windshield sprayers inop
Old Aug 22, 2015 | 09:07 AM
dudesmccool's Avatar
Default windshield sprayers inop
Hey guys!
Ive got a 1990 civic with some windshield wipers that are not working.
Now I have out power directly to the sprayers motors and the definitely work. Fluid sprayed everywhere (heh)
I see no popped fuses, no cuts in the wiring or obvious damage.
This badass little care does a rear wiper and that sprayer does work.
Any ideas on how to fix this?
thanks in advance! lots of brilliant minds on here.
Old Aug 22, 2015 | 11:47 AM
James89DX's Avatar
Default Re: windshield sprayers inop
Your actual stalk on the steering column could be bad. One of the functions on my wipers no longer work and my sprayer function no longer works out of the blue starting a few months back. I suspect the actual steering wheel stalk is bad but haven't tried changing it yet.
Old Aug 25, 2015 | 06:30 AM
turboboxer6spd's Avatar
Do you have power coming from the switch like James said? Or were you supplying the power from a battery? You could have a clogged line but if there is no power from the switch, check fuses first. If fuses are good, try a good switch but also check any wiring that might be rubbing somewhere especially if it looks out of place. On these older cars, wiring doesn't always get routed where it should.
Old Aug 25, 2015 | 01:51 PM
94eg!'s Avatar
#1 Super Guy
Loved
Most likely the switch. Replace it with a used one from ebay. New ones are crazy expensive. You can do it without removing the steering wheel but it's a pain.
Randysi
Oct 18, 2012 01:24 PM
Efjdm88
11
Jun 20, 2012 11:51 AM
94eh2
Jan 15, 2010 08:42 AM
Stingray96
18
Dec 23, 2005 10:44 AM
0 0 0
Jan 9, 2004 05:40 PM
