spec seat?
- Hytech Header on a ls/vtec in CRX Chassis
- Exhaust question????
- Need help with ecu/wiring
- Starting Problem [newb]
- GSR Calipers/Rotors on CRX SI hubs?
- Help!!!! Help!!!! Help!!!!
- Brakes, Power Steering, AC
- good garages in souther cali???
- Exhaust question at rear axel
- 89 crx 4 wheel disc???
- oil covered my spark plugs?
- Help...Im New
- Help w/ Failed Smog Test
- 92-00 Walbro Fuel Pump Kit fit in my 88???
- double din
- Brake upgrades for turbo set-up?
- how did u guys mount ur traction bars?
- Ls/ vtec or D16a6 turbo?
- How to change a shift knob in ur hatchback??
- Is this a good deal a k20 and tranny?? 4 1200
- what is this?! help plz!!
- Canadian and USDM EF Wire Harnesses interchangeable?
- missing piece...
- MPFI swap: wires into ecu.
- help with front lca on a 90 EX 4dr
- vaccum leaks?
- awd ef 4dr
- Greets from Germany!
- B series rear tranny T bracket question, will auto work?
- jdm d15b question
- D16A6 head on D15b2
- ZC Intake?
- Steering wheel issue
- b16a obd0 swap question into ef
- Aftermarket seats in an 89 CRX DX
- Anyone know this Clean CRX, white in So. Cali?
- Question about my ef plz help
- EF Drifts in The Rain BAD
- Wall Street virtual stock trade game
- Need some help with an 91 civic hatch
- EF shooting flames...yes it can be done
- b swap with a/c
- need help/advice on swapping engine please!!!
- dropping a sohc in my ef si shell HELP
- CRX/Civic Radiator support
- front knuckles
- 90 sedan corner lights?
- so still after searching for a catback can't decide
- rywire obd0 to obd1 harness question
- Noob idle question
- My first motor swap
- Any Auto-X or road racers using Function Form F2?
- headlight housing???
- Clutch Help
- what should i do now?
- confusing kinds of weatherstrips
- d16z6 questions
- Won't rev
- Help? b18 curiousities
- front end
- need some seat help
- NOS on my 90 D16 hatch
- ef w/ ls acceleration problem!! HELP PLEASE!!!!
- 89 civic very hard starter
- pump turns on but no start
- Water leaking into car?
- Titleless CRX
- Seriously, what's up with the hood latches on these cars?
- Edm vs jdm!
- EF Civic Headlight Alighment
- CRX Gauge cluster light issues
- diy stock traction bar idea
- remove paint?
- work or car?
- b-series cable tranny guru's ?
- Wierd overheating question!!
- door cover
- One quick ? (noob question)
- parts help
- nrg quick release
- torque specs
- B16a will it pass Smog in Cali?
- intake mani question
- Crx headlights wont work
- alternator belt help!
- zc parts the same?
- cabin harness HeLp! (pics inside)
- Cusco Front lower tie bar!!
- heating problem please help
- How do u install front strut tower bar??
- Reverse switch question.
- civic ef9 rear headrest
- How many teeth can the timing belt be off without causing damage?
- ef gsr bogs
- Clutch Issues!
- cabin harness swap???
- Front bumper swap from a 4th gen to a 5th gen???
- No spark in crx
- cluster keeps shortin out my car.
- a6/y8 mini me, larger timing belt tensioner?
- Help me please!!!!
- OBD2 - OBD0 Distributor Re pin Diagram
- What r the best brand???
- Newer Supsension Camber Problems
- 92-95 Civic A-Arms
- Just picked up this traction bar
- are d16a6 and d16a1 same internals?
- crx si ecu compatibility
- dohc zc swap question - what is this part?
- What size r ur blackie??
- Code 9
- CRX Auto Not Starting
- Which exhaust do u recommend the sound great??
- Which header do u recommend??
- DX Bout to get A/C YAY!!!
- dx hatch ?'s
- New BOMZ racing seats
- difference between an ef6-7 an ef8
- 88-89 si cluster in an 89 dx
- Master Cylinder
- search doesnt work sedan interchangability?
- CRX Auto Dimming rear view Mirror
- clutch lever question
- what do i do with these injector wires?
- Starter problems
- CB hood repairs...
- Eibach Pro-kit Help
- nothing on hatch works
- 89 Hatch b20
- barely cranks..... input plz
- Help with diagnosing engine start problem please
- Car vibrates/shakes..could it be the alternator??
- Got a few questions, seats,tps,speedo cable.
- Car starts and idles for a minute then dies...fuel pump?
- What would you do!!!
- code 13
- RHD power windows to LHD EF??
- what wires are these ! 90 dx
- Mud flaps???
- ef hatchback with crx front end??
- dohc zc vtec?
- Got my GSR head in today ( BIG problems)
- Converting 91 CRX to Manual, Worth it?
- roll cage
- *sigh* my car wont start
- window visor/vent visor
- obd1 with an obd2 distributor?
- Cluster keeps burnin up.need help
- Brake Lights Dont work!!!!
- Break light on in my ef hatch!!!!!
- CRX, B16A parts up for grabs
- help running my vtec wire
- 88-89 & 90-91 cluster
- 91 ex to 89 front
- hood spacer fab?
- transmission q - 90crx dx
- Car dies when it hits 1/2 tank
- what is wrong with my b16a!?
- tinted windows???
- 90 crx si b16 idling problems
- OBD-1 INjector clips.
- rear lower control arms question
- pimp the 4Door???
- 1990 Civic Si dash into 1989 Civic STD? swap woes
- ecu and chips...tech Q?
- obd0 b16 distributor??? help please
- Reverse/Back up lights Always on
- Autopower roll bar with interior question
- rear wiper issues
- need help with ex hubs asap
- Will it fit??
- Camber question
- Anyone seen these?
- 88 harness in 90?
- front lips
- Injector clips?
- ef front end
- Ef VS Eg coupe
- wiper stuck on low.
- B-Series into EF
- boosted d15?
- EF seats
- does this look right (walbro 255)
- wiring problems galore... *sigh*
- electrical issue
- sohc zc/mpfi swap
- Suggestions!!
