1990 Civic Si tach not working correctly
Old Aug 26, 2015 | 05:26 PM
Rio_Red's Avatar
Default 1990 Civic Si tach not working correctly
1990 Civic Si, 246k on stock d16a6. My tachometer stopped working the other day, it starts up and idles at 0(according to the tach of course), and then moves fast up the RPM range. Anyone else have this problem and suggestions to fix it?
Old Aug 27, 2015 | 07:21 AM
90civichbsi's Avatar
Default Re: 1990 Civic Si tach not working correctly
Could be the ignition control module (ignitor) in the distributor on it's way out. When they start to go bad the tach will fluctuate and do odd things.
The part is pretty universal between most D/B series distributors if you have another laying around.
Old Aug 27, 2015 | 09:15 AM
Rio_Red's Avatar
Less than a couple months ago I replaced the cap, rotor, and (according to o'reilleys) the part was called an ignition coil, would that be the same part you are talking about? On top with a blue and black/yellow wire attached?
Old Aug 28, 2015 | 03:20 PM
tamboo's Avatar
10 Year Member
that's the coil, it's below where the other end of those 2 wires are.
Starting Problems
Old Aug 29, 2015 | 02:50 PM
graveltravel2's Avatar
its the ignitor in the dizzy.
jdykstra28
Sep 25, 2013 06:41 AM
TcUiRvBiOc
Sep 24, 2009 10:34 PM
2DoorBandit
Jun 28, 2008 05:52 AM
murphymiddlesboro
Jun 27, 2004 12:46 AM
CivicSoul
Sep 9, 2002 04:37 PM
