View Full Version : Honda CRX / EF Civic (1988 - 1991)
- new coil lead to no engine turnover
- question about fuel tank vent
- Battery Drains - Need Help Please
- 91 Civic LX. No Crank (sort of), No Start
- alternator over charged to 18 volts car died
- Something electrical.
- Best fitting ebay header
- turbo install 98 crx, pipe clearance
- Clunk sound when going over speed bump
- hood
- Where to find replacement ST Sway Bar bushings?
- Temperature switch wiring harness
- How to replace transmission input shaft on a B transmission
- Obd2 injectors
- Has anyone had this happen before?
- D-Series Shift Linkage Rebuild
- Rota Slipstreams on CRX: what size?
- Can MPFI distributor be used on DPFI cars
- MPFI distributor plug pinout, why two different sources
- I need help guys.
- Ignition coil resistance check
- Distributor sensor polarity matters?
- I need help guys.
- 91 EF DPFI no spark
- Why Honda design the main relay this way
- 91 EF hatch build
- Engine Guru's whats this issue?!
- 91 Si build thread
- EF Sedan Brake Conversion Questions
- Civic EF a/c motorswap question
- 91 crx b17a1 turbo ?
- Removing interior harness. a few questions please help
- Emission problems
- Ef sedan b18b1 swap no spark test light is on at the ignition switch
- B20 swap which ECU to get
- B20 swap use OBD1 injector to delete resistor box?
- 88 Civic Hood Latch
- Temperature gauge not working
- My car battery dies just sitting in the garage
- 2 crxs to 1
- DPFI to MPFI B18B1 swap help
- distributor burnt up 1988 D16A6 RT4WD wagon
- please help no crank no start
- Junk yard EF B20 mounts, are they any good
- EF b swap mount question
- EF B20 Swap, no front mount
- Radiator fan not working (searched)
- Wiring problem crx 90
- 91 civic windshield replacement, how much?
- My ef
- Radiator Support
- Code 14 on after start up
- ac problem
- 89 civic dx sohc zc swap help!!!
- Odb1 conversion spark but no injector pulse
- Mechanic Work Quote
- For B20 swap, the 90-93 integra Half shaft is so hard to find
- Removed my first transmission
- 91 civic wagon spindle for B20 swap?
- 1991 civic, dpfi to mpfi problems. Obd0 to obd1.
- ECU/ECM Question
- Shuttle ef3
- Ac hookups
- Question about AC not working
- My rexy spun a main bearing
- Doesn’t want to start just every now and then..?
- NO CRANK OR START
- 2wd 91 civic wagon z6 swap
- Steering gear bearing
- Pwr Door lock alarm install
- Valves and pistons collide? Honda cb900
- 1991 sedan d16y8 swap - left axle doesn't fit the engine block
- which transmission to use for 91 EF std B20 swap
- Crx retro fitting
- bumpy ride with new wheels?
- What are the other honda iacv that is compatible with 16022-p6d-k01?
- Rear Window Heater Weird Issue
- 91 sedan auto seatbelt wont retract
- Where is 91 honda crx hf speed sensor location
- Doesnt start
- 1990 ED6 DX B18b1 LSVTEC swap, Build thread, may ask questions.
- Body panel replacement
- EF Door Hinge Pins & Bushings
- I have 2012 insight,
- 91 honda crx hf speed sensor
- 91 honda crx hf check engine light goes on/off
- SWAP EE4 D16Z2 TO D16A9
- Cr-v trailing arm swap/interchangeable
- Car won’t start after home wire tuck
- Question about interchangeable parts.
- Rear disc conversion and aggressive braking with stock 1725 prop valve?
- Which size tires should I got with?
- 97 Honda CR-V Stalling while driving and slow start
- Got a set of si’s for my crx n had 3 different sizes
- 1989 Civic ef Stalling issue Cant find similar issue
- Maintenance Schedule?
- B18b1 motor mount issues
- engine swap
- Should I put gsr blades on my crx or si wheels
- Turn signals on solid
- JDM D15B Carb Issues
- Front wheel bearing dust shields?
- bvans CRX rotten to racing
- Omni tach in 89 CRX? Why wouldn't it work?
- Bottom bolt for starter 1992 Honda Accord Wagon
- Ideas On What To Do Next
- 89 Civic Distributor plug wires
- black smoke and engine died
- Carb trouble
- What Should I Replace?
- Rywire obd1 harness ???
- hiu
- 3rd Gen DOHC ZC Ignition Timing
- What is this hose for??
- Need Help 1990 Crx si b20 swap
- What engine do I have?
- Gsr cluster help
- Need Valvetrain Advice
- My 91 Civic dx sedan b series build
- B or K swap
- Troubleshooting: 1991 Honda CRX won’t start for some reason
- Grommets
- Need help with damaged seat mounting points
- When you use a bolt cutter to cut your fuel line
- Help with mpfi
- 1989 Civic LX
- 1989 Civic SI d16a6 with some timing issues
- Fuel tank from shuttle
- Driver side window glass interchange ?
- Few Questions About Engine Swapping...
- 89 honda integra TDC sensor error
- d16y8 with y7 block vitara pistons and eagle rods
- Front LCA Replacement Options
- What automatic gearbox will fit b20 in a crx
- EF Civic Hatch DX (no sunroof) ceiling leak
- D series harness on b series?
- Just got my 91
- Cluster help
- Fuel out of intake
- D16Z6 Code 16
- JHMED7_B16A_Y1 LSD_hondata s300_NA_all motor
- 2018 cost of doing a DPFI to MPFI swap
- Main Relay Clicking/MPFI Question
- Trying to do a head swap, looking to pick someone’s brain
- 91 Civic Type R. Trying to get a feeler of what shes worth.
- Crank angle sensor went bad so I replaced it, now the car runs sluggish
- B20 Swap, which exhaust manifold to use
- Gauge cluster and turn signals not working
- HELP 1991 CRX turned into racecar put fuel cell in no fuel
- B20B change to B18C1 or maybe B18C5
- Brake questions
- Obd2 integra into dual point civic
- Can I rule out rear main s leak if back of fly w is dry
- What 14 years of neglect looks like....
- Fuel door stuck, no it's not the release tab.
- Can cry axles fit 90crx si front hubs?
- Opinions? F swap with F2D? Cost vs HP NA build (noob)
- Which distributor do I buy?
- Just bought a 1991 Wagon, had a question about timing belts
- 88 crx rear plastics into a 91 si
- Trailing arm swap
- 1988 crx si temputure gague plug wire?
- Simple Question (Hopefully)
- Obd1 swap cranks no start no check engine light
- Transmission codes for the swap
- Speedfactory radiator / intercoooler combo - Front Bumper advice and HELP PLEASE!
- Need help with 1990 civic timing!!
- main relay or starter
- 91 civic ef std B20 swap, can I use stock spindle?
- Why do OBD1 conversion?
- CRX
- Transmission issues 1990 hatch
- Intake manifold bolt pattern, D15 and B20 the same?
- How to remove broken cylinder lock from steering colum (theft gone wrong)
- 1990 Civic DX Sedan
- Header glowing red??
- Help with setting up VTEC on a D16A6 with a Y8 Head
- Timing belt walking off pulley
- lightweight crank pulley anyone?
- Coolant in Reservoir boiling. Need Help!!
- Ignition problems, no start.
- Motorcycle battery?
- 90 crx 1.5 stumble/surges while driving
- What door is on my 88 crx si?
- Civic Ef New Exhaust System
- TWIN CARBURETION
- Cable to hydro Fiasco
- Civic Engine Rebuilt
- Skunk2 intake manifold B20
- 89 Sedan swap
- Deleted OEM Seatbelts - Bypass Warning Light/Alarm
- 91 DPFI Civic HB, low speed bucking, feeling crazy
- 91 Si Steering Rack noise
- Gear drive
- Help with obd0 ecu code
- no start 88 honda crx si
- Drop springs didn't drop lol
- Big injectors on stock engine
- B16a2 overheating issue
- Si vs EX Brake Pads
- Weird Noise 🤔 Need help figuring it out
- Can you put a Da shift linkage on a B swap 91 Honda Civic DX
- relpace a cigarette lighter
- Rear hatch leaks...91 HF
- Rywire tuck harness EF sedan lx model
- Adding Honda or Universal AC Kit?
- Adding a cigarette lighter socket to my CX
- 91 crx si ac questions
- D16A6/Y8 mini me was running, now cranks but wont start
- Adjusting The Rpm
- removal of this type of pump
- Compensator Arm Substitution
- D15B 1988 Honda CRX HF Idle Issue
- 1988 Honda CRX washer fluid drain
- Found a mint 1991 Si with 188K Miles - Should I be worried?
- How much could I sell my OEM mudflaps for??
- 88 civic check engine, oil and battery come on
- D16Z6 Help // New everything, no start // Videos to help diagnose
- DPFI to MPFI difficulty?
- 1991 Honda Civic DX HB
- Ecu wiring diagram for b20 swap
- Lug Nut Size?
- Crx si sunroof issues
- How to make a stock 91 EF hatch fast?
- Window regulator roller replacement?
- Questions about a 91 crx
- Weird problems with this car. 1989 Civic SI d16a6
- Y7 cam gear timing question.
- Y8 head mini me - couple questions/clarifications
- Question about my ef rear disc brake conversion?
- D Swap Fuses
- Future build
- Stuck Crankshaft Pulley Bolt - Broke
- Engine swap ideas
- 1989 ef b20 help
- Shifter shifts to middle after putting in gear.
- B18 Turbod EF
- EF hydro conversion - Suja1 vs Hush Performance
- 89 dies when clutch released
- No pressure in clutch
- B18 in an EF
- 91 Civic autmatic Trans. will my Junk yard replacment work?
- Will a 26x10x15 fit on a crx (15x10 0 offset wheels)
- Bizarre High Idle Issue
- d15b7 with y7 head in ef ran dpfi confusion
- the passenger power windows will not go down
- Transmission drain and fill plug washer size?
- Mugen inspired ED7 Been YEARS since ive been on here too.
- Running lights not working, 2 months diagnosing and took to shop.
- 89 Civic DX
