View Full Version : Honda CRX / EF Civic (1988 - 1991)
- what should my rex running in the 1/4
- Question about Tanabe Super Hyper Medallion catback.
- d16z6 turbo cam
- ef9 civic sir vin #
- Putting the civic on a diet for the week
- ***Post your supercharged B16 1/4 mi. Times!!***
- CTR Engine Code?
- Clearing ECU codes - PR3 (search = tried)
- Motor Mounts
- do u guys think im paying too much? for my crx
- East Coast JDM Engine Importer ?
- Recently traded JDM B16a S1 for a USDM Integra S1.....
- doing a full swap
- d16z6 cam
- DX ECU with ZC?
- Smoke at idle with ZC
- CRX seat replacement foam...
- d16a6 head on d15b2 block and still run DPFI????
- B16A struggles during cold start
- B16 head & gsr head What's the difference?
- question about s-afc.
- will crx body parts/kits fit the civic?
- anyone w/revhard 2c pics on a crx
- can someone please repost power mirror wireing diagram
- 4-door
- Hood pins on an EF..
- need help limp mode
- anyone driving an auto HB?
- ahh hondaautomotiveparts.com isn't working any more?!?!
- Ya so my CRX exhaust got really loud for no reason.
- bad wheel bearing on my used EX knuckle?
- ZC CRX 1/4 mile times, did search..
- Please post pics of seats in CRX
- CRX Armrest?
- b18a... whats the swap worth?
- This sucks, I can't make up my mind!
- tailight wiring harness quick question
- I dont hear vtec.. maybe my dam STD piping..?
- setting ignition timing - need help ASAP!
- in middle of swap. help please
- ZC probs...running rich etc etc...
- Just came home from track with my MPFI CRX DX
- Where to get a half-size radiator for a CRX?
- Some pics of last week Solo I
- My car always CEL 17 VSS how do I fix it..?
- Exhaust System
- Hwo many teethe on 88 , 89 - 91 tranny si?
- b16a1 from EF into EG..difficult?
- needed: black corners (90 hatch)
- will a altenator off a 88 crx si fit onn 88 crx dx?
- what it would take to get OBD1 dist to work on OBD0 harness
- ??????Does any one have??????
- wing for ef`s????
- d16a6 headgasket on d16z6/y8
- S/t swaybar fitment with greddy mx exhaust
- MIni me, z6 , or zc...........pros and cons?
- Need help with crx wiring!
- Gauge/Taillight problem HELP!
- Help me on a set of stickies!!
- crappy numbers
- crx motor mount question
- what goes in these slots???
- b16a2 SIR in 89 hb Si 1/4 time crap...help what's wrong?!?!!?
- florida rexers?
- A good motor
- hard ass motor mounts
- mpfi
- How much trouble will it be to.........
- How do i put an Si sway bar on a DX?
- just bought a ef.. help me out with motor/seat/susp. questions.. first time ef owner..
- b16 rear mount bracket HELP!!
- Timing?
- Motor Mount Question...
- help real quick!!!
- Oil leak on b16 were could it be coming from
- Exactly what goes wrong with ls/vtec setup to deem it "unreliable"
- Can you adjust the clutch on an '86 CRX
- thinking of selling my 91 crx si what do you guys think it is worth
- Any ideas on how to ground a temp sensor
- Does anyone know if the EF9 (JDM civic) radiator support fit the crx (EF8)
- how do you wire up a tach?
- Y8 manifold question
- How much ????????????
- Push Start Button Install..Easy/Hard?
- How To: A/C Kill Switch with pictures
- tranny q's
- b16 block
- ?? How do I remove the turn signal switch
- hood cut out for air intake?
- type r seats in an 88??
- need to take off crank pulley
- damaged bumper support
- Self healing hail damage
- 86-87 (pg6b) d16a1 pistons?
- Arghhhhhh!!! I hate cars! Timimg Belt Q's...
- Side skirts for crx question....
- just put in zc and it wont start help
- EF w/ B-series and Jdm/Dc ITR header--Hang low?
- Which Quaife LSD for JDM B16 with S1 tranny.
- B16 or B18a/b CRX. Which would you choose?
- seats that don't suck
- Installed Skunk2 manifold and now my intake wont fit
- zc bogging
- take 1 part Cable YS1 ls trans add 1 part gsr FD and 1 part ITR LSD = wheeeee!!!!
- Auto To Manual
- AC in a b16a 91 civic
- obd1 b18b how many 02 sensors?
- Drag Racing tips?
- What bushings do I need ?
- b17 trany??
- Gearboxes question - 1.3, 1.5, 1.6 sohc engine gearboxes the same?
- wires... lets talk wires..
- Spring question
- problems w/ camber kit plz help
- Proportioning Valve Need it Straight....
- Intercooler piping VS. Washer/overflow bottles!!!!
- where can i pass smog?
- crx drag shell, b16a motor swap, seats, tire/wheel, etc
- FS:2000 civic si front end Conversion OEM
- when shifting rpms don't drop unless i let off the throttle for a good second
- how to.......
- Jdm fenders and hood on usdm car?
- 8 valve d series block with 16 valve head
- soon to be crx owner... decisions decisions help me out please!
- race cats?
- b16 hesistation, anybody get it? how to fix??
- having some bad luck....
- Weird gauge problem
- Msd rpm switch for mini-me
- ZC, tranny/axles problems...
- Can someone explain this to me?(ebay ad)
- black corner lens
- quick head gasket question
- Anyone have access to EURO parts or pics?
- Bags on a 91 Civic Hatch???
- do civic fenders fit a crx?
- How much gas does my 88' CRX DX Hold?
- JDM corner lights
- Car wont start??
- on-line service manual for '90-'91 Integra?; 5th gear syncro change-over
- DOHC ZC Firing Order
- Crx suspension question...
- Fuel problem???Help?
- Do these belong to a B18C1/C5 oil/water pump
- need help with my crx
- Head Bolts, Exhaust and intake gaskets, TB seal.
- just got ebay intake :)
- wiring schematic
- DPFI to MPFI to B18A
- Restoring Black moldings and bumpers
- any differences between B18a longblock from auto/manual car
- Check out my Civic on EBAY. Reserve has been met!!!!
- for those that are intrested, CTR header vs. Clearance :)
- Some parts on my b16 broke and i need to know what they are.
- b20 vtec set up running 12.5 the block is still stock... i need some pistons
- Car stutters a lot and drives/sounds like a Go Kart?
- ***pics of how many miles on car***
- i need fiberglass front end,doors,hatch and rear bumper 4 crx
- Looking to buy a 90Si Hatch....have ?'s
- How much should I sell my 91HB for? B18C1 swap, turbo, etc..
- High speed stability and ES bushings...
- new bushings for front suspension
- Slr style fenders
- I blew my 90 Si's D16A6, what do I need to do to swap in a B16A1?
- Front brakes swap to Prelude's ones???
- Gearbox swap for crx d16a9 questions..
- crx tranny in a civic? dumb question?
- Brake pads for CRX???
- ***Any power gains from a FMIC hooked to a supercharger***
- my ecu reads code 19
- CLUTCH Problems
- DX to MPFI/ZC need tons of help please help please
- What Distributor Cap and Rotor for a ZC?
- What Distributor housing and ignition coil for JDM B16a?
- b16a swap into 1986 crx si
- Anyone doing this?
- Test Pipe on 89 Crx Si???
- Tuning the cam timing on a sohc???
- dash lights dim all of a sudden?!
- help with turbo crx
- How much is a D16a6 with about 100K and running strong worth?
- Standard B16 Setup. Post pictures.
- Help w/ 92-95 SiR steering wheel install
- Compression test results on my D16a6
- K20 in CRX
- looking for setting for a vafc for sohc
- 91 hf throtle surges at idle??
- Fluidyne Radiator for 90 CRX Si with B16a?
- door window wont stay straight
- '90 civic STD dash to a '90 civic SI dash swap questions.....
- Please some Help here D15b8 (obd1) into 88 crx
- how many guys runnin nos on their d16a6s....
- aww man this sucks...
- What seats are these? (thanks in advance)
- Swapping b18a, need some recommended parts.
- All motor monster: tuneing high compression z6
- how can i tell what year my b16 is?
- how do you post pictures?
- PInout needed for PM6 ( 88-91 Civic/crx si)
- going from d15a to d16a6
- HondaAutomotiveParts.com
- HF owners! do the hf have idle control valve? if so...
- ecu chiping and chips for obd0 ecus
- I need a nice big pic showing the CRX interior, preferably one showing the dash and doorpanel in sam
- code 22 - fixed, now code 21
- B18A1
- SiR glass roof look alike?
- Differences in the DX/Hf & si engine harness's?
- Will 90-93 integra front suspension work on a 89 civic dx ??
- muffler shop cat-back on 88 crx
- clutch
- PR3 Program for Zdyne?
- POLL: Nicest Stock Steering Wheel - 2, 3, or 4-Spoke
- si head on dx block????
- Crx Zc hoses
- any road racers use wheel spacers?
- shock question
- b20b powered crx
- I blew a hole in my block!
- Who uses what engines??
- steering with no axles?
- 2 stock 91 crx si lips- $45 shipped
- cleaning head gasket
- No power at all now
- 1988 CRX AC System
- D15 motor, D16 tranny...
- B18C1 in a CRX? opinions...
- Hood release cable broken? Help me out!!!
- P28 Pin-Out
- Future turbo considerations
- CRX with JDM b16
- keithv... Why did you lock my RacePlates post?
- Main relay, what other cars will work for the crx ?
- Changing Lock Cylinder and can't get it in
- Charateristics of an OLD catalitic converter?
- fuse keeps blowing
- guage mounts
- 1998 civic ex swap info???!!!!!!
- ES bushing install problem... tension arm wont fit! help asap
- silver faced gauges?
- EF8/9 speedo swap
- Reclinable seats vs. non-reclinable seats
- will 90 integra cluster work in a 91 hatch????
- just installed jdm 4-1 header and cat back exhaust...
- will 93 hubs fit 89?
- whats better ??
- will a 90-93 accord aftermarket intake fit my 90 STD HB?
- will a 90-93 aftermarket intake fit my 90 STD HB?
- matching 90si motor to an 88si tranny
- Another MPFI problem
